Could I use some help from anyone on solving the following blow up problem?
I'm trying to forcing my model on three open boundaries. The model is at a relative shallow water region with the depth at around 4m, with the resolution of around 30m. I thought the blow up might be due the too small z-grid spacing, so I turned on the WET-DRY but it doesn't help much (if WET-DRY is off, it stops at the step of omega computation). I also tried to mask out all the places with the depth smaller than 0.2m but it still report a smallest z-grid spacing closer to zero.... Should I try even smaller time steps ? Smooth the bathymetry more ? Or there are some other obvious mistakes ?
Thank you very much
Tidal flow at OIB
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /gpfs/software/openmpi-3.0.0/bin/mpif90
Compiler flags : -frepack-arrays -g -fbounds-check -fbacktrace -fcheck=all -fsanitize=address -fsanitize=undefined -finit-real=nan -ffpe-trap=invalid,zero,overflow -
MPI Communicator : 0 PET size = 1
Input Script : roms_oib.in
SVN Revision : 1013
Local Root : /gpfs/projects/WilsonGroup/ROMS/trunk
Header Dir : /gpfs/projects/WilsonGroup/ROMS/OIB
Header file : roms_oib.h
Analytical Dir : /gpfs/projects/WilsonGroup/ROMS/OIB
Resolution, Grid 01: 153x208x5, Parallel Nodes: 1, Tiling: 1x1
200 ntimes Number of timesteps for 3-D equations.
27.940 dt Timestep size (s) for 3-D equations.
100 ndtfast Number of timesteps for 2-D equations between
200 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
5.0000E-06 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
0.0000E+00 theta_s S-coordinate surface control parameter.
1000.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
T VolCons(1) NLM western edge boundary volume conservation.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T VolCons(4) NLM northern edge boundary volume conservation.
of State.
Output Restart File: roms_rst.nc
Output History File: roms_his.nc
Input Grid File: /gpfs/projects/WilsonGroup/ROMS/OIB/ROMS_Grid1_msk02.nc
Input Nonlinear Initial File: /gpfs/projects/WilsonGroup/ROMS/OIB/oib_ini.nc
Input Boundary File: /gpfs/projects/WilsonGroup/ROMS/OIB/oib_obc.nc
ROMS I/O variables Metadata File: /gpfs/projects/WilsonGroup/ROMS/OIB/varinfo.dat
Tile partition information for Grid 01: 153x208x5 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 153 1 208 159120
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 153.50 0.50 208.50 RHO-points
0 1.00 153.00 0.50 208.50 U-points
0 0.50 153.50 1.00 208.00 V-points
HaloSizeI(1) = 326
HaloSizeJ(1) = 438
TileSide(1) = 213
TileSize(1) = 33441
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
salt 1 Upstream3 Centered4
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
zeta 1 Chapman Imp Chapman Imp Chapman Imp Closed
ubar 1 Flather Flather Flather Closed
vbar 1 Flather Flather Flather Closed
u 1 Radiation Radiation Radiation Closed
v 1 Radiation Radiation Radiation Closed
temp 1 Radiation Radiation Radiation Closed
salt 1 Radiation Radiation Radiation Closed
tke 1 Radiation Radiation Radiation Closed
roms_oib Tidal flow at OIB
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_BTFLUX Analytical kinematic bottom temperature flux
ANA_SMFLUX Analytical kinematic surface momentum flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ASSUMED_SHAPE Using assumed-shape arrays
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
GLS_MIXING Generic Length-Scale turbulence closure
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction
KANTHA_CLAYSON Kantha and Clayson stability function formulation
MASKING Land/Sea masking
MIX_S_UV Mixing of momentum along constant S-surfaces
MPI MPI distributed-memory configuration
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
N2S2_HORAVG Horizontal smoothing of buoyancy and shear
POWER_LAW Power-law shape time-averaging barotropic filter
PROFILE Time profiling activated
K_GSCHEME Third-order upstream advection of TKE fields
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine
RI_SPLINES Parabolic Spline Reconstruction for Richardson Number
!RST_SINGLE Double precision fields in restart NetCDF file
SOLVE3D Solving 3D Primitive Equations
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
SPHERICAL Spherical grid configuration
UV_QDRAG Quadratic bottom stress
UV_VIS2 Harmonic mixing of momentum
VAR_RHO_2D Variable density barotropic mode
WET_DRY Wetting and drying activated
Process Information:
Node # 0 (pid= 30370) is active.
