Adding variables to history and averages files
I am trying to add some new variables to the history and averages files, but am running into a snag. Below I will post the name of the file I modified, and what I added, shortened to a single variable only, even though I am adding a total of 5. The error, I believe, is that it is not reading in the "T" in the .in file to write out the variables (presumably this should be done in inp_par.F) I tried to copy the syntax used for other variables within the files. I didn't delete my debuging write statements for this. If anyone can point to why I get this error, and anything else that looks wrong that would be a great help. It looks like my tabs didn't copy over correctly, and a part of the code is short for a smiley.
The error is below, and comes directly after it starts definining the history file after step zero.
oceanS: string.c:42: NC_check_name: Assertion `name != ((void *)0)' failed.
Aborted
This write statement in def_his.F comes back with zeros for the variables.
write(6,*) 'hisVid', hisVid(idCwbl,ng), idCwbl
def_his.F
#ifdef WBLGRAV_HTG
! Define wbl variables
write(6,*) 'made here 1'
IF (Hout(idCwbl,ng)) THEN
Vinfo( 1)=Vname(1,idCwbl)
Vinfo( 2)=Vname(2,idCwbl)
Vinfo( 3)=Vname(3,idCwbl)
Vinfo(14)=Vname(4,idCwbl)
Vinfo(16)=Vname(1,idtime)
# if defined WRITE_WATER && defined MASKING
Vinfo(20)='mask_rho'
Vinfo(22)='coordinates'
Aval(5)=REAL(Iinfo(1,idCwbl,ng),r8)
write(6,*) 'made here 2'
status=def_var(ncHISid(ng),hisVid(idCwbl,ng),NF_FOUT, &
& nvd3,t2dgrd,Aval,Vinfo,ncname)
#ifdef WBLGRAV_HTG
IF (TRIM(varnam(i)).eq.TRIM(Vname(1,idCwbl))) THEN
got_var(idCwbl)=.TRUE.
status=nf90_inq_varid(ncHISid(ng), &
& TRIM(Vname(1,idCwbl)), &
& hisVid(idCwbl,ng))
#ifdef WBLGRAV_HTG
IF (.not.got_var(idCwbl).and.Hout(idCwbl,ng)) THEN
WRITE (stdout,60) TRIM(Vname(1,idCwbl)), TRIM(ncname)
exit_flag=3
RETURN
END IFC
wrt_his.F
#ifdef WBLGRAV_HTG
! Write out wave boundary layer gravity flow variables.
! CsedW,Uwbl,Vwbl,Ri
write(6,*) idCwbl, idWdir
write(6,*) 'made it into CsedW writing loop'
scale=1.0_r8
gtype=gfactor*r2dvar
status=nf_fwrite2d(ng, iNLM, ncHISid(ng), hisVid(idCwbl,ng), &
& tHISindx(ng), gtype, &
& LBi, UBi, LBj, UBj, scale, &
# ifdef MASKING
& GRID(ng) % rmask(LBi,LBj), &
& OCEAN(ng) % CsedW(LBi,LBj,NST))
IF (status.ne.nf90_noerr) THEN
IF (Master) THEN
WRITE (stdout,10) TRIM(Vname(1,idCwbl)), tHISindx(ng)
exit_flag=3
ioerror=status
RETURN
inp_par.F
It looks like I was unsure of this part since I added some and then commented it out, should it be there?
