I had trouble for running model using latest version of ROMS and realized that this is because error in mod_scalars.F
Using USE_DEBUG, it is figured out that the error (mentioned in viewtopic.php?t=6022) is caused in mod_scalars.F, line of
user=0.0_r8
Debugger said: Fortran runtime error: Assignment of scalar to unallocated array.
The generic user parameter array (user) is updated to be recently allocatable variable. I can see that the variable is declared as allocatable, but there is no code to allocate 'user' variable.
To be specific, mod_scalars.F need to include below codes
IF (.not.allocated(user)) THEN
allocate ( user(Ngrids) )
Dmem(1)=Dmem(1)+REAL(Ngrids,r8)
and
IF (allocated(user)) deallocate ( user )
. After I put these code in mod_scalars.F, latest version start to work.
I would be pleasure if it can be officially updated as soon as possible.
Best regards,
Jang
Error in ROMS/Modules/mod_scalars.F
Re: Error in ROMS/Modules/mod_scalars.F
Thank you for reporting this issue. The problem is that the statement in mod_scalars.F
needs to be removed. The other statements that you added are incorrect. The management of the user variable is now done in read_phypar.F.
user=0.0_r8
Thank you for quick response. Hope it can be fixed in next version ROMS.
Always appreciate you for your service.
Best regards,
Jang
Best regards,
Jang
