I hope I did not miss the answer to the following question inside the forum.
We are using two-way nesting for tidal-flat applications.
When comparing the free surface in coarse and fine grid within the same region, one can see a difference in dry areas. Whereas in fine grid, zeta meets the D_crit criterion, zeta in coarse grid is just zero.
This setting is done in fine2coarse, where the interpolation weights from fine grid in dry regions sets zeta-coarse to zero.
In "normal" settings (without nesting), there are code lines that guaranty zeta to meet the D_crit criterion like these in step_2d... :
# if defined WET_DRY && defined MASKING
zeta(i,j,knew)=zeta(i,j,knew)+ &
& (Dcrit(ng)-h(i,j))*(1.0_r8-rmask(i,j))
My question is now, if this inconsistency might cause any harm?
Best, Karsten
