This is an error while I compiling the 'upwelling' test on our school's cluster.
When everything was done and typed './build_roms.bash', the error occured
'rm -f -r core *.ipo /home/cyue/roms/upwelling/Build_roms /home/cyue/make_macros.mk
cp -f /home/cyue/nc/nc/include/netcdf.mod /home/cyue/roms/upwelling/Build_roms
cp -f /home/cyue/nc/nc/include/typesizes.mod /home/cyue/roms/upwelling/Build_roms
Can't locate Pod/Escapes.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /usr/share/perl5/Pod/Simple.pm line 8.
BEGIN failed--compilation aborted at /usr/share/perl5/Pod/Simple.pm line 8.
Compilation failed in require at /usr/share/perl5/Pod/Text.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/Pod/Text.pm line 33.
Compilation failed in require at /usr/share/perl5/Pod/Usage.pm line 452.
BEGIN failed--compilation aborted at /usr/share/perl5/Pod/Usage.pm line 459.
Compilation failed in require at ./ROMS/Bin/sfmakedepend line 18.
BEGIN failed--compilation aborted at ./ROMS/Bin/sfmakedepend line 18.
make: *** No rule to make target `/home/cyue/roms/upwelling/Build_roms/MakeDepend', needed by `all'. Stop. '
Do you know how to fix this bug and compile ROMS, thank you.
Error while compiling ROMS
Re: Error while compiling ROMS
This is a problem with your Perl. What version of Perl is this? My Perl works:
chinook03.rcs.alaska.edu 435% perl -v
This is perl 5, version 22, subversion 1 (v5.22.1) built for x86_64-linux-thread-multi
The version of perl on the cluster: 'This is perl, v5.10.1 (*) built for x86_64-linux-thread-multi'kate wrote: Thu Oct 24, 2019 6:49 pm This is a problem with your Perl. What version of Perl is this? My Perl works:
There are no descriptions about perl in the instruction on website 'https://www.myroms.org/wiki/ROMS_UNSW2008', so I didn't care about that.
When compiling, the model is using cluster's perl, so do I need to install a new perl?
Since my Perl is dated 2015 and yours is rather older, it might help if you could try a newer Perl.
Thank you, Kate, that's the problem.kate wrote: Thu Oct 24, 2019 7:14 pm Since my Perl is dated 2015 and yours is rather older, it might help if you could try a newer Perl.
I updated Perl by re-installing Linux on my desktop, then the compilation is successful now.
