I plan to calculate the value of vertical eddy viscosity —— Km. I wonder if ROMS could output this variable, or I have to calculate it by myself?
Thanks.
Hoty
Vertical eddy viscosity
- zhangtianhao
- 20201209165158.png (4.89 KiB) Viewed 6087 times
Re: Vertical eddy viscosity
I believe it is called Akv in the ROMS output.
- zhangtianhao
Kate,
Thanks for your reply. But I remember that the defination of Akv [Input] is vertical viscosity (ν in the picture below) but not vertical eddy viscosity (Km in the picture below) . I wonder that if Akv [Output] is the sum of background viscosity and eddy viscosity (Km + ν in the picture below)?
Hoty
It is the vertical viscosity used by the model, the sum of all the bits that go into it. The details depend on which vertical mixing scheme you are using.
- zhangtianhao
Kate,kate wrote: Thu Dec 10, 2020 5:08 pm It is the vertical viscosity used by the model, the sum of all the bits that go into it. The details depend on which vertical mixing scheme you are using.
Thanks, I will take a try.
Hoty
