Errors when compiling ROMS
han
#1 Unread post by han »
I was compiling an application on ROMS. And when I was running oceanG and *.in file, I met with following error
Program received signal 11 (SIGSEGV): Segmentation fault.
Backtrace for this error:
+ /lib64/libc.so.6() [0x3d21432510]
+ function load_i_ (0x4341A5)
at line 1026 of file inp_par.f90
+ function read_phypar_ (0x456ED8)
at line 214 of file read_phypar.f90
+ function inp_par_ (0x40C8A1)
at line 67 of file inp_par.f90
+ function __ocean_control_mod_MOD_roms_initialize (0x4035F3)
at line 75 of file ocean_control.f90
+ in the main program
at line 81 of file master.f90
+ /lib64/libc.so.6(__libc_start_main+0xfd) [0x3d2141ed1d]
Does anybody know what are these about? I'm trying to figure them out but the progress is slow.
Re: Errors when compiling ROMS
The place to look is here:
This file should be in your $SCRATCH_DIR. What is on that line?
han
#3 Unread post by han »
kate wrote:The place to look is here:
Below is the related program. Line 214 is marked red.
! Read in physical model parameters. Then, load input data into module.
! Take into account nested grid configurations.
DO WHILE (.TRUE.)
READ (inp,'(a)',ERR=10,END=20) line
status=decode_line(line, KeyWord, Nval, Cval, Rval)
IF (status.gt.0) THEN
SELECT CASE (TRIM(KeyWord))
CASE ('TITLE')
IF (Nval.eq.1) THEN
title=TRIM(ADJUSTL(Cval(Nval)))
ELSE
WRITE(title,'(a,1x,a)') TRIM(ADJUSTL(title)), &
& TRIM(ADJUSTL(Cval(Nval)))
CASE ('MyAppCPP')
DO i=1,LEN(MyAppCPP)
MyAppCPP(i:i)=blank
MyAppCPP=TRIM(ADJUSTL(Cval(Nval)))
CASE ('VARNAME')
DO i=1,LEN(varname)
varname(i:i)=blank
varname=TRIM(ADJUSTL(Cval(Nval)))
CASE ('Ngrids')
Npts=load_i(Nval, Rval, 1, Ivalue)
Ngrids=Ivalue(1)
IF (Ngrids.le.0) THEN
IF (Master) WRITE (out,290) 'Ngrids', Ngrids, &
& 'must be greater than zero.'
exit_flag=5
RETURN
got_Ngrids=.TRUE.
CALL allocate_param ! Start allocating variables in
CALL allocate_parallel ! modules that solely depend on
CALL allocate_iounits ! the number of nested grids
CALL allocate_stepping
IF (.not.allocated(Ldiag)) THEN
allocate ( Ldiag(Ngrids) )
IF (.not.allocated(Nfiles)) THEN
allocate ( Nfiles(Ngrids) )
Nfiles(1:Ngrids)=0
CASE ('NestLayers')
NestLayers=Ivalue(1)
IF (NestLayers.lt.1) THEN
IF (Master) WRITE (out,290) 'NestLayers', NestLayers, &
& 'must be greater or equal than one.'
exit_flag=5
RETURN
IF (NestLayers.gt.1) THEN
& 'must be equal to one in non-nesting applications.'
exit_flag=5
RETURN
got_NestLayers=.TRUE.
IF (.not.allocated(GridsInLayer)) THEN
allocate ( GridsInLayer(NestLayers) )
GridsInLayer(1:NestLayers)=1
IF (.not.allocated(GridNumber)) THEN
allocate ( GridNumber(Ngrids,NestLayers) )
GridNumber(1:Ngrids,1:NestLayers)=0 ! Important
CASE ('GridsInLayer')
IF (.not.got_NestLayers) THEN
IF (Master) WRITE (out,320) 'NestLayers', &
& 'Add "NestLayers" keyword before GridsInLayer.'
exit_flag=5
RETURN
Npts=load_i(Nval, Rval, NestLayers, GridsInLayer)
ng=0
DO nl=1,NestLayers
DO i=1,GridsInLayer(nl)
ng=ng+1 ! order of grids are very in
GridNumber(i,nl)=ng ! nesting applications. See
END DO ! WikiROMS for details.
CASE ('Lm')
IF (.not.got_Ngrids) THEN
IF (Master) WRITE (out,320) 'Ngrids', &
& 'Add "Ngrids" keyword before grid dimension (Lm, Mm).'
exit_flag=5
RETURN
Npts=load_i(Nval, Rval, Ngrids, Lm)
DO ng=1,Ngrids
IF (Lm(ng).le.0) THEN
IF (Master) WRITE (out,300) 'Lm', ng, &
exit_flag=5
RETURN
CASE ('Mm')
Npts=load_i(Nval, Rval, Ngrids, Mm)
DO ng=1,Ngrids
IF (Mm(ng).le.0) THEN
IF (Master) WRITE (out,300) 'Mm', ng, &
exit_flag=5
RETURN
CASE ('N')
Npts=load_i(Nval, Rval, Ngrids, N)
DO ng=1,Ngrids
IF (N(ng).lt.0) THEN
IF (Master) WRITE (out,300) 'N', ng, &
exit_flag=5
RETURN
CASE ('NAT')
NAT=Ivalue(1)
IF ((NAT.lt.1).or.(NAT.gt.2)) THEN
IF (Master) WRITE (out,290) 'NAT = ', NAT, &
& 'make sure that NAT is either 1 or 2.'
exit_flag=5
RETURN
IF (NAT.ne.2) THEN
& 'make sure that NAT is equal to 2.'
exit_flag=5
RETURN
CASE ('NtileI')
Npts=load_i(Nval, Rval, Ngrids, NtileI)
NtileX(1:Ngrids)=NtileI(1:Ngrids)
CASE ('NtileJ')
Npts=load_i(Nval, Rval, Ngrids, NtileJ)
NtileE(1:Ngrids)=NtileJ(1:Ngrids)
So this code is reading NtileI from the ocean_xxx.in file. Did you switch so that NtileJ comes before NtileI in the ocean.in file? This is forbidden. Or is something else screwy in your ocean.in file? That's what you need to check next.
han
#5 Unread post by han »
kate wrote:So this code is reading NtileI from the ocean_xxx.in file. Did you switch so that NtileJ comes before NtileI in the ocean.in file? This is forbidden. Or is something else screwy in your ocean.in file? That's what you need to check next.
Thanks, kate. I'll check my ocean.in file.
