READ_INP ERROR: A total of 1 configuration errors discovered.
Isabella_Su
#1 Unread post by Isabella_Su »
Hi! All,
I am running a coastal ocean simulation with tides, however, I always encounter a problem when running it with MPI parallelization.
READ_INP ERROR: Cannot find input file 'ROMS_FILES/roms_grd.nc'. READ_INP ERROR: A total of 1 configuration errors discovered.
However, I did not meet such error when I was running the same simulation in a serial mode, but only with parallelization. Could you please help? I attached my cppdefs.h file. Thanks heaps in advance,
cppdefs.h
(29.41 KiB) Downloaded 425 times
Re: READ_INP ERROR: A total of 1 configuration errors discovered.
#2 Unread post by wilkin »
We would need to see you logfile to debug this.
But, since you are running CROCO and not ROMS from myroms.org, you might want to consult your CROCO colleagues directly.
Isabella_Su
#3 Unread post by Isabella_Su »
Hi! wilkin,
Thank you so much for your reply.
I have posted my question at the CROCO community forum, but did not get answers from the CROCO colleagues yet.
I am trying my best to catch up with the schedule of my project, therefore I am wondering if the ROMS colleagues here could help by any chance.
I have posted the log file from my simulation with serial mode on HPC, which looks like there are problems in reading the topography data from the grid file. But the simulation is running successfully on my computer in the office. I have check the NetCDF library in my HPC account, which looks ok.
Could you help please? Many thanks in advance.
log1.txt
(13.8 KiB) Downloaded 483 times
#4 Unread post by wilkin »
Vertical S-coordinate System:
 level   S-coord     Cs-curve          at_hmin  over_slope     at_hmax
    30   0.0000000   0.0000000           0.000       0.000       0.000
    29  -0.0333333  -0.0001156        Infinity************   -Infinity
    28  -0.0666667  -0.0004685        Infinity************   -Infinity
    27  -0.1000000  -0.0010779        Infinity************   -Infinity
    26  -0.1333333  -0.0019765        Infinity************   -Infinity
There is definitely something wrong with your bathymetry. Possibly NaNs somewhere. Even if in the land, they are a problem.
Look like your initial conditions time might be before before your run start time ...
     GET_INITIAL -- Processing data for time =   0.000     record =   1
 Ntimes from date_start and date_end: -2147483648
but these are CROCO warnings and information that I am not familiar with.
You have a lot of warning messages in general. Probably not a good strategy to ignore those.
Please post any follow up in a more appropriate board than this one ... "Job Opportunities"!