GET_GRID - angle between XI-axis and EAST: angler
(Grid = 01, File: /gpfs/projects/WilsonGroup/ROMS/OIB/ROMS_Grid1_msk02.nc)
(Min = 3.63290745E-01 Max = 4.03162787E-01)
GET_GRID - bathymetry at RHO-points: h
(Min = 0.00000000E+00 Max = 1.15236203E+01)
GET_GRID - Coriolis parameter at RHO-points: f
(Min = 9.51175864E-05 Max = 9.52489999E-05)
GET_GRID - reciprocal XI-grid spacing: pm
(Min = 3.34922159E-02 Max = 3.40657003E-02)
GET_GRID - reciprocal ETA-grid spacing: pn
(Min = 3.26098114E-02 Max = 3.35705449E-02)
GET_GRID - longitude of RHO-points: lon_rho
(Min = -7.29389253E+01 Max = -7.28611025E+01)
GET_GRID - longitude of U-points: lon_u
(Min = -7.29387624E+01 Max = -7.28612654E+01)
GET_GRID - longitude of V-points: lon_v
(Min = -7.29388592E+01 Max = -7.28611687E+01)
GET_GRID - longitude of PSI-points: lon_psi
(Min = -7.29386963E+01 Max = -7.28613316E+01)
GET_GRID - latitude of RHO-points lat_rho
(Min = 4.07080613E+01 Max = 4.07762032E+01)
GET_GRID - latitude of U-points: lat_u
(Min = 4.07081139E+01 Max = 4.07761563E+01)
GET_GRID - latitude of V-points: lat_v
(Min = 4.07081897E+01 Max = 4.07760790E+01)
GET_GRID - latitude of PSI-points lat_psi
(Min = 4.07082423E+01 Max = 4.07760321E+01)
GET_GRID - mask on RHO-points: mask_rho
(Min = 0.00000000E+00 Max = 1.15000000E+02)
GET_GRID - mask on U-points: mask_u
(Min = 0.00000000E+00 Max = 1.17000000E+02)
GET_GRID - mask on V-points: mask_v
(Min = 0.00000000E+00 Max = 1.18000000E+02)
GET_GRID - mask on PSI-points: mask_psi
5 0.0000000 0.0000000 0.000 0.000 0.000 0.000
4 -0.2000000 -0.2000000 -0.000 -2.305 -1.152 -2.305
3 -0.4000000 -0.4000000 -0.000 -4.609 -2.305 -4.609
2 -0.6000000 -0.6000000 -0.000 -6.914 -3.457 -6.914
1 -0.8000000 -0.8000000 -0.000 -9.219 -4.609 -9.219
0 -1.0000000 -1.0000000 -0.000 -11.524 -5.762 -11.524
Time Splitting Weights for Grid 01: ndtfast = 100 nfast = 136
1-0.0001594457047350 0.0100000000000000-0.0001594457047350 0.0100000000000000
2-0.0003102043539850 0.0100015944570474-0.0004696500587199 0.0200015944570474
3-0.0004522759527012 0.0100046965005872-0.0009219260114211 0.0300062909576346
4-0.0005856605201383 0.0100092192601142-0.0015075865315594 0.0400155102177488
5-0.0007103581063581 0.0100150758653156-0.0022179446379175 0.0500305860830644
6-0.0008263688153356 0.0100221794463792-0.0030443134532531 0.0600527655294436
7-0.0009336928346655 0.0100304431345325-0.0039780062879186 0.0700832086639761
8-0.0010323304718712 0.0100397800628792-0.0050103367597898 0.0801229887268553
9-0.0011222821973150 0.0100501033675979-0.0061326189571048 0.0901730920944532
10-0.0012035486937100 0.0100613261895711-0.0073361676508149 0.1002344182840242
11-0.0012761309122332 0.0100733616765082-0.0086122985630481 0.1103077799605324
12-0.0013400301352409 0.0100861229856305-0.0099523286982890 0.1203939029461629
13-0.0013952480455848 0.0100995232869829-0.0113475767438738 0.1304934262331457
14-0.0014417868025304 0.0101134757674387-0.0127893635464042 0.1406069020005845
15-0.0014796491242768 0.0101278936354640-0.0142690126706810 0.1507347956360485
16-0.0015088383770778 0.0101426901267068-0.0157778510477588 0.1608774857627553
17-0.0015293586709646 0.0101577785104776-0.0173072097187234 0.1710352642732329
18-0.0015412149620705 0.0101730720971872-0.0188484246807939 0.1812083363704202
19-0.0015444131615570 0.0101884842468079-0.0203928378423509 0.1913968206172281
20-0.0015389602511410 0.0102039283784235-0.0219317980934918 0.2016007489956516
21-0.0015248644052242 0.0102193179809349-0.0234566624987160 0.2118200669765865
22-0.0015021351196239 0.0102345666249872-0.0249587976183399 0.2220546336015737
