Adding Sediment to the Latte Example
son-goku
#1 Unread post by son-goku »
Hi everyone
I am try set up the Latte case example, following instructions on the ROMS official web (https://www.myroms.org/wiki/CSTMS_UNSW2008) but, i can not download files from this link (http://coast-enviro.er.usgs.gov/models/Latte/). These files are necessary for executng this test case. Someone will have those files? or exist a detailed manual of a test case for sediment transport?
note
ROMS Upwelling is run correct on mi pc
it is my first time configuring a sediment-trasnport case.
i want configure a real case-> discharge sediment of a river on the ocean-coast and watch it move in the ocean... but firts i want configure a test-case to learn how to do it.
I will appreciate your help.
Re: Adding Sediment to the Latte Example
#2 Unread post by wilkin »
This is a very old example ... 2008! It needs updating to be useful with the present version of the code. One day I'll get to it.
#3 Unread post by jcwarner »
there are many other test cases to choose from. if you want to grab our version of the COAWST system, we distribute a rip current test, inlet test, etc. Most of them have sediment so there are several examples to choose from.
https://github.com/jcwarner-usgs/COAWST
son-goku
#4 Unread post by son-goku »
Thanks so much for your clarification. I will try to run some test case of COAWST.
Thanks so much again.
