Add c-language function in the ROMS compiling process
s.celestino
#1 Unread post by s.celestino »
I want to add a C function (to compute the resident set size memory used by ROMS) in the compiling process. I need to compile the object C file together the object fortran files.
This part in the makefile (line 185)?
#  Set Pattern rules.
%.o: %.F
%.o: %.f90
    cd $(SCRATCH_DIR); $(FC) -c $(FFLAGS) $(notdir $<)
%.f90: %.F
    $(CPP) $(CPPFLAGS) $(MY_CPP_FLAGS) $< > $*.f90
    $(CLEAN) $*.f90
Re: Add c-language function in the ROMS compiling process
I needed to add a C function for the waves-in-a-circle problem. I believe the chunk of makefile you show does nothing at all. It's all in the functions. I added these to https://github.com/kshedstrom/roms/blob ... n/makefile:
  c_sources  :=
# $(call source-to-object, source-file-list)
c-source-to-object = $(call source-dir-to-binary-dir,       \
                     $(subst .c,.o,$(filter %.c,$1))        \
                     $(subst .cc,.o,$(filter %.cc,$1)))
# $(call make-c-library, library-name, source-file-list)
define make-c-library
   libraries += $(SCRATCH_DIR)/$1
   c_sources += $2
   $(SCRATCH_DIR)/$1: $(call source-dir-to-binary-dir,    \
                      $(subst .c,.o,$(filter %.c,$2))     \
                      $(subst .cc,.o,$(filter %.cc,$2)))
        $(AR) $(ARFLAGS) $$@ $$^
        $(RANLIB) $$@
endef
# $(call one-c-compile-rule, binary-file, source-file)
define one-c-compile-rule
  $1: $2
        cd $$(SCRATCH_DIR); $$(CXX) -c $$(CXXFLAGS) $$<
endef
Then in your compilers file you also need:
               CC := gcc
              CXX := g++
           CFLAGS :=
         CXXFLAGS :=
ifdef USE_DEBUG
           FFLAGS += -g -fbounds-check
           CFLAGS += -g
         CXXFLAGS += -g
else
           FFLAGS += -O3 -ffast-math
           CFLAGS += -O3
         CXXFLAGS += -O3
endif
Finally, you need to invoke the compiling of your C code. I forget how we did that before. It was for the Hong Kong workshop, files which are no longer being served by ARSC with the demise of ARSC. I can poke around later for them.
#3 Unread post by kate »
Hah, I didn't do so much work back in 2011. I just needed one new C routine, so I did this in Master/Module.mk:
diff --git a/Master/Module.mk b/Master/Module.mk
index 4ff5e1b..a9c943d 100644
--- a/Master/Module.mk
+++ b/Master/Module.mk
@@ -18,8 +18,8 @@ ifdef LD_WINDOWS
 $(BIN):        $(libraries) $(local_objs)
        $(LD) $(FFLAGS) $(local_objs) -o $@ $(libraries) $(LIBS_WIN32) $(LDFLAGS)
 else
-$(BIN):        $(libraries) $(local_objs)
-       $(LD) $(FFLAGS) $(LDFLAGS) $(local_objs) -o $@ $(libraries) $(LIBS)
+$(BIN):        $(libraries) $(local_objs) $(SCRATCH_DIR)/bessi.o
+       $(LD) $(FFLAGS) $(LDFLAGS) $(local_objs) $(SCRATCH_DIR)/bessi.o -o $@ $(libraries) $(LIBS)
 endif
 $(eval $(compile-rules))
In other words, I added $(SCRATCH_DIR)/bessi.o to the dependencies and to the link list. Then in the makefile, I added these lines below the "all:" target, directions for creating $(SCRATCH_DIR)/bessi.o:
$(SCRATCH_DIR)/bessi.o: $(MY_ANALYTICAL_DIR)/bessi.c
[TAB]gcc -c $< -o $@
Note that you *must* have a tab before "gcc".
s.celestino
#4 Unread post by s.celestino »
Wow thanks a lot! I will try it now :D
s.celestino
#5 Unread post by s.celestino »
Thanks kate,
I updated all the code you cited.
and the makefile:
#  Build target directories.
.PHONY: all
all: $(SCRATCH_DIR) $(SCRATCH_DIR)/MakeDepend $(BIN) rm_macros
$(SCRATCH_DIR)/memuse.o: $(MY_ANALYTICAL_DIR)/memuse.c
    gcc -c $< -o $@
but after the compiling process I get this:
ar: creating /home/ocean/WC13/I4DVAR/Build/libUTIL.a
master.f90:122:25:
    print*, 'Mem Used:: ', memuse(), 'KB'
                         1
Error: Function ‘memuse’ at (1) has no IMPLICIT type
make: *** [/home/ldamore/ocean/WC13/I4DVAR/Build/master.o] Error 1
memuse() is defined in the memuse.c. So I did not compile the C object file together with the other files in fortran. Where am I wrong?
#6 Unread post by kate »
Actually, that's not what it's complaining about. It's complaining that you didn't declare the type of memuse in the Fortran code. Does memuse return an integer or a real? You have to tell the compiler since we have turned on IMPLICIT NONE (we don't want it making assumptions for us). At the top of your code, just add something like:
real(r8) :: memuse
or
integer :: memuse
s.celestino
#7 Unread post by s.celestino »
kate wrote:Actually, that's not what it's complaining about. It's complaining that you didn't declare the type of memuse in the Fortran code. Does memuse return an integer or a real? You have to tell the compiler since we have turned on IMPLICIT NONE (we don't want it making assumptions for us). At the top of your code, just add something like:
real(r8) :: memuse
or
integer :: memuse
Oh yes, you are right. I'm a noob on Fortran :D
Thanks.
