Hello!
I am having a problem running the wrf, roms coupled mode. roms sea surface heights do not correspond to the measured tide level data. There is a difference of 6 hours between them and I would like to know why. How should I adjust it.
The tide level file I am using is Create_roms_tides.m in coawst. The data uses the osu dataset. The simulation is from 13 to 17 September 2018. And I think there should be no problem with the settings in the ".in" file.
The roms simulates a 6 hour difference in tide levels.
- Location: Changsha University of Science and Technology
Create_roms_tides.m
- (13.71 KiB) Downloaded 667 times
roms_mangkhut_r1.in
- (153.54 KiB) Downloaded 648 times
- zeta.png (178.9 KiB) Viewed 8241 times
Re: The roms simulates a 6 hour difference in tide levels.
looks like the simulation starts with zeta = -0.5 but the obs are at +0.5.
so it will take a while for that barotropic mode to slosh out of the model. after 2 days the water levels look like they are starting to get into phase.
if that storm at time 40 is your main interest, i suggest you start the simulation a few days earlier.
Thank you for your reply.jcwarner wrote: Fri Jul 22, 2022 1:33 pm looks like the simulation starts with zeta = -0.5 but the obs are at +0.5.
My model was run two days in advance and the results are for two days later.
And at 40 hours, the typhoon is about to make landfall, which is why I think there is a rise in sea surface.
- zeta_1.png (29.54 KiB) Viewed 8180 times
