Hi, I'm a graduate student and I am trying to modelling a river that goes from east to west of my grade, i put the flow as a point source (22 point sources side by side) and i am using roms_iview to check if the velocities corresponds with my input( river_transport), and this part its ok, but in the end of my river the u velocities sometimes is negative this represent a flow entering in the end of my river, and this is not expected.
I tried many lateral boundaries, I had the better result with this one:
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Clo Clo Cha Clo ! free-surface
LBC(isUbar) == Clo Clo red Clo ! 2D U-momentum
LBC(isVbar) == Clo Clo red Clo ! 2D V-momentum
LBC(isUvel) == Clo Clo Rad Clo ! 3D U-momentum
LBC(isVvel) == Clo Clo Rad Clo ! 3D V-momentum
LBC(isMtke) == Clo Clo gra Clo ! mixing TKE
LBC(isTvar) == Clo Clo rad Clo\ ! temperature
Clo Clo rad Clo ! salinity
388800 ntimes Number of timesteps for 3-D equations.
20.000 dt Timestep size (s) for 3-D equations.
72 nRST Number of timesteps between the writing of data
into restart fields.
10 ninfo Number of timesteps between print of information
to standard output.
100 nHIS Number of timesteps between the writing fields
into history file.
0 nQCK Number of timesteps between the writing fields
into quicksave file.
for tracer 02: salt
20.000 Tcline S-coordinate surface/bottom layer width (m) used
1000.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
157.000 dstart Time-stamp assigned to model initialization (days).
20170101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
And my .h file:
/* momentum equations */
#define UV_ADV /* use to turn ON or OFF advection terms */
#define UV_LDRAG
#define ANA_HMIXCOEF
/* general options */
#define ANA_STFLUX
#define ANA_SMFLUX
#define ANA_INITIAL
#define ANA_FSOBC
But sometimes the velocity in u direction (in top levels) get negative. And I am assuming that in the bottom the velocity can be negative.
what should i have to do to get a right distribuition of velocities in the end of my river (west side)?
River Modelling
- Location: Federal University of Rio de Janeiro, LAMCE- COPPE
Re: River Modelling
If you are imposing a river inflow on the eastern end, then you don't want a radiation condition there. If the western end is outflow, then that should have a radiation condition. Since your inflow is at the edge of the domain, you can use the river sources with a closed wall boundary condition or you can use a clamped boundary condition. Either way, you enforce the velocity as being purely incoming and you have to specify all the tracer values there.
Re: River Modelling
Sorry, the inflow is on the west end. As you can see in the figure, the west end is closed ( the inflow is right).
When I put radiation condition on the eastern end, the outflow get wrong direction.
kate wrote:If you are imposing a river inflow on the eastern end, then you don't want a radiation condition there. If the western end is outflow, then that should have a radiation condition. Since your inflow is at the edge of the domain, you can use the river sources with a closed wall boundary condition or you can use a clamped boundary condition. Either way, you enforce the velocity as being purely incoming and you have to specify all the tracer values there.
Re: River Modelling
Is it going unstable? There's nothing in the radiation condition that guarantees outflow in all cells. The outgoing transport should match (roughly) the imposed inflow from the other end.
Re: River Modelling
Kate, i would like to thank you for your help.kate wrote:Is it going unstable? There's nothing in the radiation condition that guarantees outflow in all cells. The outgoing transport should match (roughly) the imposed inflow from the other end.
I will share what i choose as Lateral Boundary Condition and maybe this can be useful for someone.
LBC(isUbar) == Clo Clo Fla Clo ! 2D U-momentum
LBC(isVbar) == Clo Clo Fla Clo ! 2D V-momentum
And now, the u velocity looks better on eastern end (outflow).
