if I can set hc=Tcline>hmin?
hpd14thu
#1 Unread post by hpd14thu »
Hello everyone,
I found that in init.matlab pre-processing file, people set hc=min(hmin,Tcline), but my hmin is very small(2m), so I want to set a bigger hc=Tcline(50m)(change the code hc=min(hmin,Tcline) to hc=Tcline). I wonder that if it's OK?
Thank you!!
Re: if I can set hc=Tcline>hmin?
It depends on which vertical "transform" function you use. The old one needed Tcline <= hmin, but the new one does not. I'm sure there's plenty of code still around from the bad old days. I use:
  Vtransform == 2                          ! transformation equation
 Vstretching == 4                          ! stretching function
     THETA_S == 7.0d0                      ! surface stretching parameter
     THETA_B == 2.0d0                      ! bottom  stretching parameter
      TCLINE == 250.0d0                    ! critical depth (m)
with hmin of 2 or 5 or something.
hpd14thu
#3 Unread post by hpd14thu »
kate wrote:It depends on which vertical "transform" function you use. The old one needed Tcline <= hmin, but the new one does not. I'm sure there's plenty of code still around from the bad old days. I use:
Thank you for your help!
pmaccc
#4 Unread post by pmaccc »
I have a related question. I have a grid where the min value of h is 4 m, and I specify Tcline = 10 m in the .in file. So if I am understanding things right ROMS should use hc = 4 m when calculating the z coordinates (I use Transform function 2 and Stretching function 4). Yet in my history files the variable hc has value 10. What is going on here? Where is hmin actually calculated in the code and why do my history files have hc = 10 when it should be 4?
Thanks, Parker
#5 Unread post by kate »
Actually, no, you want hc = Tcline = 10 m. It was only with the bad old stretching that the code enforced hc = Tcline = hmin.
The stretching is meant to be "z-like" above Tcline (hc). Having the old way meant that the z-like part of your domain could only be above hmin. Meanwhile, I was getting away with shallower and shallower values of hmin, especially with wetting and drying, but I still want "z-like" coordinates down to the same depth.
pmaccc
#6 Unread post by pmaccc »
Kate, thanks for your helpful response. I agree that what I want to use for hc is the Tcline I specify in the .in file. What is still unclear to me is if "hmin" is used anywhere in the calculation of z.
From the "warning" paragraph here: https://www.myroms.org/wiki/Vertical_S-coordinate one way of reading the description is that hc = min(hmin, Tcline) is a strict rule. Am I wrong about this? Is it instead the case that newer versions of ROMS use hc = Tcline?
Parker
#7 Unread post by kate »
hmin is no longer used in computing z. If you keep reading in the Warning, it says the restriction was removed.
pmaccc
#8 Unread post by pmaccc »
Thanks very much for the clarification, Kate. It was unclear to me in the wiki which restriction was removed. And now I see in ROMS/Utility/set_scoord.F where this is implemented (lines 176-178 in the version I have):
ELSE IF (Vtransform(ng).eq.2) THEN
hc(ng)=Tcline(ng)
