Error while running biotoy test case
sun_92
#1 Unread post by sun_92 »
Hello all, i tried to give the test BIOTOY CASE using the fennel module. But I'm getting the following error. Can anybody help?
i gave the run using the command mpirun -np 1 ./oceanM ocean_bio_toy_fennel.in
Re: Error while running biotoy test case
It told you you have a calendar inconsistency between the initial time and the Tair files. You can use DSTART to change the ROMS time to match the Tair time, but all other files with times have to be consistent too.
sun_92
#3 Unread post by sun_92 »
How to change the timings of the already tested cases? The ocean_time is 0 and Tair time is 0.5 1.5 2.5 etc
