Riverplume Problem Abnormal Termination Netcdf Reason:
patrick.cocola
#1 Unread post by patrick.cocola »
Hello everyone,
Ok so I got some of the other test cases working, but the riverplume1 and riverplume2 are giving me problems. They pop up with an error:
Reason: No such file or directory
I have also attached the log file, .h file, and .in file.
Thank you in advanced.
riverplume.log
(21.1 KiB) Downloaded 486 times
ocean_riverplume1.in
(131.97 KiB) Downloaded 486 times
riverplume1.h
(1.19 KiB) Downloaded 462 times
Re: Riverplume Problem Abnormal Termination Netcdf Reason:
Sometimes you have to look higher up in the output:
ocean_rivers.nc
Is the error still unclear?
patrick.cocola
#3 Unread post by patrick.cocola »
is ocean_rivers.nc included in the trunk? Thats what i thought the error was but could not locate the file in the trunk or online
You can get the files as part of the test repository as described here.
patrick.cocola
#5 Unread post by patrick.cocola »
Ok i was looking around that location. The riverplume test cases are blank pages.
https://www.myroms.org/wiki/RIVERPLUME1_CASE
I also tried checking out the test cases with svn but still missing the ocean_rivers.nc file.
patrick.cocola
#6 Unread post by patrick.cocola »
Im just getting a little confused why the other test cases that use ocean_rivers.nc work but this one doesn't.
