I wanna use oceanM so i set USE_MPI=on and USE_MPIF90=on in the build.bash file as below:
workingdir=${PWD}
which_MPI=openmpi # default, overwriten below
parallel=0
clean=1
dprint=0
while [ $# -gt 0 ]
do
case "$1" in
-j )
shift
parallel=1
test=`echo $1 | grep '^[0-9]\+$'`
if [ "$test" != "" ]; then
NCPUS="-j $1"
shift
else
NCPUS="-j"
fi
-p )
shift
clean=0
dprint=1
debug="print-$1"
shift
-noclean )
shift
clean=0
echo ""
echo "$0 : Unknown option [ $1 ]"
echo ""
echo "Available Options:"
echo ""
echo "-j [N] Compile in parallel using N CPUs"
echo " omit argument for all avaliable CPUs"
echo ""
echo "-p macro Prints any Makefile macro value"
echo " For example: build.bash -p FFLAGS"
echo ""
echo "-noclean Do not clean already compiled objects"
echo ""
exit 1
esac
done
# Set the CPP option defining the particular application. This will
# determine the name of the ".h" header file with the application
# CPP definitions.
export ROMS_APPLICATION=east_sea_curv3d
# Set a local environmental variable to define the path to the directories
# where all this project's files are kept.
export MY_ROOT_DIR=${workingdir}
export MY_PROJECT_DIR=${MY_ROOT_DIR}
# The path to the user's local current ROMS source code.
# If using svn locally, this would be the user's Working Copy Path (WCPATH).
# Note that one advantage of maintaining your source code locally with svn
# is that when working simultaneously on multiple machines (e.g. a local
# workstation, a local cluster and a remote supercomputer) you can checkout
# the latest release and always get an up-to-date customized source on each
# machine. This script is designed to more easily allow for differing paths
# to the code and inputs on differing machines.
#export MY_ROMS_SRC=${MY_ROOT_DIR}/branches/arango
export MY_ROMS_SRC=${MY_ROOT_DIR}/trunk
# ${MY_ROMS_SRC}/Compilers. If this is the case, the you need to keep
# these configurations files up-to-date.
export COMPILERS=${MY_ROMS_SRC}/Compilers
#export COMPILERS=${HOME}/Compilers
# Set tunable CPP options.
# Sometimes it is desirable to activate one or more CPP options to run
# different variants of the same application without modifying its header
# file. If this is the case, specify each options here using the -D syntax.
# Notice also that you need to use shell's quoting syntax to enclose the
# definition. Both single or double quotes work. For example,
#export MY_CPP_FLAGS="-DAVERAGES"
#export MY_CPP_FLAGS="${MY_CPP_FLAGS} -DDEBUGGING"
# can be used to write time-averaged fields. Notice that you can have as
# many definitions as you want by appending values.
#export MY_CPP_FLAGS="-D"