23-0.0014707833469051 0.0102495879761834-0.0264295809652450 0.2323042215777571
24-0.0014308216383147 0.0102642958096525-0.0278604026035597 0.2425685173874096
25-0.0013822642923165 0.0102786040260356-0.0292426668958762 0.2528471214134452
26-0.0013251275097287 0.0102924266689588-0.0305677944056049 0.2631395480824039
27-0.0012594295554622 0.0103056779440561-0.0318272239610671 0.2734452260264600
28-0.0011851909268611 0.0103182722396107-0.0330124148879281 0.2837634982660707
29-0.0011024345286441 0.0103301241488793-0.0341148494165722 0.2940936224149500
30-0.0010111858544481 0.0103411484941657-0.0351260352710203 0.3044347709091157
31-0.0009114731749732 0.0103512603527102-0.0360375084459935 0.3147860312618259
32-0.0008033277327288 0.0103603750844599-0.0368408361787224 0.3251464063462858
33-0.0006867839433822 0.0103684083617872-0.0375276201221045 0.3355148147080730
34-0.0005618796037077 0.0103752762012210-0.0380894997258122 0.3458900909092941
35-0.0004286561061383 0.0103808949972581-0.0385181558319504 0.3562709859065522
36-0.0002871586599182 0.0103851815583195-0.0388053144918686 0.3666561674648717
37-0.0001374365188575 0.0103880531449187-0.0389427510107261 0.3770442206097904
38 0.0000204567843123 0.0103894275101073-0.0389222942264138 0.3874336481198977
39 0.0001864631969805 0.0103892229422641-0.0387358310294334 0.3978228710621618
40 0.0003605198990979 0.0103873583102943-0.0383753111303355 0.4082102293724562
41 0.0005425590490165 0.0103837531113034-0.0378327520813190 0.4185939824837595
42 0.0007325075227271 0.0103783275208132-0.0371002445585919 0.4289723100045727
43 0.0009302866464954 0.0103710024455859-0.0361699579120965 0.4393433124501586
44 0.0011358119228966 0.0103616995791210-0.0350341459891999 0.4497050120292796
45 0.0013489927502484 0.0103503414598920-0.0336851532389515 0.4600553534891716
46 0.0015697321354425 0.0103368515323895-0.0321154211035089 0.4703922050215611
47 0.0017979264001745 0.0103211542110351-0.0303174947033344 0.4807133592325962
48 0.0020334648805720 0.0103031749470333-0.0282840298227624 0.4910165341796295
49 0.0022762296202215 0.0102828402982276-0.0260078002025408 0.5012993744778572
50 0.0025260950565934 0.0102600780020254-0.0234817051459475 0.5115594524798827
51 0.0027829277008656 0.0102348170514595-0.0206987774450819 0.5217942695313421
52 0.0030465858111454 0.0102069877744508-0.0176521916339365 0.5320012573057930
53 0.0033169190590902 0.0101765219163394-0.0143352725748463 0.5421777792221323
54 0.0035937681899259 0.0101433527257485-0.0107415043849203 0.5523211319478808
55 0.0038769646758645 0.0101074150438492-0.0068645397090558 0.5624285469917299
56 0.0041663303629196 0.0100686453970906-0.0026982093461362 0.5724971923888205
57 0.0044616771111203 0.0100269820934614 0.0017634677649840 0.5825241744822818
58 0.0047628064281242 0.0099823653223502 0.0065262741931082 0.5925065398046320
59 0.0050695090962281 0.0099347372580689 0.0115957832893363 0.6024412770627009
60 0.0053815647927771 0.0098840421671066 0.0169773480821135 0.6123253192298075
61 0.0056987417039731 0.0098302265191789 0.0226760897860865 0.6221555457489863
62 0.0060207961320800 0.0097732391021391 0.0286968859181665 0.6319287848511255
63 0.0063474720960293 0.0097130311408183 0.0350443580141958 0.6416418159919438
64 0.0066785009254227 0.0096495564198580 0.0417228589396184 0.6512913724118019
65 0.0070136008479335 0.0095827714106038 0.0487364597875519 0.6608741438224057
66 0.0073524765701069 0.0095126354021245 0.0560889363576588 0.6703867792245302
67 0.0076948188515579 0.0094391106364234 0.0637837552092167 0.6798258898609536
