Bug in initialization of Tobc_in and Tobc_out
m.hadfield
In ROMS 2.1, arrays Tobc_in and Tobc_out are allocated in subroutine initialize_scalars (mod_scalars.F lines 1263-1264) and written to netCDF output files in function wrt_info (wrt_info.F lines 608-632). They are given values in subroutine set_nudgcof_tile (set_nudgcof.F lines 552-665) but only for the boundaries on which the corresponding xxxx_TNUDGING option is defined. So there may be uninitialised values written to the output file. This can generates an error; whether this actually happens depends on how the compiler treats allocated, but uninitialised, variables and on how tolerant the netCDF library is.
One solution is to write Tobc_in and Tobc_out only for those boundaries where they are used. But this would be awkward, as each array is currently written to a single netCDF variable. The simpler solution is to initialise these arrays with zeros in initialize_scalars, eg. replace lines 1263-1264 in mod_scalars.F
      allocate ( Tobc_in(MT,Ngrids,4) )
      allocate ( Tobc_out(MT,Ngrids,4) )
with
      Tobc_in = IniVal
      Tobc_out = IniVal
#2 Unread post by arango »
Yes, this is a good solution.
Thank you, H
