Couple WRF and ROMS:Could not find input parameter: NestLayers
zhaolv
Location: Changsha University of Science and Technology
#1 Unread post by zhaolv »
hello
I am using COAWST to couple WRF and ROMS, I have been able to run WRF and ROMS separately, after that I edit the coupling.in, scrrip_coawst file.
but when I run it, I am prompted with an error in the roms.in file, missing NestLayers.
But actually my roms.in file already includes the NestLayers variable. I don't know how to fix it, please help me
out.in
Model Input Parameters: ROMS/TOMS version 3.9
Wednesday - April 6, 2022 - 10:36:36 AM
READ_PHYPAR - Could not find input parameter: NestLayers
in ROMS standard input script.
Add "NestLayers" keyword after "Ngrids".
Program received signal SIGSEGV: Segmentation fault - invalid memory reference.
Backtrace for this error:
roms.in
! Number of nested grids.
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Re: Couple WRF and ROMS:Could not find input parameter: NestLayers
this is more of a coawst configuration issue, and should be posted here:
https://github.com/jcwarner-usgs/COAWST/issues
can you post this and the coupling.in file over there.
