Hello All,
This might seem like a very basic question.
Where can I find the exact linear equation of state used in ROMS? I see that in roms.in one can set Tcoef and Scoef (for thermal expansion and haline contraction coefficients) for linear EoS. But I am wondering if somewhere the isothermal compression coefficient is set, and if the linear EoS includes the compression term (which I assume it does..?)
If someone could point out to me where to find the exact EoS used in ROMS it would be more than helpful.
Just need to double check to make sure my density calculation and subsequent diagnosis is using the same as my run with linear EoS.
Much appreciated.
Linear EoS in ROMS
Re: Linear EoS in ROMS
It is a the bottom of rho_eos.F. As always, you can check the C-preprocessed file rho_eos.f90 in the build directory for the case that NONLIN_EOS is not activated. It is a very simple equation and does not include any of the secant bulk modules terms.
