error in compiling scrip_coawst
sun_92
#1 Unread post by sun_92 »
Dear all
I'm getting this error while running the scrip_coawst. Kindly help
./scrip_coawst scrip_coawst_bob.in
Read input_file for SCRIP_COAWST Wrapper
Ngrid_roms= 1
Ngrid_swan= 0
Ngrid_ww3= 0
Ngrid_wrf = 1
Common netcdf file is:
scrip_bob.nc
Number of netcdf subgroups 2
Input ROMS grid 1 = /scratch/student2/COAWST/croco_grd.nc
Input WRF grid 1 = /scratch/student2/COAWST/wrfinput_d01
Begin mapping between the two grids
The interp file is:
ocn1_to_atm1_weights.nc
The src grid is:
The dst grid is:
grid1 dimensions= 217 225
grid2 dimensions= 99 99
Using latitude bins to restrict search.
Computing remappings between:
and
grid1 sweep
grid2 sweep
Total number of links = 65140
Error in netCDF:
Permission denied
I have exported LD_FLAGS , CPP FLAGS and all in terminal. Please help
robertson
Re: error in compiling scrip_coawst
#2 Unread post by robertson »
The "Permission denied" error would suggest that your user does not have read and/or write permissions to the file or directory.
The command "ls -la" will give you the permissions of all the files and the current directory, which will be listed as a single period (.)
sun_92
#3 Unread post by sun_92 »
Yes i have permission for the executable and file.
-rwxrwxrwx 1 student2 research 1705764 Jun  6 16:05 scrip_coawst
-rwxrwxrwx 1 student2 research    1340 Jun  6 17:10 scrip_coawst_bob.in
and also for netcdf folder.
sun_92
#4 Unread post by sun_92 »
drwxrwxr-x 2 student2 research 14848 Jun 6 17:10 .
drwxr-xr-x 5 student2 research 10752 Jun 6 16:03 ..
#5 Unread post by jcwarner »
let just see if you can create a file in that directory. try this command
touch help.txt
and then do
ls -ltr
do you see that file?
sun_92
#6 Unread post by sun_92 »
I was able to create the file using touch command with following permission.
-rw-r--r-- 1 student2 research       0 Jun 10 09:12 help.txt
sun_92
#7 Unread post by sun_92 »
Hi all
I tried two versions of COAWST, however getting the same error while using SCRIP_COAWST. Please help