#ifdef WBLGRAV_HTG
write(6,*) 'idCwbl', idCwbl
ELSE IF (TRIM(KeyWord).eq.'Hout(idCwbl)') THEN
! IF (idCwbl.eq.0) THEN
! WRITE (out,280) 'idCwbl'
! STOP
! END IF
Npts=load_l(Nval, Cval, Ngrids, Hout(idCwbl,1))
#ifdef WBLGRAV_HTG
IF (Hout(idCwbl,ng)) WRITE (out,170) Hout(idCwbl,ng), &
& 'Hout(idCwbl)', &
& 'WBL concentration'
mod_ncparam.F
#ifdef WBLGRAV_HTG
integer :: idCwbl ! Wave boundary layer sediment concentration
#ifdef WBLGRAV_HTG
CASE ('idCwbl')
idCwbl=varid
write(6,*) 'after1', idCwbl
varinfo.dat
'CsedW' ! Output
'sediment concentration in the wbl'
'kg m-3'
'wbl concentration,scalar'
'ocean_time'
'idCwbl'
'r2dvar'
1.0d0
ocean_main.in (we are actually modifying ocean_riverplume2.in)
Hout(idCwbl) == T ! wbl sediment concentration
Aborted
def_his.F
#ifdef WBLGRAV_HTG
#ifdef WBLGRAV_HTG
#ifdef WBLGRAV_HTG
exit_flag=3
RETURN
END IFC
wrt_his.F
#ifdef WBLGRAV_HTG
scale=1.0_r8
# ifdef MASKING
IF (Master) THEN
exit_flag=3
ioerror=status
RETURN
inp_par.F
#ifdef WBLGRAV_HTG
! STOP
! END IF
#ifdef WBLGRAV_HTG
& 'Hout(idCwbl)', &
mod_ncparam.F
#ifdef WBLGRAV_HTG
#ifdef WBLGRAV_HTG
CASE ('idCwbl')
idCwbl=varid
varinfo.dat
'CsedW' ! Output
'kg m-3'
'ocean_time'
'idCwbl'
'r2dvar'
1.0d0
So space things out using multiple spaces? What breaks from hitting tab instead?
oceanG gives me
At line 618 of file inp_par.f90
Traceback: (Innermost first)
Called from line 58 of file inp_par.f90
Called from line 80 of file ocean_control.f90
Called from line 67 of file master.f90
Fortran runtime error: Array element out of bounds: 0 in (1:500), dim=1
line 618, and those around it, are
! STOP
! END IF
Npts=load_l(Nval, Cval, Ngrids, Hout(idCwbl,1)) ( line 618 )
write(6,*) 'idCwbl, Npts', idCwbl, Npts
This was commented out because I got the 280 error, which is
280 FORMAT (/,' READ_PHYPAR - variable info not yet loaded, ', a)
oceanG gives me
! STOP
! END IF
well, that is your problem.
Your problem is that idCwbl = 0.
In inp_par, it is trying to put a value in
so it is trying to put a value into Hout(0,1) but Hout is from (1:500,1).
So that will not work.
So the million dollar question is "why is idCwbl = 0 ??"
In mod_ncparam, in the subroutien initialize_ncparam, you added:
#ifdef WBLGRAV_HTG
CASE ('idCwbl')
idCwbl=varid
You said it "doesn't get that far", but it actually has gone that far and beyond it. Inp_par calls initialize_ncparam, and so idCwbl should get a value. Edit mod_ncparam, look for :
CASE ('idCwbl')
idCwbl=varid
Is it really in the *.f90 ??
#ifdef WBLGRAV_HTG
CASE ('idCwbl')
idCwbl=varid
CASE ('idCwbl')
idCwbl=varid
Yes it is in the mod_ncparam.f90, but it looks like the left hand side is not lined up with the rest of the code, it is off by one space, which is where emacs tabs it to. Is the tab breaking it? Why wasn't I supposed to use a tab?
And yes it is in varinfo.dat
varinfo.dat
'CsedW' ! Output
'kg m-3'
'ocean_time'
'idCwbl'
'r2dvar'
1.0d0
varinfo.dat
'CsedW' ! Output
'kg m-3'
'ocean_time'
'idCwbl'
'r2dvar'
1.0d0
Aaron -
Whether emacs enters a tab or spaces is determined by the mode you're in. Opening a .F or .f90 file should put you in Fortran or F90 mode automatically. When you hit tab in this mode, emacs should indent appropriately and spaces, not a tab, should be entered. Also, opening the .h files should put you in Obj C (I think...) mode, which (I think...) also puts in spaces. The indentation won't be right in this mode, unless you change to fortran or f90 mode.
When editing the .in files, however, you'll be in Fundamental mode which DOES enter tabs. I've had ROMS choke a number of times because of this...
