Grid is not recognized by ROMS
aniskiewicz.paulina
#1 Unread post by aniskiewicz.paulina »
Hi :)
I have a problem with my grid file. In mu output file I see that model doesn't recognized grid file. My input grid looks like this:
Image (see below if you don't see the images here)
Unfortunately in my output file I see something like this:
Here are the information about grid file:
netcdf norfjords_160m_grid {
dimensions:
	xi_rho = 901 ;
	eta_rho = 451 ;
	xi_u = 900 ;
	eta_u = 451 ;
	xi_v = 901 ;
	eta_v = 450 ;
	bath = UNLIMITED ; // (2 currently)
	eta_psi = 450 ;
	xi_psi = 900 ;
variables:
	double xi_rho(xi_rho) ;
		xi_rho:long_name = "X coordinate of RHO-points" ;
		xi_rho:standard_name = "projection_x_coordinate" ;
		xi_rho:units = "meter" ;
	double eta_rho(eta_rho) ;
		eta_rho:long_name = "Y coordinate of RHO-points" ;
		eta_rho:standard_name = "projection_y_coordinate" ;
		eta_rho:units = "meter" ;
	double xi_u(xi_u) ;
		xi_u:long_name = "X coordinate of U-points" ;
		xi_u:standard_name = "projection_x_coordinate" ;
		xi_u:units = "meter" ;
	double eta_u(eta_u) ;
		eta_u:long_name = "Y coordinate of U-points" ;
		eta_u:standard_name = "projection_y_coordinate" ;
		eta_u:units = "meter" ;
	double xi_v(xi_v) ;
		xi_v:long_name = "X coordinate of V-points" ;
		xi_v:standard_name = "projection_x_coordinate" ;
		xi_v:units = "meter" ;
	double eta_v(eta_v) ;
		eta_v:long_name = "Y coordinate of V-points" ;
		eta_v:standard_name = "projection_y_coordinate" ;
		eta_v:units = "meter" ;
	double lon_rho(eta_rho, xi_rho) ;
		lon_rho:long_name = "longitude of RHO-points" ;
		lon_rho:standard_name = "longitude" ;
		lon_rho:units = "degrees_east" ;
	double lat_rho(eta_rho, xi_rho) ;
		lat_rho:long_name = "latitude of RHO-points" ;
		lat_rho:standard_name = "latitude" ;
		lat_rho:units = "degrees_north" ;
	double lon_u(eta_u, xi_u) ;
		lon_u:long_name = "longitude of U-points" ;
		lon_u:standard_name = "longitude" ;
		lon_u:units = "degrees_east" ;
	double lat_u(eta_u, xi_u) ;
		lat_u:long_name = "latitude of U-points" ;
		lat_u:standard_name = "latitude" ;
		lat_u:units = "degrees_north" ;
	double lon_v(eta_v, xi_v) ;
		lon_v:long_name = "longitude of V-points" ;
		lon_v:standard_name = "longitude" ;
		lon_v:units = "degrees_east" ;
	double lat_v(eta_v, xi_v) ;
		lat_v:long_name = "latitude of V-points" ;
		lat_v:standard_name = "latitude" ;
		lat_v:units = "degrees_north" ;
	double angle(eta_rho, xi_rho) ;
		angle:long_name = "angle between xi axis and east" ;
		angle:standard_name = "angle_of_rotation_from_east_to_x" ;
		angle:units = "radian" ;
		angle:coordinates = "lon_rho lat_rho" ;
		angle:grid_mapping = "grid_mapping" ;
	char spherical ;
		spherical:flag_values = "T, F" ;
		spherical:flag_meanings = "spherical Cartesian" ;
	double pm(eta_rho, xi_rho) ;
		pm:units = "meter-1" ;
		pm:field = "pm, scalar" ;
		pm:coordinates = "lon_rho lat_rho" ;
		pm:grid_mapping = "grid_mapping" ;
	double pn(eta_rho, xi_rho) ;
		pn:units = "meter-1" ;
		pn:field = "pn, scalar" ;
		pn:coordinates = "lon_rho lat_rho" ;
		pn:grid_mapping = "grid_mapping" ;
	double dndx(eta_rho, xi_rho) ;
		dndx:long_name = "xi derivative of inverse metric factor pn" ;
		dndx:units = "meter" ;
		dndx:field = "dndx, scalar" ;
		dndx:coordinates = "lon_rho lat_rho" ;
		dndx:grid_mapping = "grid_mapping" ;