# Other user defined environmental variables. See the ROMS makefile for
# details on other options the user might want to set here. Be sure to
# leave the switches meant to be off set to an empty string or commented
# out. Any string value (including off) will evaluate to TRUE in
# conditional if-statements.
export USE_MPI=on # distributed-memory parallelism
export USE_MPIF90=on # compile with mpif90 script
#export which_MPI=mpich2 # compile with MPICH2 library
export which_MPI=openmpi # compile with OpenMPI library
#export USE_OpenMP= # shared-memory parallelism
#export FORT=ifort
export FORT=gfortran
#export FORT=pgi
#export USE_DEBUG=on # use Fortran debugging flags
export USE_LARGE=on # activate 64-bit compilation
export USE_NETCDF4=on # compile with NetCDF-4 library
#export USE_PARALLEL_IO=on # Parallel I/O with Netcdf-4/HDF5
# There are several MPI libraries available. Here, we set the desired
# "mpif90" script to use during compilation. This only works if the make
# configuration file (say, Linux-pgi.mk) in the "Compilers" directory
# has the following definition for FC (Fortran Compiler) in the USE_MPI
# section:onS
# FC := mpif90
# that is, "mpif90" defined without any path. Notice that the path
# where the MPI library is installed is computer dependent. Recall
# that you still need to use the appropriate "mpirun" to execute.
if [ -n "${USE_MPIF90:+1}" ]; then
case "$FORT" in
ifort )
if [ "${which_MPI}" = "mpich" ]; then
export PATH=/opt/intelsoft/mpich/bin:$PATH
elif [ "${which_MPI}" = "mpich2" ]; then
export PATH=/opt/intelsoft/mpich2/bin:$PATH
export PATH=/opt/intelsoft/openmpi/bin:$PATH
fi
pgi )
export PATH=/opt/pgisoft/mpich/bin:$PATH
export PATH=/opt/pgisoft/mpich2/bin:$PATH
export PATH=/opt/pgisoft/openmpi/bin:$PATH
fi
gfortran )
export PATH=/usr/bin:$PATH
export PATH=/opt/openmpi:$PATH
fi
esac
fi
# Set libraries to compile.
# If the USE_MY_LIBS is activated above, the path of the libraries
# required by ROMS can be set here using environmental variables
# which take precedence to the values specified in the make macro
# definitions file (Compilers/*.mk). For most applications, only
# the location of the NetCDF library is needed during compilation.
# Notice that when the USE_NETCDF4 macro is activated, we need the
# serial or parallel version of the NetCDF-4/HDF5 library. The
# configuration script NF_CONFIG (available since NetCDF 4.0.1)
# is used to set up all the required libraries according to the
# installed options (openDAP, netCDF4/HDF5 file format). The
# parallel library uses the MPI-I/O layer (usually available
# in MPICH2 and OpenMPI) requiring compiling with the selected
# MPI library.
# In ROMS distributed-memory applications, you may use either the
# parallel version is required when parallel I/O is activated
# (ROMS cpp option PARALLEL_IO and HDF5).
# However, in serial or shared-memory ROMS applications, we need
# to use the serial version of the NetCDF-4/HDF5 to avoid conflicts
# with the compiler. We cannot activate MPI constructs in serial
# or shared-memory ROMS code. Hybrid parallelism is not possible.
# Recall also that the MPI library comes in several flavors:
# MPICH, MPICH2, OpenMPI, etc.
export USE_MY_LIBS=on # use my library paths below
case "$FORT" in
ifort )
export ESMF_COMPILER=intelgcc
export ESMF_BOPT=O
export ESMF_ABI=64
export ESMF_COMM=%{which_MPI}
export ESMF_SITE=default
export ARPACK_LIBDIR=/opt/intelsoft/serial/ARPACK
export ESMF_DIR=/opt/intelsoft/mpich/esmf
export MCT_INCDIR=/opt/intelsoft/mpich/mct/include
export MCT_LIBDIR=/opt/intelsoft/mpich/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich/PARPACK
export ESMF_DIR=/opt/intelsoft/mpich2/esmf
export MCT_INCDIR=/opt/intelsoft/mpich2/mct/include
export MCT_LIBDIR=/opt/intelsoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich2/PARPACK
export ESMF_DIR=/opt/intelsoft/openmpi/esmf
export MCT_INCDIR=/opt/intelsoft/openmpi/mct/include
export MCT_LIBDIR=/opt/intelsoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/openmpi/PARPACK
fi
fi
if [ -n "${USE_NETCDF4:+1}" ]; then
if [ -n "${USE_PARALLEL_IO:+1}" ] && [ -n "${USE_MPI:+1}" ]; then
export NF_CONFIG=/opt/intelsoft/mpich/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/intelsoft/mpich/netcdf4/include
