compiling upwelling
- Location: Nanjing University of Information Science & Techno
compiling upwelling
hello everyone:
i am encountering a problem when i am compiling the case of upwelling, it shows that:
cp -f /home/kzf/softwares/packman.active/include/netcdf.mod /home/kzf/myroms/projects/upwelling/Build_romsG
cp -f /home/kzf/softwares/packman.active/include/typesizes.mod /home/kzf/myroms/projects/upwelling/Build_romsG
:No such file or directory
make: **** no rule to make target...
i guess it is the problems of netcdf,the version of netcdf is 4.1.2
i edit my build_roms.bash like that:
export USE_NETCDF4=on
export USE_MY_LIBS=yes
export NETCDF_INCDIR=/home/kzf/softwares/packman.active/include
export NETCDF_LIBDIR=/home/kzf/softwares/packman.active/lib
export NC_CONFIG=/home/kzf/softwares/packman.active/bin/nc-config
export NF_CONFIG=/home/kzf/softwares/packman.active/bin/nf-config
could you help fix this problems,thanks very much!
by the way ,the netcdf.mod and typesizes.mod do exist in the file of Build_romsG. but the compiling is unsucessful
Re: compiling upwelling
I suppose that you are trying to compile the test case of upwelling, i too had similiar problems while compiling the test case. Please try to rectify it by changing line 52 of Linux-gfortran.mk as follows ( code from unidata):
Before
LIBS := -L$(NETCDF_LIBDIR) -lnetcdf
After
LIBS := -L$(NETCDF_LIBDIR) -lnetcdf -lnetcdff
Keep a copy of the original or keep a changelog session for future use.
Before
After
you might get to a problem with netcdf, and perhaps the -lnetcdff flag is needed, but right now your problem is:
"cp -f /home/kzf/softwares/packman.active/include/netcdf.mod /home/kzf/myroms/projects/upwelling/Build_romsG
:No such file or directory"
so:
1) does this directory exist: /home/kzf/softwares/packman.active/include/
2) does that directory contain netcdf.mod and typesizes.mod
3) does this directory exist: /home/kzf/myroms/projects/upwelling/Build_romsG
-john
so:
-john
hi, MIDHILAVARNAV:MIDHILAVARNAV wrote:I suppose that you are trying to compile the test case of upwelling, i too had similiar problems while compiling the test case. Please try to rectify it by changing line 52 of Linux-gfortran.mk as follows ( code from unidata):
Before
After
i have rectified Linux-gfortran.mk as your said, but the problem is still here.
could you provide me the vsrsion of roms you use and the changes you have made in your compiling in detail?
hi John,jcwarner wrote:you might get to a problem with netcdf, and perhaps the -lnetcdff flag is needed, but right now your problem is:
so:
-john
these three directionies all exist, the netcdf.mod and typesizes.mod have been copied to the directory of Build_romsG. but it still indicates that ":No such file or directory", and the compling interrupt
so when i build i get something like this:
[jwarner@poseidon-l1 breach338]$ ./coawst.bash
rm -f -r core *.ipo ./Build /vortexfs1/usgs/jwarner/make_macros.mk
makefile:248: INCLUDING FILE /vortexfs1/usgs/jwarner/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
cp -f /vortexfs1/apps/netcdf-intel/include/netcdf.mod ./Build
cp -f /vortexfs1/apps/netcdf-intel/include/typesizes.mod ./Build
./ROMS/Bin/sfmakedepend --cpp --fext=f90 --file=- --objdir=./Build -DROMS_HEADER="sandy_inwave.h" -I ROMS/Include -I /vortexfs1/usgs/jwarner/Projects/breach_run_files/breach338/Sandy_InWave -I ROMS/Nonlinear -I ROMS/Nonlinear/Biology -I ROMS/Nonlinear/Sediment -I ROMS/Nonlinear/Wec -I ROMS/Nonlinear/Vegetation -I ROMS/Utility -I ROMS/Drivers -I ROMS/Functionals -I /vortexfs1/usgs/jwarner/Projects/breach_run_files/breach338/Sandy_InWave -I SWAN/Src -I Master -I Compilers --silent --moddir ./Build ROMS/Nonlinear/lmd_skpp.F ROMS/Nonlinear/uv3.....
can you post the whole entire build output?
thanks
john
thanks
john
hi,John:jcwarner wrote:so when i build i get something like this:
thanks
john
i changed to a older version of ROMS of 514. and now the messages shows like
well that looks worse.
can you attach the build.bash. want to make sure you set the compiler.
It looks like the Perl script sfmakedepend is failing. First you need to check that ./ROMS/Bin/sfmakedepend exists, then look in it to see what the first line is. I expect that you have the sfmakedepend file, but my first line is:
so the problem could be either /usr/bin/env or perl.
#!/usr/bin/env perl
chinook01.rcs.alaska.edu 267% ls -l /usr/bin/env
0 lrwxrwxrwx. 1 root root 13 Jul 10 2018 /usr/bin/env -> ../../bin/env*
chinook01.rcs.alaska.edu 268% which perl
/usr/local/pkg/lang/Perl/5.22.1-foss-2016b/bin/perl
thanks everyone, i have saved this problem.
i execute the command sed -i 's/\r$//' to all of the files under Roms
and now i have compiled the case upwelling successfully!
why does this happen? because i download the codes through a svn version of windows?
Oh that old Windows problem. Exactly.
