Clarification about ROMS/Utility/get_nudgcoef.F
stlaur
#1 Unread post by stlaur »
Good afternoon,
I have a little question related to ROMS/Utility/get_nudgcoef.F, first introduced in the post:
https://www.myroms.org/projects/src/ticket/627
As described in the post, get_nudgcoef.F is designed to handle values in either day-1 or s-1.
Its logic follows the "units" metadata accompanying the nudging field inside the user's NetCDF file.
At the same time, ROMS/External/varinfo.dat file has (I'm picking M2_NudgeCoef as an example):
'M2_NudgeCoef'                                     ! Input
  '2D momentum inverse nudging coefficients'
  'day-1'                                          ! [1/s]
  'M2_NudgeCoef, scalar'
  'nulvar'
  'idM2nc'
  'r2dvar'
  1.157407d-5
If I'm not misinterpreting things, the varinfo suggests that day-1 is the "expected units", followed by a conversion to s-1 (scaling factor of 1.15740d-5).
My question is---does the logic inside get_nudgcoef.F supersedes what's in ROMS/External/varinfo.dat?
In other words, is ROMS silently ignoring the 1.157407d-5 scaling factor written in varinfo.dat?
Obviously I could figure out the answer myself by adding write(*,*) statements throughout the code and determine what ROMS is actually doing.
I just wanted to try the message board before going there. Thanks for your time,
Pierre
Re: Clarification about ROMS/Utility/get_nudgcoef.F
ROMS does read the varinfo.dat and scale things accordingly.
