I know that this error (the one that I am more afraid to get) can be caused by a lot of things, so I will try to give as much information as possible. I have been working for a while with ROMS. Now I am using ROMS/TOMS version 3.7, revision 921. After last updates, when I try to run the model I get:
Wednesday - September 19, 2018 - 5:10:14 PM
Image PC Routine Line Source
oceanM 00000000008544E5 Unknown Unknown Unknown
oceanM 0000000000852107 Unknown Unknown Unknown
oceanM 0000000000801784 Unknown Unknown Unknown
oceanM 0000000000801596 Unknown Unknown Unknown
oceanM 00000000007B40A6 Unknown Unknown Unknown
oceanM 00000000007B7CA0 Unknown Unknown Unknown
libpthread.so.0 00007F9460F46790 Unknown Unknown Unknown
oceanM 000000000086E313 Unknown Unknown Unknown
oceanM 00000000007FCE18 Unknown Unknown Unknown
oceanM 000000000041A869 Unknown Unknown Unknown
oceanM 00000000004249A2 Unknown Unknown Unknown
oceanM 0000000000412CEC Unknown Unknown Unknown
oceanM 000000000040BAD2 Unknown Unknown Unknown
oceanM 000000000040B59C Unknown Unknown Unknown
oceanM 000000000040B45E Unknown Unknown Unknown
libc.so.6 00007F946093DD5D Unknown Unknown Unknown
oceanM 000000000040B369 Unknown Unknown Unknown
I am able to run the model with older ROMS revision (i.e: ROMS/TOMS version 3.7 SVN Revision : 836M). I have tested successfully that NetCDF used was NetCDF4 using "ncdump -k", returning for all the input files: netCDF-4.
I am using ifort to compile the code. I am sorry, but I am not able to use another one cause I am not the admin of the system. The compiler file is set up:
setenv USE_MPI on # distributed-memory parallelism
# setenv USE_MPIF90 on # compile with mpif90 script
#setenv which_MPI mpich # compile with MPICH library
setenv which_MPI mpich2 # compile with MPICH2 library
## setenv which_MPI openmpi # compile with OpenMPI library
#setenv USE_OpenMP on # shared-memory parallelism
setenv FORT ifort
#setenv FORT gfortran
#setenv FORT pgi
#setenv USE_DEBUG on # use Fortran debugging flags
setenv USE_LARGE on # activate 64-bit compilation
setenv USE_NETCDF4 on # compile with NetCDF-4 library
setenv USE_PARALLEL_IO on # Parallel I/O with NetCDF-4/HDF5
I get the same result running it serial (oceanS). When I tried to activate DEBUG, I get this error:
ld: cannot find -ldl
So I am not able to know exactly what file is getting me in troubles.
I have been able to parallel run with MPI the upwelling test case. So I am pretty sure that my problem is related with the NetCDF file that I am using.
I really appreciate if you could point me out next steps to follow.
Thanks a lot,
-Francisco
I tried
