2D case
logvinov
2D case
#1 Unread post by logvinov »
Hello all,
Could you tell me is it possible to run ROMS for 2D applications? So consider the problem only in z(vertical) and y(horizontal) coordinates. I am trying to do that to avoid instabilities.
Thanks a lot,
Evgeny
Yes, the UPWELLING case is such a beast. You can reduce Lm to maybe 3 and not change the results. UPWELLING is a periodic channel with EW_PERIODIC.
