I am moving back into office so now I have a Ubuntu linux workstation. I was running ROMS previously on my Macbook, which has been pretty smooth. Now switching to Ubuntu linux, I am running into some unexpected issues when I try to re-run some stuff.
I have set up ROMS from scratch again here, all went well, upwelling test case fine, output files good, all fine.
However now when I re-run the domain that I configured myself, I am running into a NetCDF OUTPUT error that I have not seen before:
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_vmix.h
Found Error: 03 Line: 391 Source: ROMS/Utility/close_io.F, close_out
REASON: No error
Note: The following floating-point exceptions are signalling: IEEE_DIVIDE_BY_ZERO
ERROR STOP
Error termination. Backtrace:
#0 0x7f6731b3e820 in ???
#1 0x7f6731b3f379 in ???
#2 0x7f6731b40a97 in ???
#3 0x56067103590e in ???
#4 0x7f67317c2564 in ???
#5 0x56067103595d in ???
#6 0xffffffffffffffff in ???
Essentially as soon as the model started to run at grid 01 it encountered this error. Bizarre, and not sure why. I never had such an issue on Macbook, but now on a Linux PC there is this... Any idea how the dynamic and automatic memory usage here tells me about? Not super well versed with computers so I am trying to learn what it is telling me here...Basin information for Grid 01:
Maximum grid stiffness ratios: rx0 = 0.000000E+00 (Beckmann and Haidvogel)
rx1 = 0.000000E+00 (Haney)
Initial domain volumes: TotVolume = 1.0000000000E+16 m3
MinCellVol = 5.9919432728E+08 m3
MaxCellVol = 1.6185126730E+10 m3
Max/Min = 2.7011481907E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000105120)
0 0001-01-01 00:00:00.00 5.003588E-03 2.460429E+04 2.460429E+04 1.000000E+16
(001,050,50) 5.972398E-02 0.000000E+00 0.000000E+00 9.953997E-01
DEF_HIS - Illegal output type, io_type = 0
Found Error: 03 Line: 82 Source: ROMS/Utility/def_his.F
Found Error: 03 Line: 187 Source: ROMS/Nonlinear/output.F
Found Error: 03 Line: 518 Source: ROMS/Nonlinear/main3d.F
Found Error: 03 Line: 301 Source: ROMS/Drivers/nl_roms.h, ROMS_run
Thread # 0 CPU: 1.134
Total: 1.134
Allocation and array initialization .............. 0.976 (86.0304 %)
Ocean state initialization ....................... 0.104 ( 9.2130 %)
Reading of input data ............................ 0.000 ( 0.0017 %)
Processing of input data ......................... 0.000 ( 0.0215 %)
Processing of output time averaged data .......... 0.000 ( 0.0046 %)
Computation of vertical boundary conditions ...... 0.000 ( 0.0217 %)
Computation of global information integrals ...... 0.010 ( 0.8427 %)
2D/3D coupling, vertical metrics ................. 0.037 ( 3.3020 %)
Omega vertical velocity .......................... 0.008 ( 0.7063 %)
Equation of state for seawater ................... 0.012 ( 1.0810 %)
Total: 1.148 101.2249 %
Unique kernel(s) regions profiled ................ 1.148 101.2249 %
Residual, non-profiled code ...................... -0.014 -1.2249 %
All percentages are with respect to total time = 1.134
Dynamic and Automatic memory (MB) usage for Grid 01: 200x100x50 tiling: 1x1
tile Dynamic Automatic USAGE
0 1227.22 62.70 1289.92
TOTAL 1227.22 62.70 1289.92
Found Error: 03 Line: 85 Source: ROMS/Utility/close_io.F, close_file_nf90
Thanks all
