My boundary condition is not working.
yz966445
#1 Unread post by yz966445 »
I am running the fennel biology model.
And my boundary condition for oxygen is not working. I am setting all the boundaries for oxygen to be 399.
And the log file shows that the model can read the value like :
GET_NGFLD - oxygen southern boundary condition, t = 12599 00:00:00
(Rec=0000001, Index=2, File: bc_201407_L3_R2R.nc)
(Tmin= 12599.0000 Tmax= 12631.5000)
(Min = 3.99000000E+02 Max = 3.99000000E+02)
However the results show me the oxygen boundary is not working. I have tried different BC condition (like Clamped). And I am using Rad + Nud right now.
I have checked the temperature and salinity boundaries, which are working fine.
Can anyone give me some clue? Or can anyone tell me where is the code for calculating the boundary? I would like to check it.
I very appreciate your help.
gresendiz
Re: My boundary condition is not working.
#2 Unread post by gresendiz »
Hello!
I hope I can help you a little.
Did you check that the oxygen was activated in the .h file? And, are you sure that the boundary configuration in the fennel.in file is correct?
I think, maybe something is wrong in one of this files. A doubt, how do you kmow that the results of the boundary isn't working, why is the value o what happens?
Good luck!
-GRC
Gabriela :)
CICESE
PhD student
#3 Unread post by wilkin »
Check the log file to verify you have radiation and nudging activated for oxygen on the correct boundaries. For example, my model shows Rad+Nad on my 3 open boundaries:
 oxygen                   1   Rad + Nud    Rad + Nud    Rad + Nud    Closed
Then check that the nudging time scales are sensible. They are in the output netcdf file:
	double Tobc_in(boundary, tracer) ;
		Tobc_in:long_name = "tracers inflow, nudging inverse time scale" ;
		Tobc_in:units = "second-1" ;
	double Tobc_out(boundary, tracer) ;
		Tobc_out:long_name = "tracers outflow, nudging inverse time scale" ;
		Tobc_out:units = "second-1" ;
so you can quickly get them using ncdump:
ncdump -v Tobc_in history_file.nc
ncdump -v Tobc_out history_file.nc
These will be grouped by boundary then tracer, so starting with "west" temp, salt, nitrate, ... then "south" temp, salt, nitrate ... so you'll need to count through to which one is oxygen to be sure it has the value you intended.
yz966445
#4 Unread post by yz966445 »
gresendiz wrote: Sun Jul 26, 2020 6:33 am Hello!
Good luck!
-GRC
Hi Gresendiz,
Thanks for your reply. Yes, the oxygen is activated. That is why I can get the O2 model results. I have read the log file. It looks like:
I think it looks alright.
I have done some tests. For example, I set up the initial condition for O2 is 200 everywhere. And I set up BC for O2 is 500 (or 0) everywhere.
I can not see anything along the boundary from the model results. However, I can see the change for other variable like T S when I setup these variables BC.
That is why I think the O2 boundary is not working. It looks like closed boundary condition.
yz966445
#5 Unread post by yz966445 »
wilkin wrote: Sun Jul 26, 2020 1:49 pm Check the log file to verify you have radiation and nudging activated for oxygen on the correct boundaries. For example, my model shows Rad+Nad on my 3 open boundaries:
Hi Wilkin,
I have checked the log files. The oxygen boundaries seems alright. It looks like:
oxygen 1 Clamped Rad + Nud Clamped Closed
(here, I have checked different BC, I alse checked Rad + Nud for 3 boundaries)
For the Tobc_in in his file, It looks likes (read from matlab):
>> TOBC=ncread('ocean_his0.nc','Tobc_in')
Tobc_in has the following dimensions (input order):
1) boundary = 4
2) tracer = 10
Tobc_in loaded into an array of size: [10 4]
TOBC =
1.0e-05 *
0.3858 0.3858 0.3858 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
I have just changed the time scale in bio_fennel.in file like:
! internally, [1:Ngrids].
TNUDG == 10*360.0d0 ! days
It was like ( TNUDG == 360.0d0 360.0d0 ! days).
!Problem solved! Ty so much!!
