I know it's not directly related to ROMS. Sorry, but currently I don't know where else to ask.
In the harmonic analysis packages [1] and [2], SA is defined as inverse of an anomalistic year. For example, in T_Tide ([2], see file tide3.dat), it has Cartwright numbers (0 0 1 0 0 -1), where the "1" is the frequency for a tropical year, and the "-1" for the rotation of the perihelion. In the same file the frequency for SA is 0.0001140741 cph, i.e. a period of about 365.2596 days, consistent with the Cartwright numbers.
In [3], it's apparently defined as inverse of a tropical year. Table A.1 of [3] lists Cartwright numbers of (0 0 1 0 0 0) and an angular speed of 0.0410686 deg/h, which corresponds to a tropical year (consistent with Table 2.1 of [3], where the fundamental astronomical periods are listed). However, on their p. 38, [3] state that:
Isn't this a contradiction? Wouldn't one need (0 0 1 0 0 0) for the declination (tropical year), and than a modulation thereof for the perihelion rotation, using (0 0 1 0 0 -1) and (0 0 1 0 0 1). But NOAA seems to generally use the tropical year (see e.g. [4], same angular speed for SA as in [3]). Why??Sa and Ssa are very small tidal constituents directly generated by the nonuniform changes in the Sun's declination and distance (the perihelion-aphelion effect).
Also, I just noticed that in the original Cartwright and Taylor/Edden papers [5], the Cartwright number (0 0 1 0 0 0) does not even exist in the tables. Only (0 0 1 0 0 -1) is listed there.
Do people not differentiate because in practical timeseries analysis (harmonic analysis, Fourier analysis etc.) we have no records long enough to separate them?
[1] Foreman M.G.G, 1977: Manual for Tidal Heights Analysis and Prediction. Pacific Marine Science Report 77-10, Institute of Ocean Sciences, Patricia Bay, Sidney, B.C., 58 pp. (2004 revision)
https://www.dfo-mpo.gc.ca/science/data- ... x-eng.html
[2] Pawlowicz, R., Beardsley, B., Lentz, S., 2002: Classical tidal harmonic analysis including error estimates in MATLAB using T_TIDE.
https://doi.org/10.1016/S0098-3004(02)00013-4
[3] Parker, B.B., 2007: Tidal analysis and prediction. NOAA Special Publication NOS CO-OPS 3, U.S. Department of Commerce, 378 pp.
https://tidesandcurrents.noaa.gov/publi ... ctions.pdf
[4] https://tidesandcurrents.noaa.gov/harco ... id=8518750
[5] Cartwright, D.E., Edden, A.C., 1973: Corrected tables of tidal harmonics.
https://doi.org/10.1111/j.1365-246X.1973.tb03420.x
