floating invalid Couple ROMS and SWAN
okami_zxh
#1 Unread post by okami_zxh »
Hi All,
I am trying to running a idealized coupled case (COAWST), but there is error occurrd as below, I am using ifort:
/home/zhou/COAWST/Projects/Idealized_Mount_Hope
 Coupled Input File name = coupling_idealized_mount_hope.in
 Model Coupling:
       Ocean Model MPI nodes: 000 - 031
       Waves Model MPI nodes: 032 - 063
 Model Input Parameters:  ROMS/TOMS version 3.7
                          Saturday - October 7, 2017 -  1:51:34 PM
 Idealized Mount Hope
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : ifort
 Compiler command : /usr/mpi/intel/openmpi-1.3.2/bin/mpif90
 Compiler flags   : -heap-arrays -fp-model precise -g -check uninit -ftrapuv -traceback -assume byterecl -I/home/zhou/COAWST/install/include -free
 Input Script  :
 SVN Root URL  : https:://myroms.org/svn/src
 SVN Revision  : 1188M
 Local Root    : /home/zhou/COAWST
 Header Dir    : /home/zhou/COAWST/Projects/Idealized_Mount_Hope
 Header file   : idealized_mount_hope.h
 Analytical Dir: /home/zhou/COAWST/Projects/Idealized_Mount_Hope
 Resolution, Grid 01: 0098x0398x008,  Parallel Nodes:  32,  Tiling: 004x008
        720  ntimes            Number of timesteps for 3-D equations.
     60.000  dt                Timestep size (s) for 3-D equations.
         20  ndtfast           Number of timesteps for 2-D equations between
          1  ERstr             Starting ensemble/perturbation run number.
          1  ERend             Ending ensemble/perturbation run number.
          0  nrrec             Number of restart records to read from disk.
          T  LcycleRST         Switch to recycle time-records in restart file.
        720  nRST              Number of timesteps between the writing of data
                                 into restart fields.
          1  ninfo             Number of timesteps between print of information
                                 to standard output.
          1  nSTA              Number of timesteps between the writing of data
                                 the stations file.
          T  ldefout           Switch to create a new output NetCDF file(s).
         60  nHIS              Number of timesteps between the writing fields
                                 into history file.
  939942008  nQCK              Number of timesteps between the writing fields
                                 into quicksave file.
  939942008  ndefQCK           Number of timesteps between creation of new
                                 brief snpashots files.
          1  ntsAVG            Starting timestep for the accumulation of output
                                 time-averaged data.
         60  nAVG              Number of timesteps between the writing of
          1  ntsDIA            Starting timestep for the accumulation of output
         60  nDIA              Number of timesteps between the writing of
 1.0000E-03  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          F  LuvSponge         Turning OFF sponge on horizontal momentum.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: salt
 5.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 5.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak           Background vertical mixing coefficient (m2/s)
                                 for turbulent energy.
 5.0000E-06  Akp_bak           Background vertical mixing coefficient (m2/s)
      3.000  gls_p             GLS stability exponent.
      1.500  gls_m             GLS turbulent kinetic energy exponent.
     -1.000  gls_n             GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin          GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin          GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0          GLS stability coefficient.
 1.4400E+00  gls_c1            GLS shear production coefficient.
 1.9200E+00  gls_c2            GLS dissipation coefficient.
-4.0000E-01  gls_c3m           GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p           GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk          GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp          GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha     Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha    Factor for Zos calculation using Hsig(Awave).
      0.250  sz_alpha          Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw         Factor for Craig/Banner surface tke flux.
      0.000  wec_alpha         WEC factor for roller/breaking energy distribution.
 3.0000E-04  rdrg              Linear bottom drag coefficient (m/s).
 2.5000E-02  rdrg2             Quadratic bottom drag coefficient.
 1.5000E-02  Zob               Bottom roughness (m).
 5.0000E-01  Zos               Surface roughness (m).
          1  Vtransform        S-coordinate transformation equation.
          1  Vstretching       S-coordinate stretching function.
 1.0000E+00  theta_s           S-coordinate surface control parameter.
 1.0000E+00  theta_b           S-coordinate bottom  control parameter.
      0.000  Tcline            S-coordinate surface/bottom layer width (m) used
   1025.000  rho0              Mean density (kg/m3) for Boussinesq approximation.
      0.000  dstart            Time-stamp assigned to model initialization (days).
       0.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)         Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 9.0000E+01  Tnudg_SSS         Nudging/relaxation time scale (days)
                                 for sea surface salinity.
 0.0000E+00  Znudg             Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 0.0000E+00  obcfac            Factor between passive and active
          F  VolCons(1)        NLM western  edge boundary volume conservation.
