Question about tidal forcing in the nesting application
lizengocean09
Location: China Institute of Water Resources and Hydropower
#1 Unread post by lizengocean09 »
I used otps2frc_v5 in ROMS_TOOL to generate a tidal forcing file my_test_tides_a.nc. However, when I used this forcing file in a nesting application, some errors appeared. The error messages are as follows.
Found Error: ** Line: 8378 Source: ROMS/Modules/mod_netcdf.F, netcdf_open
my_test_tides_a.nc
call from: ROMS/Utility/inp_decode.F, find_file
Found Error: 03 Line: 1423 Source: ROMS/Modules/mod_netcdf.F, netcdf_inq_var
Found Error: 03 Line: 178 Source: ROMS/Modules/mod_tides.F, allocate_tides
At line 123 of file mod_tides.f90
Fortran runtime error: Index '2' of dimension 1 of array 'tides' above upper bound of 0
Error termination. Backtrace:
Fortran runtime error: Index '2' of dimension 1 of array 'tides' above upper bound of 0.
In the header file, the CPPs for tidal forcing are as follows
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
#define ANA_FSOBC
#define ANA_M2OBC
I don’t understand the meaning of “Fortran runtime error: Index '2' of dimension 1 of array 'tides' above upper bound of 0”.
I am sure that the file my_test_tides_a.nc exists in the working directory, but why I got this error “unable to open existing NetCDF file”.
The version of ROMS I used is 3.7.
It would be much appreciated.
Best wishes,
Li
Re: Question about tidal forcing in the nesting application
#2 Unread post by wilkin »
my_test_tides_a.nc
This suggests ROMS did not find your tides file. The path to the file that you specified in ocean.in (or roms.in these days) may be incorrect or, if it is a relative path, not consistent with the directory in which you are running the model. Check your ocean.in
You mention tides in a nesting application. With nesting, the inner child grid gets its boundary sea level from the parent, not from a tides file (your LBC flags for the child grid should be "Nes").
Does this application run OK with tides when you do not activate nesting?
lizengocean09
#3 Unread post by lizengocean09 »
John Wilkin, Thank you very much for your help!
I have checked the path of the tidal forcing file my_test_tides_a.nc. Indeed, it is in the correct drectory.
The tidal forcing is set in the my_test_nested_2g_ab.in file.
! Input tidal forcing file name.
TIDENAME == ../Data/my_test_tides_a.nc
I have also checked the boundary condition, and the inner child grid can get its surface level from the parent. The boundary conditions are specified as follows
LBC(isFsur) == Clo Cha Cha Cha \
Nes Nes Nes Nes
LBC(isUbar) == Clo Fla Fla Fla \
Nes Nes Nes Nes
LBC(isVbar) == Clo Fla Fla Fla \
Nes Nes Nes Nes
LBC(isUvel) == Clo Rad Rad Rad \
Nes Nes Nes Nes
LBC(isVvel) == Clo Rad Rad Rad \
Nes Nes Nes Nes
LBC(isMtke) == Clo Gra Gra Gra \
Nes Nes Nes Nes
LBC(isTvar) == Clo Rad Rad Rad \
Clo Rad Rad Rad \
Nes Nes Nes Nes \
Nes Nes Nes Nes
Are there any special settings in the file my_test_nested_2g_ab.in or corresponding .h file for ROMS nesting application?
#4 Unread post by wilkin »
If indeed the TIDENAME is where it is supposed to be ...
then the message ...
my_test_tides_a.nc
presumably means the permissions on the file are denying read access.
lizengocean09
#5 Unread post by lizengocean09 »
John Wilkin, Thanks a lot!
I am wondering whether I set the .h file correctly?
#define WEST_WALL
#define SOUTH_FSCHAPMAN
#define SOUTH_M2FLATHER
#define SOUTH_TRADITION
#define SOUTH_M3GRDIENT
#define SOUTH_TGRADIENT
#define EAST_FSCHAPMAN
#define EAST_M2FLATHER
#define EAST_TRADITION
#define EAST_M3GRDIENT
#define EAST_TGRADIENT
#define NORTH_FSCHAPMAN
#define NORTH_M2FLATHER
#define NORTH_TRADITION
#define NORTH_M3GRDIENT
#define NORTH_TGRADIENT
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
#define ANA_FSOBC
#define ANA_M2OBC
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_BPFLUX
#define ANA_SPFLUX
#define ANA_SRFLUX
What could deny the access to the tidal forcing file? Is it being accessed by other subroutines? This may be related to the basic codes of ROMS.
#6 Unread post by wilkin »
Update your code. Those boundary condition #define(s) have been superseded by logical switches in ocean.in.
