tide_start and ADCIRC
jmrogers
#1 Unread post by jmrogers »
HI all,
I'm modeling Rhode Island Sound and Narragansett Bay and we have been using ADCIRC harmonics from 2004 for the southern boundary tidal forcing. I'm trying to model summer 2006 now and things are not going as well. I tried just adding two years with tide_start but haven't had much luck. Would the tide origin for harmonics_2004.mat be Jan 1, 2004? I know little about where this mat-file came from.
Other tricky part is the tidal wave develops a significant(ly wrong) M4 component as it travels up the Bay. I've tried reducing bottom drag but that doesn't have much of an effect. Should I be more concerned with momentum mixing parameterizations?
Justin
URI GSO
100x200x15 curvilinear grid
CPPDEFS:
ANA_SRFLUX Analytical kinematic shortwave radiation flux.
BULK_FLUXES Surface bulk fluxes parametererization.
EASTERN_WALL Wall boundary at Eastern edge.
FSOBC_REDUCED Using free-surface data in reduced physics condtions
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
K_GSCHEME Third-order upstream bias advection of TKE fields.
SALINITY Using salinity.
SOUTH_M3NUDGING Southern edge, 3D momentum, passive/active outflow/inflow.
SOUTH_TNUDGING Southern edge, tracers, passive/active outflow/inflow.
STATIONS Writing out station data.
TS_A4HADVECTION Fouth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fouth-order Akima vertical advection of tracers.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_U3HADVECTION Third-order upstream bias advection of momentum.
UV_PSOURCE Mass point sources and sinks.
WEST_M2FLATHER Western edge, 2D momentum, Flather condition.
WEST_M3RADIATION Western edge, 3D momentum, radiation condition.
WEST_TRADIATION Western edge, tracers, radiation condition.
nacholibre
Re: tide_start and ADCIRC
#2 Unread post by nacholibre »
Hello Justin,
Did changing the momentum mixing parameters make any change for your case? I am also getting weaker currents in my model than expected and you are right about the bottom drag.
Did you find out any parameters that may help tweaking the results?
Zafer
