add passive tracer
add passive tracer
I want to add passive tracer in ROMS.
Anyone can tell me how to do it ?
Especially, how to make the initial file of passive tracer.
Many thanks.
Many thanks.
Re: add passive tracer
First, you turn on T_PASSIVE and set NPT in roms.in. For the initial conditions, ANA_PASSIVE can be used, otherwise you'll have to put the initial conditions into a netcdf file. I've usually initialized with zero via ANA_PASSIVE, then used sources to introduce the passive dye locally. What is your strategy going to be?
Thank you Kate.
I have turned on T_PASSIVE and set NPT =1. And I add dye_01 into the initial file.
Then, I run the model, but get the error message:
unable to find requested variable: dye_01_sflux
How can I figure it out?
You need these as well:
unless you want the top and bottom tracer fluxes to be non-zero.
# define ANA_BPFLUX /* analytical bottom passive tracers fluxes */
# define ANA_SPFLUX
There is an FAQ
https://www.myroms.org/wiki/Frequently_ ... tracers.3F
and also guidance on what to do if you want passive tracers in your rivers
https://www.myroms.org/wiki/River_Runoff
Thank you, Kate and Wilkin. It works.
I am not sure whether this result present the concentration of dye or not?
How can I do if I want to simulate only the Lagrange motion of particles, rather than the diffusion of the dye concentration?
The FLOATS option is a whole different can of worms. Is that what you want? Online or offline?
Online
How to use FLOATS option?
I see the wiki page on FLOATS is still empty. There is probably something about floats in the manual, though.
Read the GLOSSARY at the end of one of the floats files, e.g. floats_upwelling.in, in the External directory. It is quite comprehensive.
