parameter hc and Tcline
hpd14thu
#1 Unread post by hpd14thu »
I am writing the matlab code to generate init.nc file now. But I am not clear about the physical significance of parameter hc and Tcline. I try to Goole that but I did not find the answer. I would so appreciate if if someone can explain these parameters.
Thanks for your attention and your reply.ヽ(•ω• )ゝ
Re: parameter hc and Tcline
#2 Unread post by wilkin »
The parameters Tcline and hc are explained here:
https://www.myroms.org/wiki/Vertical_S-coordinate
The page concludes with some example stretching generated with scoord.m which is in the Matlab repository available on myroms.org.
hpd14thu
#3 Unread post by hpd14thu »
wilkin wrote:The parameters Tcline and hc are explained here:
Thank you for your reply :mrgreen:
Peida
