why "Fjord tidal case" results are the same temp values?
shiyf
#1 Unread post by shiyf »
Hello everybody,
I'm trying to set up the "Fjord tidal case" .
So first I made the grid.nc and ini.nc files. Both files were created with easygrid.m and ROMS ran without problems.
Afterwards, I build some files,eg,fjord.h,ana_fsobc.h,and so on according to the instructions on the web.
ROMS ran successfully and product two files-Fjord_ocean_his.nc and Fjord_ocean_rst.nc.But when i try to plot temp variable,i found that all the temp values are in the same.
I don't know what's the problem or what to check. I'm relatively new in modeling so I appreciate any suggestions.
Thanks in advance!
shiyf
Re: why "Fjord tidal case" results are the same temp values
Did your temperatures start out uniform? What forcings do you have on? How would you expect the temperature to be evolving? You might try turning on DIAGNOSTICS_TS for a short run to see what you see there.
bigyao
#3 Unread post by bigyao »
I meet the same problem, Have you fixed it?
Thanks for your reply
