How to make a roms model driven only by tidal and wave forcing
zhaolv
Location: Changsha University of Science and Technology
#1 Unread post by zhaolv »
Hello, I have currently been able to successfully run the roms model as well as the wrf-roms-swan coupling model via coawst. However I find that I have to use a forcing file with wind fields in my roms model. How should I change my .h file if I want roms not to be driven by the wind field and only use the tidal forcing. And how do I set it up when roms and swan are coupled?
#define ROMS_MODEL
#define NESTING
#undef WRF_MODEL
#undef SWAN_MODEL
#undef MCT_LIB
#undef MCT_INTERP_OC2AT
#undef MCT_INTERP_WV2AT
#undef MCT_INTERP_OC2WV
#if defined WRF_MODEL && defined SWAN_MODEL
# define DRAGLIM_DAVIS
# define COARE_TAYLOR_YELLAND
#ifdef ROMS_MODEL
/* Physics + numerics */
# define UV_ADV
# define UV_COR
# define UV_VIS2
# define MIX_S_UV
# define WET_DRY
# undef  TS_FIXED
# define TS_U3HADVECTION
# define TS_C4VADVECTION
# undef  TS_MPDATA
# undef SSW_BBL
# ifdef SSW_BBL
#  define SSW_CALC_ZNOT
# /*define ANA_SEDIMENT*/
# else
#  define UV_LOGDRAG
# if !defined SWAN_MODEL && defined SSW_BBL
#  define ANA_WWAVE
# define DJ_GRADPS
# define TS_DIF2
# define MIX_GEO_TS
# define CURVGRID
# define SALINITY
# define SOLVE3D
# define SPLINES_VDIFF
# define SPLINES_VVISC
# define AVERAGES
# define NONLIN_EOS
/* Grid and Initial */
# define MASKING
/* Forcing */
# ifdef WRF_MODEL
#  undef  BULK_FLUXES
#  define ATM2OCN_FLUXES
#  define ANA_SSFLUX
#  undef  LONGWAVE_OUT
# else
#  define BULK_FLUXES
# define ATM_PRESS
# define ANA_BTFLUX
# define ANA_BSFLUX
# define ANA_BPFLUX
# define ANA_SPFLUX
# define ANA_SRFLUX
# define EMINUSP
# define SOLAR_SOURCE
/* Turbulence closure */
# define GLS_MIXING
# undef  MY25_MIXING
# define AKLIMIT
#  define KANTHA_CLAYSON
#  define N2S2_HORAVG
#  define RI_SPLINES
/* # define SSH_TIDES
# define UV_TIDES
# define RAMP_TIDES
# define ANA_FSOBC
# define ANA_M2OBC */
/* Output */
# undef DIAGNOSTICS_UV
# undef DIAGNOSTICS_TS
zhaolv
Re: How to make a roms model driven only by tidal and wave forcing
#2 Unread post by zhaolv »
I don't know much about cpp options, but I tried turning off the BULK_FLUXES option and "define ANA_SMFLUX". I'm not sure if this is the right thing to do, but the result suggests that I need shflux data. The GFS data (including Uwind, Vwind, Pair, Tair, etc.) that I used when I "define BULK_FLUXES" did not include shflux data, and I would like to know where I need to download this data from.
