Change Output Frequency?
osean
#1 Unread post by osean »
Hello All,
I am trying to produce a year-long simulation, with high output frequency over a particular period of time.
At the moment, I only manage to increase output frequency for the entire simulation duration through NHIS in roms_.in file:
Output history, average, diagnostic files parameters.
LDEFOUT == T ! File creation/append switch
NHIS == 72 ! Number of timesteps between writing history records
NDEFHIS == 0 ! Number of timesteps between creation of new history file
NQCK == 0 ! Number of timesteps between writing quicksave records
NDEFQCK == 0 ! Number of timesteps between creation of new quicksave file
NTSAVG == 1 ! Starting averages timestep
NAVG == 72 ! Number of timesteps between writing averages records
NDEFAVG == 0 ! Number of timesteps between creation of new averages file
NTSDIA == 1 ! Starting diagnostics timestep
NDIA == 72 ! Number of timesteps between writing diagnostics records
NDEFDIA == 0 ! Number of timesteps between creation of new diagnostics file
However, that means my output file will be extremely large. I only look for high output frequency over a specific month period in the middle of the simulation, and the rest I only need sporadic outputs. Is there any way we can set varying number of timesteps between creation of writing history records? I see that I can create new history files, but not varying output timesteps among files...
Greatly appreciate any hints...!
Re: Change Output Frequency?
You can run for a bit with one output frequency, then restart with a different output frequency. Anything more fancy is going to take hacking the code.
osean
#3 Unread post by osean »
kate wrote: Sat Sep 04, 2021 1:18 pm You can run for a bit with one output frequency, then restart with a different output frequency. Anything more fancy is going to take hacking the code.
I noticed that there's a restart file option. How does one go about restarting with a different output frequency from a restart .nc file?
Kosa
#4 Unread post by Kosa »
osean wrote: Wed Sep 08, 2021 12:51 pm
You will create a 2nd ocean.in file with a new NHIS and set ININAME to point to your restart file. Note that you will also want to set NRREC to -1.