To see whether you have blanks or tabs in emacs you can use this minor-mode: http://www.emacswiki.org/cgi-bin/emacs/ ... nk-mode.el
Good Luck
Good Luck
This question keeps coming again and again. I added a useful information to WikiROMS detailing how to do this. Check FAQ menu:
https://www.myroms.org/wiki/index.php/F ... _Questions
It is not a good idea to include TABS to any of ROMS code. This should be avoided at all cost
We have several code processing scripts that are affected by TABS and will give surprising results. As a matter of code style, TABS are not recommended. Many modern codes do not allow TABS.
Re: Adding variables to history and averages files
I'm fairly certain my problem is not related to tabs, since I've added variables before with no problems. But I am now trying to split the ubar_hadv diagnostic into the u*du/dx and v*du/dy terms, add them as idDu2d variables, and having the same problem reported above. I'm sure it's a silly error, but I've spent two days troubleshooting and can't see what I'm doing wrong.
The cryptic "order is important" note in mod_scalars may be part of the issue. I've checked that NDM2d is larger by 2 in all routines.
I added a cppdef called M2HADV_SEP, and my modifications to mod_param.F, mod_scalars.F, mod_ncparam.F, and varinfo.dat are shown below. I removed my additions to step2d_LF_AM3.h for the two terms, it is my understanding that the arrays would be initialized with zeros anyway.
In mod_param.F
In mod_ncparam.F
In mod_scalars.F
In mod_scalars.F
In varinfo.dat
And this is the error, which occurs while the diagnostic file is being created. The file is unreadable by ncdump or otherwise.
Any advice is appreciated, thanks...
In mod_param.F
ifdef DIAGNOSTICS_UV
! 2D Momentum diagnostics.
NDM2d=4 ! Acceleration, 2D P-Gradient, stresses
# ifdef UV_ADV
NDM2d=NDM2d+1 ! Horizontal advection
# ifdef NEARSHORE_MELLOR
NDM2d=NDM2d+1 ! Horizontal radiation stresses
# ifdef UV_COR
NDM2d=NDM2d+1 ! Coriolis
# if defined UV_VIS2 || defined UV_VIS4
NDM2d=NDM2d+1 ! Horizontal viscosity
# ifdef M2HADV_SEP
NDM2d=NDM2d+2 ! two hadv components
#ifdef DIAGNOSTICS_UV
CASE ('idDu2d(M2pgrd)')
idDu2d(M2pgrd)=varid
CASE ('idDv2d(M2pgrd)')
idDv2d(M2pgrd)=varid
CASE ('idDu2d(M2sstr)')
idDu2d(M2sstr)=varid
CASE ('idDu2d(M2bstr)')
idDu2d(M2bstr)=varid
CASE ('idDv2d(M2sstr)')
idDv2d(M2sstr)=varid
CASE ('idDv2d(M2bstr)')
idDv2d(M2bstr)=varid
CASE ('idDu2d(M2rate)')
idDu2d(M2rate)=varid
CASE ('idDv2d(M2rate)')
idDv2d(M2rate)=varid
# ifdef UV_ADV
CASE ('idDu2d(M2hadv)')
idDu2d(M2hadv)=varid
CASE ('idDv2d(M2hadv)')
idDv2d(M2hadv)=varid
CASE ('idDu2d(M2hrad)')
idDu2d(M2hrad)=varid
CASE ('idDv2d(M2hrad)')
idDv2d(M2hrad)=varid
# ifdef UV_COR
CASE ('idDu2d(M2fcor)')
idDu2d(M2fcor)=varid
CASE ('idDv2d(M2fcor)')
idDv2d(M2fcor)=varid
CASE ('idDu2d(M2hvis)')
idDu2d(M2hvis)=varid
CASE ('idDv2d(M2hvis)')
idDv2d(M2hvis)=varid
# ifdef M2HADV_SEP
CASE ('idDu2d(M2hadx)')
idDu2d(M2hadx)=varid
CASE ('idDu2d(M2hady)')
idDu2d(M2hady)=varid
# ifdef DIAGNOSTICS_UV
integer :: M2pgrd ! 2D momentum, pressure gradient
integer :: M2fcor ! 2D momentum, Coriolis
integer :: M2rate ! 2D momentum, time rate of change
integer :: M2hadv ! 2D momentum, horizontal advection
integer :: M2hrad ! 2D momentum, horizontal stresses
integer :: M2hvis ! 2D momentum, horizontal viscosity
integer :: M2sstr ! 2D momentum, surface stress
integer :: M2bstr ! 2D momentum, bottom stress
# ifdef M2HADV_SEP
integer :: M2hadx ! 2D momentum, h. adv uux comp.
integer :: M2hady ! 2D momentum, h. adv vuy comp.
