calculating ubar and vbar
I want to calculate ubar and vbar using u and v. Is it calculated using following formula,
ubar = ubar + u*dz
vbar = vbar + v*dz
but in this case the units of the 2d vertical integrated momentum component will be m2/s (m/s * m) because we multiply with the thickness of the layer. In climatology package the unit of ubar and vbar is in m/s. Which one is correct? May be the formula is wrong and you can provide me the correct one.
ubar = ubar + u*dz
vbar = vbar + v*dz
Re: calculating ubar and vbar
In step3d_uv:
CF = CF + Hz
DC = DC + u*Hz
ubar = DC/CF (more or less)
CF = CF + Hz
DC = DC + u*Hz
hi,
is there any update of calculatung ubar and vbar by u and v?
or is there any recommendation for me to refer to?
thank you
thank you
Look at Nonlinear/ini_fields.F instead. It is very clear how it is computed there. It is how the inital ubar anf vbar is computed in ROMS.
Sorry, I think I am going to ask some silly questions since I am not that understand the flow.
Currently, I have download data like zeta, u v current, temp and salinity from MERCATER, yet some error occur when I used the mercator2roms.m.
Since I am not a MATLAB expert, I decided to rewrite the script using python.
However, I meet some problem in understanding the calcutation in ubar and vbar.
When look into the script INI_FIELD.F, I wonder will ROMS calculate ubar and vbar itself if the initial file contains u and v data.
How should I modified my header file if so.
Thank you very much.
To make it clear, here is the error when I tried to convert MERCATOR to ROMS initial file.
However, I cannot upload my nc file even after zipping it.
In an assignment A(:) = B, the number of elements in A and
B must be the same.
Error in mercator2roms (line 188)
Fwork(indnan(m))=Fwork(indwet(near));
Error in d_mercator2roms_update (line 225)
temp=mercator2roms('temp',S,Temp,Tlon,Tlat,Rmask3d,Tdepth);
Error in run (line 96)
evalin('caller', [script ';']);
Thank you.
B must be the same.
Thank you.
- grid13_gebco_smooth4.nc
- (64 KiB) Downloaded 834 times
d_mercator2roms_update.m
- (11.14 KiB) Downloaded 679 times
mercator2roms.m
- (6.4 KiB) Downloaded 845 times
To update, the error has been solved.
Yet , when I used the new initial file, a new error popped up.
Please have a look if you have any idea to solve it. Thank you.
temp.txt
- (56.85 KiB) Downloaded 849 times
144 1 00:00:00 NaN NaN NaN 5.758336E+16
(163,187,19) 2.195484E-02 1.405542E-02 0.000000E+00 1.002493E+00
Thank you for your reply.
I have solved it by using ANA_INITIAL in my header file.
I'd like to clarify what you meant as you seemed to be using an initial condition file earlier. So instead of using an initial condition file, you edited ana_initial.h to input your desired initial conditions?venuscheung wrote: Wed Dec 25, 2019 6:08 am Thank you for your reply.
yes, I put ana_initial in my header file, yet the result show that the model seems starting from a new initial condition that salinity = 35 and sst = 17.lcbernardo wrote: Thu Dec 26, 2019 7:18 amI'd like to clarify what you meant as you seemed to be using an initial condition file earlier. So instead of using an initial condition file, you edited ana_initial.h to input your desired initial conditions?venuscheung wrote: Wed Dec 25, 2019 6:08 am Thank you for your reply.
should use other initial condition instead of ana_initial
