passive tracers - segmentation error ......help? :(
Suggest improvements/optimizations to the ROMS code.
aakashsane
#1 Unread post by aakashsane »
Hello!
I have a working version which uses external forcing files (wind, BCs, rivers, ...)
On top of that I wanted to simulate non reactive passive tracers.
So I added variable 'dye_01' to
initial conditions netcdf file, with the same dimensions as that of temperature.
and in the cpp file (.h) file I switched on the following:
#define T_PASSIVE
#define ANA_BPFLUX
#define ANA_SPFLUX
In the input text file, I gave NPT == 1. and switched on Aout(inert) == T .
Apart from the above I haven't made any changes.
I compiled using serial mode (to check), got the oceanS, but when I run I got into segmentation fault error.
I am attaching the .out text file as well as the cpp file, any suggestions would be appreciated.
Best,
Aakash
tracer_ngbay.h
cpp def file for reference.
(1.63 KiB) Downloaded 1084 times
segmenfaulterror.txt
the output text file which shows segmentation fault error.
(46.22 KiB) Downloaded 1053 times
Re: passive tracers - segmentation error ......help? :(
If you recompile with USE_DEBUG=on, you should get filenames and linenumbers instead of those annoying UNKNOWNS:
oceanS             000000000059C85A  Unknown               Unknown  Unknown
oceanS             000000000059BF55  Unknown               Unknown  Unknown
Without line numbers, we're pretty blind!
aakashsane
#3 Unread post by aakashsane »
well...when I switched on the debug mode, it did not compile but gave error. :oops: :oops: :oops:
attaching the error.
compileerror.txt
(50.57 KiB) Downloaded 1112 times
Did you change anything in your build except USE_DEBUG? I assume you cleaned out the old build first. Anyway, it's a link error, not a compile error. The netCDF library wants to link to the curl library. Sometimes, "nc-config --flibs" will want to bring in the curl library. You can add it explicitly to the link statement, but you might have to track it down first. Add to LDFLAGS with
LDFLAGS += -L/location_of_libcurl -lcurl
LDFLAGS gets set in your Compilers/Sys_comp.mk file.
aakashsane
#5 Unread post by aakashsane »
I added the code
and it got rid of the 'lcurl' error which I was getting while compiling in the debug mode.
Thanks Kate for this suggestion.
Debug mode compilation still was not successful due to some other error.
Anyways I went ahead and compiled with MPI == on and ran the model to see if it runs,
and it ran and I am getting some tracer flow.
So now I have a working tracer model, but the debug mode shows some error which is not affecting my run. Is that normal?
Best,
Aakash
#6 Unread post by kate »
It is possible for problems to show up in debug mode that are not fatal when optimized. I still like to get to the bottom of all such issues, if I can.
aakashsane
#7 Unread post by aakashsane »
okay, thanks!