	double dmde(eta_rho, xi_rho) ;
		dmde:long_name = "eta derivative of inverse metric factor pm" ;
		dmde:units = "meter" ;
		dmde:field = "pn, scalar" ;
		dmde:coordinates = "lon_rho lat_rho" ;
		dmde:grid_mapping = "grid_mapping" ;
	int grid_mapping ;
		grid_mapping:long_name = "grid mapping" ;
		grid_mapping:straight_vertical_longitude_from_pole = 70 ;
		grid_mapping:false_easting = 1480640. ;
		grid_mapping:standard_parallel = 60. ;
		grid_mapping:semi_major_axis = 6378137. ;
		grid_mapping:false_northing = 1496320. ;
		grid_mapping:grid_mapping_name = "polar_stereographic" ;
		grid_mapping:inverse_flattening = 298.257223563 ;
		grid_mapping:latitude_of_projection_origin = 90. ;
		grid_mapping:ellipsoid = "WGS84" ;
		grid_mapping:dx = 160 ;
		grid_mapping:proj4string = "+proj=stere +ellps=WGS84 +lat_0=90.0 +lat_ts=60.0 +x_0=1480640 +y_0=1496320 +lon_0=70" ;
	double hraw(bath, eta_rho, xi_rho) ;
		hraw:long_name = "Working bathymetry at RHO-points" ;
		hraw:standard_name = "sea_floor_depth" ;
		hraw:units = "meter" ;
		hraw:field = "bath, scalar" ;
		hraw:coordinates = "lon_rho lat_rho" ;
		hraw:grid_mapping = "grid_mapping" ;
	double h(eta_rho, xi_rho) ;
		h:long_name = "Final bathymetry at RHO-points" ;
		h:standard_name = "sea_floor_depth" ;
		h:units = "meter" ;
		h:field = "bath, scalar" ;
		h:coordinates = "lon_rho lat_rho" ;
		h:grid_mapping = "grid_mapping" ;
	double f(eta_rho, xi_rho) ;
		f:standard_name = "coriolis_parameter" ;
		f:units = "second-1" ;
		f:field = "Coriolis, scalar" ;
		f:coordinates = "lon_rho lat_rho" ;
		f:grid_mapping = "grid_mapping" ;
	double mask_rho(eta_rho, xi_rho) ;
		mask_rho:long_name = "mask on RHO-points" ;
		mask_rho:option_0 = "land" ;
		mask_rho:option_1 = "water" ;
		mask_rho:coordinates = "lon_rho lat_rho" ;
		mask_rho:grid_mapping = "grid_mapping" ;
	double mask_u(eta_u, xi_u) ;
		mask_u:long_name = "mask on U-points" ;
		mask_u:option_0 = "land" ;
		mask_u:option_1 = "water" ;
		mask_u:coordinates = "lon_u lat_u" ;
		mask_u:grid_mapping = "grid_mapping" ;
	double mask_v(eta_v, xi_v) ;
		mask_v:long_name = "mask on V-points" ;
		mask_v:option_0 = "land" ;
		mask_v:option_1 = "water" ;
		mask_v:coordinates = "lon_v lat_v" ;
		mask_v:grid_mapping = "grid_mapping" ;
	double mask_psi(eta_psi, xi_psi) ;
		mask_psi:long_name = "mask on PSI-points" ;
		mask_psi:option_0 = "land" ;
		mask_psi:option_1 = "water" ;
	double xl ;
		xl:long_name = "domain length in the XI-direction" ;
		xl:units = "meter" ;
	double el ;
		el:long_name = "domain length in the ETA-direction" ;
		el:units = "meter" ;
I've tried to use this assumption:
https://code.mpimet.mpg.de/boards/1/topics/913
I used ncks function:
ncks -v h,lon_rho,lat_rho norfjords_160m_grid.nc norfjords_160m_grid6.nc
And my result was smaller grid file:
dimensions:
	eta_rho = 451 ;
	xi_rho = 901 ;
variables:
		h:units = "meter" ;
Nevertheless, model still can not see the grid.
Did anybody have this problem?
Thank you for your response :)
ROMS input grid
ROMS input grid
ROMS output grid
ROMS output grid
Re: Grid is not recognized by ROMS
I can't see what the error is from ROMS. What does it say?
#3 Unread post by wilkin »
When you say ROMS does not recognize the grid, do you mean it did not read it at all or that it gave an error. If it did not even read perhaps you have #define ANA_GRID by mistake.