! Indices for 2D momentum diagnostic variables.
! Order is important!
M2pgrd=1
ic=1
# if defined UV_COR
M2fcor=ic+1
ic=ic+1
# if defined UV_ADV
M2hadv=ic+1
ic=ic+1
# if defined NEARSHORE_MELLOR
M2hrad=ic+1
ic=ic+1
M2sstr=ic+1
ic=ic+1
M2bstr=ic+1
M2hvis=ic+2
# if defined M2HADV_SEP
M2hadx=ic+3
M2hady=ic+4
M2rate=NDM2d
'ubar_uux' ! Input/Output
'2D u-momentum, hadv uux term'
'meter second-2' ! [m/s2]
'ubar_uux, scalar, series'
'ocean_time'
'idDu2d(M2hadx)'
'u2dvar'
1.0d0
'ubar_vuy' ! Input/Output
'2D u-momentum, hadv vuy term'
'ubar_vuy, scalar, series'
'ocean_time'
'idDu2d(M2hady)'
'u2dvar'
1.0d0
0 608 00:00:00 0.000000E+00 8.372662E+01 8.372662E+01 9.075481E+08
DEF_HIS - creating history file: ./his_40m_tidalzo_0001.nc
DEF_DIAGS - creating diagnostics file: ./dia_cblast2007_0001.nc
9 additional processes aborted (not shown)
oceanM: string.c:176: NC_check_name: Assertion `name != ((void *)0)' failed.
[marlin07:14708] *** Process received signal ***
[marlin07:14708] Signal: Aborted (6)
[marlin07:14708] Signal code: (-6)
[marlin07:14708] [ 0] /lib/libpthread.so.0 [0x2b87329a57d0]
[marlin07:14708] [ 1] /lib/libc.so.6(gsignal+0x35) [0x2b8732be5095]
[marlin07:14708] [ 2] /lib/libc.so.6(abort+0x110) [0x2b8732be6af0]
[marlin07:14708] [ 3] /lib/libc.so.6(__assert_fail+0xef) [0x2b8732bde2df]
[marlin07:14708] [ 4] ./oceanM(NC_check_name+0xef) [0x59872f]
[marlin07:14708] *** End of error message ***
mpiexec noticed that job rank 0 with PID 14708 on node marlin07.marlin.loc exited on signal 6 (Aborted).
This code is so complicated that I very rarely get it all on the first pass when making changes. This is when good debugging skills become important, whether you use a debugger with a gui or just print statements.
Actually, adding each component of the horizontal advection and viscosity is in my to do list. This needs to be done carefully because the advection has an additional term in curvilinear coordinates. You need to do splitting in both 2D and 3D equations because of the coupling. The split-explicit scheme is a numerical technique to resolve gravity-wave dynamics. Many people call ubar and vbar as barotropic velocities. I prefer to call them vertically-integrated velocity components.
Let me see if I can do it soon.
Do you have UV_VIS2 or UV_VIS4 defined? If not, then NDM2d is off by 1 (it was never incremented) You will need to adjust mod_scalars.F.
I would try this:
I don't remember details, but I do recall that ROMS was much happier when the indices were defined in a certain order.
I would try this:
M2pgrd=1
ic=1
# if defined UV_COR
M2fcor=ic+1
ic=ic+1
# if defined UV_ADV
M2hadv=ic+1
ic=ic+1
# if defined M2HADV_SEP !move here and increment ic
M2hadx=ic+1
M2hady=ic+2
ic=ic+2
M2hrad=ic+1
ic=ic+1
M2sstr=ic+1
ic=ic+1
M2bstr=ic+1
M2hvis=ic+2
M2rate=NDM2d
I updated the code to include the ξ- and η-components of horizontal advection, viscosity and diffusion. See following
ticket for details. I also added 2D and 3D relative and potential vorticity.
I did some testing but it will be advantageous if other users help us to test these new diagnostics fields in their particular applications.
