I built a ROMS model on Bohai sea, which is a coastal sea with 24 meters average water depth.But the time-averaged current in one tide period is always too high.
- BASIC MODEL PARAMETERS
2) vertical level: 10
3) boundary condition: east open boundary, Cha for free surface, Fla for 2d-momentum, Cla for 3d-momentum, Gra for mixing-TKE, RadNud for temperature and salinity.
4) boundary data: extract from HYCOM dataset. the hycom dataset exclude the tide-induced current and tide-induced water level, so I turn the CPP option "ADD_FSOBC" and "ADD_M2OBC" on.
*.h file:
#define ROMS_MODEL
# define WET_DRY
/* Physics + numerics */
# define WEC_VF
# define WDISS_WAVEMOD
# define UV_KIRBY
# define UV_ADV
# define UV_COR
# define UV_VIS2
# define MIX_S_UV
# undef TS_FIXED
# define UV_LOGDRAG
# define DJ_GRADPS
# define TS_DIF2
# define MIX_GEO_TS
# define CURVGRID
# define SALINITY
# define SOLVE3D
# define SPLINES_VDIFF
# define SPLINES_VVISC
# define AVERAGES
# define NONLIN_EOS
/* Grid and Initial */
# define MASKING
/* Forcing */
# define BULK_FLUXES
# define LONGWAVE
# define ATM_PRESS
# define PRESS_COMPENSATE
# define EMINUSP
# define SOLAR_SOURCE
# define ANA_NUDGCOEF
# define ANA_BTFLUX
# define ANA_BSFLUX
# define ANA_BPFLUX
/* Turbulence closure */
# undef GLS_MIXING
# define MY25_MIXING
# define LIMIT_VDIFF
# define LIMIT_VVISC
# define RI_SPLINES
# define CRAIG_BANNER
# define CHARNOK
/* tide */
# define SSH_TIDES
# define UV_TIDES
# define RAMP_TIDES
# define ADD_FSOBC
# define ADD_M2OBC
# undef FSOBC_REDUCED
/* Output */
# undef DIAGNOSTICS_UV
# undef DIAGNOSTICS_TS
518400 ntimes Number of timesteps for 3-D equations.
0 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
720 nHIS Number of timesteps between the writing fields
into history file.
2880 ndefHIS Number of timesteps between creation of new
history files.
120 nQCK Number of timesteps between the writing fields
into quicksave file.
2880 ndefQCK Number of timesteps between creation of new
brief snpashots files.
time-averaged data.
2880 nAVG Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
5.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
1.0000E-03 Akt_limit(01) Vertical diffusion upper threshold (m2/s)
1.0000E-03 Akt_limit(02) Vertical diffusion upper threshold (m2/s)
for tracer 02: salt
1.0000E-03 Akv_limit Vertical viscosity upper threshold (m2/s)
for turbulent energy.
1.2500E-03 Zob Bottom roughness (m).
2.0000E+00 blk_ZQ Height (m) of surface air humidity measurement.
1.5000E-01 Dcrit Minimum depth for wetting and drying (m).
1 lmd_Jwt Jerlov water type.
3.5000E+00 theta_s S-coordinate surface control parameter.
1.000 Tcline S-coordinate surface/bottom layer width (m) used
20190101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
T Qout(idFsur) Write out free-surface.
T Qout(idUbar) Write out 2D U-momentum component.
T Qout(idVbar) Write out 2D V-momentum component.
T Qout(idu2dE) Write out 2D U-eastward at RHO-points.
T Qout(idv2dN) Write out 2D V-northward at RHO-points.
T Qout(idUsur) Write out surface U-momentum component.
T Qout(idVsur) Write out surface V-momentum component.
T Qout(idsurT) Write out surface tracer 01: temp_sur
T Qout(idsurT) Write out surface tracer 02: salt_sur
T Qout(idUsms) Write out surface U-momentum stress.
T Qout(idVsms) Write out surface V-momentum stress.
T Qout(idUbms) Write out bottom U-momentum stress.
T Qout(idVbms) Write out bottom V-momentum stress.
T Qout(idPair) Write out surface air pressure.
T Qout(idTair) Write out surface air temperature.
T Qout(idUair) Write out surface U-wind component.
T Qout(idVair) Write out surface V-wind component.
T Qout(idTsur) Write out surface net heat flux.
T Qout(idTsur) Write out surface net salt flux.
T Qout(idSrad) Write out shortwave radiation flux.
T Qout(idLrad) Write out longwave radiation flux.
T Qout(idLhea) Write out latent heat flux.
T Qout(idShea) Write out sensible heat flux.
T Qout(idEmPf) Write out E-P flux.
T Qout(idevap) Write out evaporation rate.
T Qout(idrain) Write out rain rate.
T Aout(idu3dE) Write out averaged 3D U-eastward at RHO-points.
T Aout(idv3dN) Write out averaged 3D V-northward at RHO-points.
- PROBLEMS
I also ran a particle tracking experiment with the output flowfield for 15 days, and most of the particles moved for more than 100 km within 15 days. It also unmatches the buoy data.
Is there anyone who have met similar problems? I would appreciate it if you could post any replies!
