Error compiling COAWST
sun_92
#1 Unread post by sun_92 »
Dear All
I'm getting the following error in building COAWST using FC=ifort ? Can you please help?
diag.f90(132): error #6279: A specification expression object must be a dummy argument, a COMMON block object, or an object accessible through host or use association. [NREDUCE]
integer :: Nreduce
compilation aborted for diag.f90 (code 1)
make: *** [Build/diag.o] Error 1
Re: Error compiling COAWST
Could you look at your diag.F to see how Nreduce is set and used? My code has:
#ifdef DISTRIBUTE
# ifdef SOLVE3D
#  ifdef BIOLOGY
      integer :: Nreduce
#  else
      integer, parameter :: Nreduce = 6
#  endif
      integer, parameter :: Ncourant = 7
# else
      integer, parameter :: Nreduce = 4
      integer, parameter :: Ncourant = 5
      real(r8), allocatable           :: buffer(:)
      character (len=3), allocatable  :: op_handle(:)
      character (len=6), allocatable  :: C_handle(:)
      real(r8), dimension(Ncourant) :: Courant
#else
      integer :: my_threadnum
Then later:
#ifdef DISTRIBUTE
# ifdef BIOLOGY
      Nreduce = 6 + NBT
      IF (.not. allocated(buffer))    allocate (buffer(Nreduce))
      IF (.not. allocated(op_handle)) allocate (op_handle(Nreduce))
      IF (.not. allocated(C_handle))  allocate (C_handle(Nreduce))
sun_92
#3 Unread post by sun_92 »
! Local variable declarations.
#ifdef BIOLOGY
integer :: ibt, itrc
integer :: NSUB, i, ispace, j, k, trd
integer :: my_max_Ci, my_max_Cj, my_max_Ck
#ifdef DISTRIBUTE
# ifdef SOLVE3D
# ifdef BIOLOGY
integer :: Nreduce
# else
integer, parameter :: Nreduce = 5
# else
real(r8), dimension(Nreduce) :: buffer
character (len=3), dimension(Nreduce) :: op_handle
character (len=6), dimension(Nreduce) :: C_handle
#else
THEN LATER
#ifdef DISTRIBUTE
# ifdef BIOLOGY
Nreduce = 5 + NBT
! IF (.not. allocated(buffer)) allocate (buffer(Nreduce))
! IF (.not. allocated(op_handle)) allocate (op_handle(Nreduce))
! IF (.not. allocated(C_handle)) allocate (C_handle(Nreduce))
You need to change yours to look like mine for it to compile.
sun_92
#5 Unread post by sun_92 »
Thank you, I'm doing it
