Dear Sir or Madam,
I installed the newest ROMS source codes:
https://www.myroms.org/projects/src/ticket/769
that includes the modified "Linux-ifort.mk".
And I tried to MPI compile (make) UPWELLING case using 'ifort'
compiler. The consequences, however, the following error messages
appeared and failed to compile (make);
>> ipo: warning #11016: Warning unknown option -stack_size
>> ld: Unrecognized option of -a : `ck_size'
>> make: *** [oceanM] error 1
Then would you please tell me how to compile (make) this UPWELLING
case successfully?
Note that the version of compilers I am using are as follows;
intel/18.0.2.199
intel-mpi/5.0.3.048
And I set the environmental variable stacksize to unlimited;
% limit
cputime unlimited
filesize unlimited
datasize unlimited
stacksize unlimited
coredumpsize 0 kbytes
memoryuse unlimited
vmemoryuse unlimited
descriptors 1024
memorylocked unlimited
maxproc 511459
maxlocks unlimited
maxsignal 511459
maxmessage 819200
maxnice 0
maxrtprio 0
maxrttime unlimited
I am looking forward to seeing your reply. Thank you in advance.
Sincerely yours,
Hiroshi Yoshinari
ifort compile (make) error
Re: ifort compile (make) error
Hello ,
I guess you have problems with stacksize limit commands !
Yes, I got the same error. I just commented out the stack_size lines in Compilers/Linux-ifort.mk.
Yes, it is Darwin configuration that needs it. As Kate said, just comment the line in the Linux-ifort configuration file. Linux will take the unlimited value from the environmental variable. It is the loader LD that it is having the problem. It depends on what you have in your computer.
Dear Aminrahdarian, kate, and arango,
Thank you very much for prompt reply.
lines in Compilers/Linux-ifort.mk as kate did. And I succeeded in
MPI compiling (making) using 'ifort' compiler!
Thanks so much for useful advice.
Best regards,
Hiroshi
According as arango's advice, I also commented out the stack_sizearango wrote:Yes, it is Darwin configuration that needs it. As Kate said, just comment the line in the Linux-ifort configuration file. Linux will take the unlimited value from the environmental variable. It is the loader LD that it is having the problem. It depends on what you have in your computer.
Best regards,
Hiroshi