68 0.0080403040725683 0.0093621624479078 0.0718240592817850 0.6891880523088615
69 0.0083885937950820 0.0092817594071822 0.0802126530768670 0.6984698117160436
70 0.0087393343170983 0.0091978734692313 0.0889519873939653 0.7076676851852749
71 0.0090921562204639 0.0091104801260603 0.0980441436144293 0.7167781653113352
72 0.0094466739120640 0.0090195585638557 0.1074908175264932 0.7257977238751909
73 0.0098024851584102 0.0089250918247351 0.1172933026849035 0.7347228156999260
74 0.0101591706136288 0.0088270669731510 0.1274524732985322 0.7435498826730770
75 0.0105162933408455 0.0087254752670147 0.1379687666393777 0.7522753579400917
76 0.0108733983269705 0.0086203123336062 0.1488421649663483 0.7608956702736980
77 0.0112300119908805 0.0085115783503365 0.1600721769572288 0.7694072486240345
78 0.0115856416849999 0.0083992782304277 0.1716578186422287 0.7778065268544623
79 0.0119397751902801 0.0082834218135777 0.1835975938325088 0.7860899486680401
80 0.0122918802045775 0.0081640240616749 0.1958894740370863 0.7942539727297150
81 0.0126414038244295 0.0080411052596291 0.2085308778615158 0.8022950779893441
82 0.0129877720202296 0.0079146912213848 0.2215186498817454 0.8102097692107290
83 0.0133303891048003 0.0077848135011826 0.2348490389865456 0.8179945827119115
84 0.0136686371953643 0.0076515096101345 0.2485176761819100 0.8256460923220460
85 0.0140018756689153 0.0075148232381809 0.2625195518508252 0.8331609155602269
86 0.0143294406109853 0.0073748044814918 0.2768489924618106 0.8405357200417186
87 0.0146506442578125 0.0072315100753819 0.2914996367196231 0.8477672301171005
88 0.0149647744319058 0.0070850036328038 0.3064644111515289 0.8548522337499043
89 0.0152710939710086 0.0069353558884847 0.3217355051225375 0.8617875896383890
90 0.0155688401504611 0.0067826449487746 0.3373043452729986 0.8685702345871636
91 0.0158572240989606 0.0066269565472700 0.3531615693719592 0.8751971911344336
92 0.0161354302077207 0.0064683843062804 0.3692969995796799 0.8816655754407140
93 0.0164026155330280 0.0063070300042032 0.3856996151127079 0.8879726054449172
94 0.0166579091921988 0.0061430038488729 0.4023575243049067 0.8941156092937901
95 0.0169004117529325 0.0059764247569509 0.4192579360578392 0.9000920340507410
96 0.0171291946160649 0.0058074206394216 0.4363871306739041 0.9058994546901626
97 0.0173432993917185 0.0056361286932610 0.4537304300656226 0.9115355833834236
98 0.0175417372688526 0.0054626956993438 0.4712721673344752 0.9169982790827673
99 0.0177234883782110 0.0052872783266553 0.4889956557126862 0.9222855574094225
100 0.0178875011486682 0.0051100434428731 0.5068831568613544 0.9273956008522957
101 0.0180326916569743 0.0049311684313865 0.5249158485183287 0.9323267692836821
102 0.0181579429708980 0.0047508415148167 0.5430737914892267 0.9370776107984988
103 0.0182621044857684 0.0045692620851077 0.5613358959749951 0.9416468728836066
104 0.0183439912544149 0.0043866410402501 0.5796798872294100 0.9460335139238567
105 0.0184023833105056 0.0042032011277059 0.5980822705399156 0.9502367150515626
106 0.0184360249852842 0.0040191772946008 0.6165182955251998 0.9542558923461635
107 0.0184436242177053 0.0038348170447480 0.6349619197429051 0.9580907093909115
108 0.0184238518579681 0.0036503808025710 0.6533857716008732 0.9617410901934824
109 0.0183753409644487 0.0034661422839913 0.6717611125653219 0.9652072324774736
110 0.0182966860940303 0.0032823888743468 0.6900577986593522 0.9684896213518204
111 0.0181864425858324 0.0030994220134065 0.7082442412451847 0.9715890433652269
112 0.0180431258383383 0.0029175575875482 0.7262873670835230 0.9745066009527751
