I have started to run a two way nesting simulation with a grid size of 1079*755 755*663, for running 2 minutes the time taken is 3 minutes approximately(slower as compared to standalone model), I am attaching my .in file for your reference.
Kindly suggest a solution for this one. I have seen previous threads on ths ame topic, however it dates back to previous version.
Slow running of nesting simulation
- ocean_india.in
- (118.94 KiB) Downloaded 252 times
Re: Slow running of nesting simulation
Yes, the online nesting is extremely slow. I have not seen any ROMS development in the myroms code to lead me to expect that this has changed since those old posts. I am instead doing offline nesting because it gives more flexibility in the child grids.
Thank you for the reply Kate. I tried with multiple combinations of Ntilei and NtileJ keeping their ratio almost equal to Lm/Mm, as I reduced the total number of processors from 40x30 to 10x7 (40/30=1.33~Lm/Mm)(10/7=1.423~Lm/Mm) I was able to decrease the time taken for running the model considerably. Now almost 4Hrs 20Min are completed in 32 minutes.
Hi kate,
I need your help to resolve one of my doubt regarding Nesting, I have a coarser grid (1/16) and a refined grid(1/48) the refined grid is created from the coarse using coarse2refine.m matlab script. Rather than having a higher resolution bathymetry for the refined grid, the same bathymetry is observed for the refined grid as compared to the coarser one. How could that happen. I suppose that you have also used the same method, if there is any difference in the approach please highlight the difference
Hernan once said that he thought the way to do it is fine-to-coarse, with a fine grid the size of your larger domain. However, as you find, one must use coarse-to-fine because that's the matlab script you have. I made all the grids and did the bathymetry the way I wanted to.
What I can help you with is the roms.in file. If you have a working roms.in for the coarse grid and same for the fine grid, I have a python script to merge the two (or three, or five). See the pyroms/examples/nesting directory.
My standalone ROMS set up for coarse(1/12) and fine(1/36) resolution is running well individually but when I use two way nesting the Cw value becomes greater than one for finer resolution grid. Is that problem due to the higher time step? I have used 300,100 for coarse and finer resolution respectively and have used the same dt for running independently too.
