Hello everybody,
I want to calibrate the tide and the domain is in the Persian Gulf
I've used many lateral condition parameters but none of them help me to calibrate the model as I want(the result of Fla is too large as you can see in the picture below and when I use NudRad, the fluctuation vary by centimeters.)
I also use roms_tools to generate the boundary file
so the question is: should I change the domain or should I generate the boundary file from another source? (or whatever else)
thanks
tide-calibration
tide-calibration
Fla.log
- (45.36 MiB) Downloaded 850 times
RadNud.log
- (24.24 MiB) Downloaded 788 times
Re: tide-calibration
Another option for fussing is the bottom drag. You can make a spatially variable bottom drag and modify it to get a better match.
kate wrote: Tue Jul 20, 2021 6:43 pm Another option for fussing is the bottom drag. You can make a spatially variable bottom drag and modify it to get a better match.
thanks a lot, kate
I'll check it.
Amirhossein, did the bottom drag adjustment solve the problem? I hope so. If not, I may have some ideas based on previous experience in the Gulf. I had a lot of trouble too, about five years ago, getting the tides to behave (I was looking more at comparisons around the UAE). What database of bottom depths are you using?
Hi johnluick,
I didn't find a way to calibrate the zeta parameters and the bottom drag didn't help me too. what was your idea as you said about this problem?
thanks
thanks
I used to run a similar gulf case, and I foudn that the amplitude of tides is very sensitive to the Zob parameter.
if the result of Fla is too large, I guess you can try to set Zob to a smaller value.
Here is an idea that people may find a bit radical but it can get you back on the road. This is just my opinion and lots of people have lots more experience than me. They are welcome to point it out if I am missing something. I am being a bit of a "devil's advocate" here.
First off, check if the harmonics from the global tidal model are accurate at a nearby port. Chances are, they are. If they are, then think about whether including tides in your circulation model is likely to lead to improvement. Chances are, it will not. Chances are, adding the global model harmonics to your circulation model solution post facto will be more accurate. I personally prefer the latter whenever possible. It is also faster and cleaner once you get your systems in place.
There are trade-offs to either approach. You have already learned about the downsides to adding tides at the ocean boundaries of a coastal circulation model (beginning with hair loss / hair greying). There are limits to the accuracy of all the boundary schemes (Flather etc.) and in my experience there is always some energy reflected. There is also incomplete undestanding of bottom geometry, friction, etc., which are critical to tides due to the relatively high velocity of tidal currents. Nowadays the global tidal models are tuned to both satellite and port data worldwide, and there are no ocean boundaries. It is difficult to improve on them except in small embayments and wide mudflats etc. (and only then if you have really good bathymetry data).
Nowadays I would only add tides to coastal circulation models if I have reason to believe there is a nonlinear interaction between the tidal and wind-driven currents. (I should add that nowadays, I would only run a coastal circulation model if I have a profoundly real reason to do so, because the CMEMS/Mercator system is so good, it is really hard to improve on, and I get a result in seconds as opposed to days or weeks. And by the way you can download a global model forecast with tides already in it! I just prefer to leave the modelling to the experts, and get on with the part that interests me.)
If anyone wishes to contact me directly, please send it to john.luick@austides.com, as I will see it immediately, rather than in days or months (as in the case of DMs sent to this ROMS forum).
Hi sankarea and dear johnluick,
Thanks for your tips.
Dear johnluick, you opened my eyes to this issue. Finally, with a lot of trial and error, I came to your valuable statements.
