Hello everyone,
I'm trying to use the pyroms tools to create my own files for initializing, defining boundaries and forcing. As the files I want to use are from HYCOM outputs (from GLBv0.08), I first want to train on the Arctic_HYCOM example. To do it, I need a definition of the grid ARCTIC2 (that I could then add into my gridid.txt). Could someone help me to find these few text lines?
Thanks a lot,
Morgane
training on pyroms ARCTIC2
Re: training on pyroms ARCTIC2
The few lines you're asking for are:
The grid file itself is rather large, not a great starter grid.id = ARCTIC2
name = ARCTIC2
grdfile = /archive/u1/uaf/AKWATERS/kshedstrom/gridpak/Arctic2/grid_Arctic_2.nc
N = 50
grdtype = roms
Vtrans = 4
theta_s = 7
theta_b = 2
Tcline = 250
Thanks a lot! ![Smile :)](./images/smilies/icon_smile.gif)
Hello everyone,
I try to interpolate some HYCOM output fields (temperature, salinity, ssh and wind velocity) to a ROMS grid thanks the pyroms tools. To achieve that, I try to reproduce the HYCOM_Arctic example from the examples directory. Yet, I succeed in interpolating the ssh from HYCOM GLBa0.08 to an ARCTIC2 grid.
That's means that :
The scripts built a new ssh which seems to be OK.
![Image](http://imagizer.imageshack.us/a/img923/3317/pMHbEM.png)
Then, I modified only the destination grid (actually, I tried a grid in the South Africa and keep exactly the same gridid parameters as ARCTIC2 to define the vertical grid) and I adapted the scripts get*.py , make_remap*.py, merge*.ksh, remap.py, remap_uv.py and make_ic_file*.py from the HYCOM_Arctic example to stay coherent.
While the grid file seems OK (mask is correct), the scripts built a interpolated ssh file with errors in the mash and abnormal values of ssh (FillValue in the ocean).
![Image](http://imagizer.imageshack.us/a/img923/8794/csASgS.png)
My source grid is well larger than my destination grid. I've verified that my longitudes and latitudes were defined the same than the example... Actually, I've no more ideas to test and I though that someone on the forum could have some new ones...
#I defined ARCTIC2 grid with these characteristics :
Lp = 160
Mp = 300
# define the 4 corners of the grid
# first point is the top left corner then counter clock wise rotation
lon0=-20.5
lat0=80.8
lon1=20.75
lat1=80.8
lon2=20.75
lat2=48.75
lon3=-20.5
lat3=48.75
hmin = 10.0
rx0_max = 0.2
gridid='ARCTIC2'
grd_name = 'ARCTIC2'
- I've well downloaded files from HYCOM.org.
I've formatted them through get_hycom_GLBa0.08_'varname'_2014.py.
I've built my source grid through get_hycom_GLBa0.08_grid.py.
I've computed my weigth files from make_remap_weights_file.py.
And then, I've 'concatenated' all my variable files to obtain one big file HYCOM_GLBa0.08_2014_095.nc.
I've modified my make_ic_file.py while adding a “exit()” line just after the computation of the ssh on the destinated grid (because, I realize something was wrong with the interpolation of my following variables).
# remap
zeta = remap(file, 'ssh', src_grd, dst_grd, dst_dir=dst_dir)
exit() # <= the lien I added
st_grd = pyroms.grid.get_ROMS_grid('ARCTIC2', zeta=zeta)
#I defined an other grid with these characteristics :
#Grid dimension
Lp = 280 # i-direction
Mp = 230 # j-direction
lon0=-2.5
lat0=-4.8
lon1=54.75
lat1=-4.8
lon2=54.75
lat2=-46.75
lon3=-2.5
lat3=-46.75
hmin = 10.0
rx0_max = 0.2
gridid='NEW_GRID'
grd_name = 'NEW_GRID'
When downloading HYCOM, pyroms expects the HYCOM grid file to be two grid cells larger in all directions than the other HYCOM files. Do you have that? It would be good to recode things so that that's not necessary, but we're not there yet.
Because of the North Pole, the Arctic is an especially challenging domain. There might be Arctic hacks that you don't want for a mid-latitude domain. We should provide examples for both kinds of domains - sorry about that.
Thanks a lot!
Indeed, I did not notice the modification in the index as downloading the HYCOM files. Now, my ssh interpolation works correctly.
And at the same time, that explains the error I received after the ssh interpolation, as computing the interpolation of the following variables.
Then, from some extra "print", I learned that :
Thanks you very much for these explanations !
File "make_ic_file.py", line 29, in <module>
remap(file, 'temp', src_grd, dst_grd, dst_dir=dst_dir)
File "/home/mdessert/pyroms/mytools/caretta_test/remap.py", line 127, in remap
dxy=dxy, cdepth=cdepth, kk=kk)
File "/home/mdessert/usr/conda/envs/seasnake/lib/python3.6/site-packages/pyroms_toolbox/Grid_HYCOM/flood_fast.py", line 87, in flood_fast
c = c1 & c2 & c3
grd.mask_t size = (33, 656, 4498)
grd.mask_t[0,:,:] size = (656, 4498)
C1 size : (656, 4496)
C2 size : (658, 4496) #=> and I did not understand why these mask was bigger ! It is from the mash while the two others are directly from the variable!
C3 size : (656, 4496)
