I'm trying to do a one-way nesting on a refinement grid, and I got the following error. Does anyone have an idea what might this error correspond to?
At line 370 of file u2dbc_im.f90
Fortran runtime error: Index '-999' of dimension 1 of array 'ucontact%idg' below lower bound of 1
Error termination. Backtrace:
#0 0x10fd034 in __u2dbc_mod_MOD_u2dbc_tile
at /gpfs/projects/WilsonGroup/ROMS/OIB_nwn/Build_romsG/u2dbc_im.f90:370
#1 0xc42c32 in ini_fields_tile
at /gpfs/projects/WilsonGroup/ROMS/OIB_nwn/Build_romsG/ini_fields.f90:340
#2 0xc573a0 in __ini_fields_mod_MOD_ini_fields
at /gpfs/projects/WilsonGroup/ROMS/OIB_nwn/Build_romsG/ini_fields.f90:82
#3 0x40c53e in main3d_
at /gpfs/projects/WilsonGroup/ROMS/OIB_nwn/Build_romsG/main3d.f90:157
#4 0x407034 in __ocean_control_mod_MOD_roms_run
at /gpfs/projects/WilsonGroup/ROMS/OIB_nwn/Build_romsG/ocean_control.f90:180
#5 0x404ee6 in ocean
at /gpfs/projects/WilsonGroup/ROMS/OIB_nwn/Build_romsG/master.f90:108
#6 0x404f9e in main
at /gpfs/projects/WilsonGroup/ROMS/OIB_nwn/Build_romsG/master.f90:50
Does it means the connection file I use has problem? What is the best way to check that file? Or some other mistakes can also cause such error?
Thank you very much!
