Hi , i recently upgraded my ROMS code to SVN Revision 1036. But i get the following error when running RBL4DVAR simulation.
did i missed any changes in the inputs (.in) files ?
Found Error: ** Line: 140 Source: ROMS/Utility/def_var.F
DEF_VAR - Grid 01, unable to define variable: ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
in NetCDF file: ocean_mod.nc
Found Error: 03 Line: 1500 Source: ROMS/Utility/def_mod.F
Found Error: 03 Line: 213 Source: ROMS/Drivers/rbl4dvar.F
Found Error: 03 Line: 285 Source: ROMS/Drivers/rbl4dvar_ocean.h
Found Error: 03 Line: 53 Source: ROMS/Utility/close_io.F
Found Error: ** Line: 8657 Source: ROMS/Modules/mod_netcdf.F, netcdf_sync
NETCDF_SYNC - unable to synchronize to disk file:
ocean_mod.nc
call from: ROMS/Utility/close_io.F, close_out
NetCDF: Operation not allowed in define mode
RBL4DVAR error after upgrade to SVN Revision 1036
Re: RBL4DVAR error after upgrade to SVN Revision 1036
Try updating your varinfo.dat file.
Hi, thanks for your answer
Indeed i was using varinfo.dat coming with the test case (svn 999) instead of the one coming with the source code.
