a minor suggestion about fennel_mod.h
Discussion about coupled ecosystem models
mjfconan
#1 Unread post by mjfconan »
From line 183 to 223, the fennel_mod.h says:
#ifdef CARBON
# ifdef OXYGEN
#  if defined PO4 && defined RIVER_DON
      NBT=15
#  elif defined RIVER_DON && !defined PO4
      NBT=14
#  elif defined PO4 && !defined RIVER_DON
      NBT=13
#  else
      NBT=12
#  endif
# else
      NBT=14
      NBT=13
      NBT=12
#  else
      NBT=11
#  endif
#else
# ifdef OXYGEN
      NBT=10
#  elif defined PO4 || defined RIVER_DON
      NBT=9
#  else
      NBT=8
#  endif
# else
      NBT=9
      NBT=8
#  else
      NBT=7
#  endif
which may be equal to
NBT=7
#ifdef CARBON
      NBT=NBT+5
#ifdef OXYGEN
      NBT=NBT+1
#if defined PO4
      NBT=NBT+1
#if defined RIVER_DON
     NBT=NBT+1
Do I understand it correctly ?
This is a similar code with the end of fennel_mod.h (from line 504 to 526), but why does this end say that CARBON introduced 4 tracers not 5 ?
# ifdef CARBON
      iLDeC=ic+1
      iSDeC=ic+2
      iTIC_=ic+3
      iTAlk=ic+4
      ic=ic+4
Thanks.
arnaudlaurent
Location: Oceanography Department, Dalhousie University
Re: a minor suggestion about fennel_mod.h
#2 Unread post by arnaudlaurent »
When you define CARBON you introduce 4 new tracers: TIC, alkalinity, SdetritusC and LdetritusC. However, if you define CARBON+RIVER_DON you introduce an additional tracer: RdetritusC. This is why in fennel_mod.h you add 4 tracers when CARBON is defined and then 1 tracer when RIVER_DON is defined:
# ifdef CARBON
      iLDeC=ic+1
      iSDeC=ic+2
      iTIC_=ic+3
      iTAlk=ic+4
      ic=ic+4
#  ifdef RIVER_DON
      iRDeC=ic+1
      ic=ic+1
#  endif
mjfconan
#3 Unread post by mjfconan »
Yes, I omitted it.
Thank you!