113 0.0178652105799207 0.0027371263291648 0.7441525776634437 0.9772437272819399
114 0.0176511301327661 0.0025584742233656 0.7618037077962098 0.9798022015053054
115 0.0173992756701974 0.0023819629220379 0.7792029834664072 0.9821841644273432
116 0.0171079954673952 0.0022079701653359 0.7963109789338024 0.9843921345926792
117 0.0167755941455171 0.0020368902106620 0.8130865730793195 0.9864290248033412
118 0.0164003319092156 0.0018691342692068 0.8294869049885351 0.9882981590725479
119 0.0159804237775546 0.0017051309501147 0.8454673287660897 0.9900032900226625
120 0.0155140388083243 0.0015453267123391 0.8609813675744140 0.9915486167350016
121 0.0149992993157544 0.0013901863242559 0.8759806668901684 0.9929388030592575
122 0.0144342800816253 0.0012401933310983 0.8904149469717937 0.9941789963903559
123 0.0138170075597788 0.0010958505302821 0.9042319545315725 0.9952748469206379
124 0.0131454590740262 0.0009576804546843 0.9173774136055987 0.9962325273753222
125 0.0124175620094554 0.0008262258639440 0.9297949756150540 0.9970587532392662
126 0.0116311929971360 0.0007020502438495 0.9414261686121900 0.9977608034831157
127 0.0107841770922234 0.0005857383138781 0.9522103457044133 0.9983465417969938
128 0.0098742869454606 0.0004778965429559 0.9620846326498740 0.9988244383399496
129 0.0088992419680793 0.0003791536735013 0.9709838746179533 0.9992035920134509
130 0.0078567074900984 0.0002901612538205 0.9788405821080517 0.9994937532672713
131 0.0067442939120218 0.0002115941789195 0.9855848760200735 0.9997053474461908
132 0.0055595558499342 0.0001441512397993 0.9911444318700077 0.9998494986859900
133 0.0042999912739953 0.0000885556812999 0.9954444231440029 0.9999380543672900
134 0.0029630406403327 0.0000455557685600 0.9984074637843356 0.9999836101358500
135 0.0015460860163330 0.0000159253621566 0.9999535498006686 0.9999995354980067
136 0.0000464501993315 0.0000004645019933 1.0000000000000002 1.0000000000000000
ndtfast, nfast = 100 136 nfast/ndtfast = 1.36000
1.000000000000 1.019196655660 0.509598327830 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.25560
Minimum X-grid spacing, DXmin = 2.93550402E-02 km
Maximum X-grid spacing, DXmax = 2.98576841E-02 km
Minimum Y-grid spacing, DYmin = 2.97880182E-02 km
Maximum Y-grid spacing, DYmax = 3.06656174E-02 km
Minimum Z-grid spacing, DZmin = 2.00000000E-15 m
Maximum Z-grid spacing, DZmax = 2.30472405E+00 m
Minimum barotropic Courant Number = 1.38959712E-02
Maximum barotropic Courant Number = 1.40755645E-01
Maximum Coriolis Courant Number = 2.66097292E-03
NLM: GET_STATE - Reading state initial conditions, 0001-01-01 00:00:00.00
(Grid 01, t = 0.0000, File: oib_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = 0.00000000E+00 Max = 4.42551112E-02)
- u-momentum component
- v-momentum component
- potential temperature
(Min = 0.00000000E+00 Max = 6.90543909E+00)
- salinity
(Min = 0.00000000E+00 Max = 3.17981322E+01)
GET_NGFLD - free-surface western boundary condition, 0001-01-01 00:00:00.00
(Grid= 01, Rec=0000001, Index=2, File: oib_obc.nc)
(Tmin= 0.0000 Tmax= 0.0747) t = 0.0000
GET_NGFLD - free-surface eastern boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD - free-surface southern boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD - 2D u-momentum western boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD - 2D v-momentum western boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD - 2D u-momentum eastern boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD - 2D v-momentum eastern boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD - 2D u-momentum southern boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD - 2D v-momentum southern boundary condition, 0001-01-01 00:00:00.00
