WC13/R4DVAR Compiling Problem: rp_set_vbc.f90
ckers
#1 Unread post by ckers »
After I compiled the build_roms.bash in test/WC13/R4DVAR, I got this error:
rp_set_vbc.f90:248:10:
tl_stflx(i,j,isalt)=EmP*tl_t(i,j,N(ng),nrhs,isalt)+ &
1
Error: Unclassifiable statement at (1)
I checked the rp_set_vbc.f90 in Build_roms directory under test/WC13/R4DVAR, and I found that
& (tl_EmP-EmP))* &
& t(i,j,N(ng),nrhs,isalt)
As you can see, there is an extra right parenthesis. I have tried to delete the extra right parenthesis; however, after compiling it will generate a new rp_set_vbc.f90
How can I solve this?
Re: WC13/R4DVAR Compiling Problem: rp_set_vbc.f90
You need to fix rp_set_vbc.F, not the .f90 file.