export NF_CONFIG=/opt/intelsoft/mpich2/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/intelsoft/mpich2/netcdf4/include
export NF_CONFIG=/opt/intelsoft/openmpi/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/intelsoft/openmpi/netcdf4/include
fi
else
export NF_CONFIG=/opt/intelsoft/serial/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/intelsoft/serial/netcdf4/include
fi
else
export NETCDF_INCDIR=/opt/intelsoft/serial/netcdf3/include
export NETCDF_LIBDIR=/opt/intelsoft/serial/netcdf3/lib
fi
pgi )
export ESMF_COMPILER=pgi
export ESMF_BOPT=O
export ESMF_ABI=64
export ARPACK_LIBDIR=/opt/pgisoft/serial/ARPACK
export ESMF_DIR=/opt/pgisoft/mpich/esmf
export MCT_INCDIR=/opt/pgisoft/mpich/mct/include
export MCT_LIBDIR=/opt/pgisoft/mpich/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/mpich/PARPACK
export ESMF_DIR=/opt/pgisoft/mpich2/esmf
export MCT_INCDIR=/opt/pgisoft/mpich2/mct/include
export MCT_LIBDIR=/opt/pgisoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/mpich2/PARPACK
export ESMF_DIR=/opt/pgisoft/openmpi/esmf
export MCT_INCDIR=/opt/pgisoft/openmpi/mct/include
export MCT_LIBDIR=/opt/pgisoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/openmpi/PARPACK
fi
fi
export NF_CONFIG=/opt/pgisoft/mpich/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/mpich/netcdf4/include
export NF_CONFIG=/opt/pgisoft/mpich2/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/mpich2/netcdf4/include
export NF_CONFIG=/opt/pgisoft/openmpi/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/openmpi/netcdf4/include
fi
else
export NF_CONFIG=/opt/pgisoft/serial/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/serial/netcdf4/include
fi
else
export NETCDF_INCDIR=/opt/pgisoft/serial/netcdf3/include
export NETCDF_LIBDIR=/opt/pgisoft/serial/netcdf3/lib
fi
gfortran )
export ESMF_COMPILER=gfortran
export ESMF_BOPT=O
export ESMF_ABI=64
export ARPACK_LIBDIR=${MY_ROMS_SRC}/Lib/ARPACK
export ESMF_DIR=/opt/gfortransoft/mpich2/esmf
export MCT_INCDIR=/opt/gfortransoft/mpich2/mct/include
export MCT_LIBDIR=/opt/gfortransoft/mpich2/mct/lib
export PARPACK_LIBDIR=${MY_ROMS_SRC}/Lib/ARPACK
export ESMF_DIR=/opt/openmpi/bin
export MCT_INCDIR=/opt/openmpi/include
export MCT_LIBDIR=/opt/openmpi/lib
fi
fi
export NF_CONFIG=/usr/local/bin/nf-config
export NETCDF_INCDIR=/usr/local/include
fi
else
fi
else
export NETCDF_LIBDIR=/usr/local/lib
fi
esac
fi
# The rest of this script sets the path to the users header file and
# analytical source files, if any. See the templates in User/Functionals.
# If applicable, use the MY_ANALYTICAL_DIR directory to place your
# customized biology model header file (like fennel.h, nemuro.h, ecosim.h,
# etc).
export MY_HEADER_DIR=${MY_PROJECT_DIR}/Include
export MY_ANALYTICAL_DIR=${MY_ROMS_SRC}/ROMS/Functionals
# Put the binary to execute in the following directory.
export BINDIR=${MY_PROJECT_DIR}
# Put the f90 files in a project specific Build directory to avoid conflict
# with other projects.
export SCRATCH_DIR=${MY_PROJECT_DIR}/Build
# Go to the users source directory to compile. The options set above will
# pick up the application-specific code from the appropriate place.
cd ${MY_ROMS_SRC}
# Compile.
# Remove build directory.
if [ $clean -eq 1 ]; then
make clean
fi
# Compile (the binary will go to BINDIR set above).
if [ $dprint -eq 1 ]; then
make $debug
else
if [ $parallel -eq 1 ]; then
make $NCPUS
else
make
fi
fi
mod_parallel.f90:17: Error: Can't open included file 'mpif.h'
ROMS/Modules/Module.mk:15: recipe for target '/home/ROMS_Programs/Build/mod_parallel.o' failed
make: *** [/home/ROMS_Programs/Build/mod_parallel.o] Error 1
When i run build.bash file it returned the error:
Could anyone please help me how to fix it? I am very new in ROMS. Also, I went around the forum to find how to fix this error but still couldnt.
Thanks a lot
couldn't create executable oceanM
Re: couldn't create executable oceanM
Hi Van!
I think, you need to specify the path to your MPI library. I marked the line with a long arrow:
gfortran )
------> export PATH=/opt/openmpi:$PATH
fi
Hi c.drinkorn,
Thanks a lot for your response.
I gave a full path for mpi already, but it didn't work. Then i did give a full path to mpif90 in the Linux-gfortran.mk file and now it worked, oceanM was created.