Maximum grid stiffness ratios: rx0 = 2.000000E-01 (Beckmann and Haidvogel)
rx1 = 1.800000E+00 (Haney)
Initial domain volumes: TotVolume = 4.6410819004E+07 m3
MinCellVol = 2.0581743846E+01 m3
MaxCellVol = 1.9942072251E+03 m3
Max/Min = 9.6892043744E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000000200)
GET_NGFLD - free-surface western boundary condition, 0001-01-01 00:00:28.00
(Grid= 01, Rec=0000002, Index=1, File: oib_obc.nc)
(Tmin= 0.0000 Tmax= 0.0747) t = 0.0003
(Min = -3.78718571E-04 Max = 4.12897236E-04)
GET_NGFLD - free-surface eastern boundary condition, 0001-01-01 00:00:28.00
(Min = -1.45746730E-04 Max = 1.80724703E-04)
GET_NGFLD - free-surface southern boundary condition, 0001-01-01 00:00:28.00
(Min = -1.05794905E-04 Max = -9.69371904E-05)
GET_NGFLD - 2D u-momentum western boundary condition, 0001-01-01 00:00:28.00
(Min = 0.00000000E+00 Max = 8.99481820E-04)
GET_NGFLD - 2D v-momentum western boundary condition, 0001-01-01 00:00:28.00
(Min = -1.26960198E-03 Max = 2.68548756E-04)
GET_NGFLD - 2D u-momentum eastern boundary condition, 0001-01-01 00:00:28.00
(Min = 0.00000000E+00 Max = 1.17361650E-03)
GET_NGFLD - 2D v-momentum eastern boundary condition, 0001-01-01 00:00:28.00
(Min = -4.89090860E-04 Max = 6.61526399E-04)
GET_NGFLD - 2D u-momentum southern boundary condition, 0001-01-01 00:00:28.00
(Min = 4.77489593E-05 Max = 8.93098040E-05)
GET_NGFLD - 2D v-momentum southern boundary condition, 0001-01-01 00:00:28.00
(Min = -6.63306419E-05 Max = -1.19462557E-05)
0 0001-01-01 00:00:00.00 NaN NaN NaN NaN
(000,000,0) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
Found Error: 01 Line: 299 Source: ROMS/Drivers/nl_ocean.h
Elapsed CPU time (seconds):
Node # 0 CPU: 1.322
Total: 1.322
Allocation and array initialization .............. 0.750 (56.6932 %)
Ocean state initialization ....................... 0.106 ( 7.9971 %)
Reading of input data ............................ 0.042 ( 3.1753 %)
Processing of input data ......................... 0.002 ( 0.1478 %)
Computation of global information integrals ...... 0.069 ( 5.2499 %)
2D/3D coupling, vertical metrics ................. 0.066 ( 5.0200 %)
Omega vertical velocity .......................... 0.017 ( 1.2578 %)
Equation of state for seawater ................... 0.078 ( 5.8947 %)
Reading model state vector ....................... 0.066 ( 5.0137 %)
Total: 1.196 90.4493
Message Passage: 2D halo exchanges ............... 0.000 ( 0.0227 %)
Message Passage: 3D halo exchanges ............... 0.000 ( 0.0091 %)
Message Passage: 4D halo exchanges ............... 0.000 ( 0.0016 %)
Message Passage: data broadcast .................. 0.001 ( 0.0829 %)
Message Passage: data reduction .................. 0.000 ( 0.0053 %)
Message Passage: data scattering.................. 0.028 ( 2.0892 %)
Message Passage: boundary data gathering ......... 0.000 ( 0.0041 %)
Message Passage: synchronization barrier ......... 0.000 ( 0.0011 %)
Total: 0.029 2.2160
Unique code regions profiled ..................... 1.196 90.4493 %
Residual, non-profiled code ...................... 0.126 9.5507 %
All percentages are with respect to total time = 1.322
Dynamic and Automatic memory (MB) usage for Grid 01: 153x208x5 tiling: 1x1
tile Dynamic Automatic USAGE MPI-Buffers
0 81.59 11.46 93.06 1.30
TOTAL 81.59 11.46 93.06 1.30
Found Error: 01 Line: 68 Source: ROMS/Utility/close_io.F
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
Found Error: 01 Line: 333 Source: ROMS/Utility/close_io.F
