Compiling ROMS error
michaelkwamebiney
#1 Unread post by michaelkwamebiney »
I have been able to compile the upwelling test case and i had an executable called oceanM
But when i try to run it on a single processor i get the following error. And im also wondering why i am not getting the oceanS executable file.
Here is the error message i got
Tuesday - September 11, 2018 - 12:39:05 PM
INP_PAR - Unable to open ROMS/TOMS input script file.
In distributed-memory applications, the input
script file is processed in parallel. The Unix
routine GETARG is used to get script file name.
For example, in MPI applications make sure that
command line is something like:
mpirun -np 4 ocean ocean.in
and not
mpirun -np 4 ocean < ocean.in
Found Error: 02 Line: 111 Source: ROMS/Drivers/nl_ocean.h
Elapsed CPU time (seconds):
Analytical header files used:
Found Error: 02 Line: 350 Source: ROMS/Utility/close_io.F
REASON: No error
Re: Compiling ROMS error
if you set
export USE_MPI=on # distributed-memory parallelism
export USE_MPIF90= # compile with mpif90 script
export USE_OpenMP= # shared-memory parallelism
or
export USE_MPIF90=on # compile with mpif90 script
then you will get an oceanM
this will give you an oceanO
export USE_MPI= # distributed-memory parallelism
export USE_OpenMP=on # shared-memory parallelism
if you do this:
you will get an oceanS.
michaelkwamebiney
#3 Unread post by michaelkwamebiney »
Thank you very much. Problem solved