          F  VolCons(2)        NLM southern edge boundary volume conservation.
          F  VolCons(3)        NLM eastern  edge boundary volume conservation.
          F  VolCons(4)        NLM northern edge boundary volume conservation.
     10.000  T0                Background potential temperature (C) constant.
     30.000  S0                Background salinity (PSU) constant.
   1027.000  R0                Background density (kg/m3) used in linear Equation
                                 of State.
 1.7000E-04  Tcoef             Thermal expansion coefficient (1/Celsius).
 7.6000E-04  Scoef             Saline contraction coefficient (1/PSU).
      1.000  gamma2            Slipperiness variable: free-slip (1.0) or
          F  LuvSrc            Turning OFF momentum point Sources/Sinks.
          F  LwSrc             Turning OFF volume influx point Sources/Sinks.
          F  LtracerSrc(01)    Turning OFF point Sources/Sinks on tracer 01: temp
          F  LtracerSrc(02)    Turning OFF point Sources/Sinks on tracer 02: salt
          F  LsshCLM           Turning OFF processing of SSH climatology.
          F  Lm2CLM            Turning OFF processing of 2D momentum climatology.
          F  Lm3CLM            Turning OFF processing of 3D momentum climatology.
          F  LtracerCLM(01)    Turning OFF processing of climatology tracer 01: temp
          F  LtracerCLM(02)    Turning OFF processing of climatology tracer 02: salt
          F  LnudgeM2CLM       Turning OFF nudging of 2D momentum climatology.
          F  LnudgeM3CLM       Turning OFF nudging of 3D momentum climatology.
          F  LnudgeTCLM(01)    Turning OFF nudging of climatology tracer 01: temp
          F  LnudgeTCLM(02)    Turning OFF nudging of climatology tracer 02: salt
          T  Hout(idBath)      Write out time-dependent bathymetry.
          T  Hout(idFsur)      Write out free-surface.
          T  Hout(idUbar)      Write out 2D U-momentum component.
          T  Hout(idVbar)      Write out 2D V-momentum component.
          T  Hout(idUvel)      Write out 3D U-momentum component.
          T  Hout(idVvel)      Write out 3D V-momentum component.
          T  Hout(idWvel)      Write out W-momentum component.
          T  Hout(idOvel)      Write out omega vertical velocity.
          T  Hout(idTvar)      Write out tracer 01: temp
          T  Hout(idTvar)      Write out tracer 02: salt
          T  Hout(idpthR)      Write out time-varying dephts of RHO-points.
          T  Hout(idpthU)      Write out time-varying dephts of U-points.
          T  Hout(idpthV)      Write out time-varying dephts of V-points.
          T  Hout(idpthW)      Write out time-varying dephts of W-points.
          T  Hout(idUbms)      Write out bottom U-momentum stress.
          T  Hout(idVbms)      Write out bottom V-momentum stress.
          T  Hout(idUbrs)      Write out bottom U-current stress.
          T  Hout(idVbrs)      Write out bottom V-current stress.
          T  Hout(idUbws)      Write out wind-induced, bottom U-wave stress.
          T  Hout(idVbws)      Write out wind-induced, bottom V-wave stress.
          T  Hout(idUbcs)      Write out max wind + current, bottom U-wave stress.
          T  Hout(idVbcs)      Write out max wind + current, bottom V-wave stress.
          T  Hout(idUVwc)      Write out max wind + current, bottom UV-wave stress.
          T  Hout(idUbot)      Write out bed wave orbital U-velocity.
          T  Hout(idVbot)      Write out bed wave orbital V-velocity.
          T  Hout(idUbur)      Write out bottom U-momentum above bed.
          T  Hout(idVbvr)      Write out bottom V-momentum above bed.
          T  Hout(idU2rs)      Write out total 2D u-radiation stress.
          T  Hout(idV2rs)      Write out total 2D v-radiation stress.
          T  Hout(idU2Sd)      Write out 2D u-momentum stokes velocity.
          T  Hout(idV2Sd)      Write out 2D v-momentum stokes velocity.
          T  Hout(idU3rs)      Write out total 3D u-radiation stress.
          T  Hout(idV3rs)      Write out total 3D v-radiation stress.
          T  Hout(idU3Sd)      Write out 3D u-momentum stokes velocity.
          T  Hout(idV3Sd)      Write out 3D v-momentum stokes velocity.
          T  Hout(idW3Sd)      Write out 3D omega-momentum stokes velocity.
          T  Hout(idW3St)      Write out 3D w-momentum stokes velocity.
          T  Hout(idWztw)      Write out WEC quasi-static sea level adjustment.
          T  Hout(idWqsp)      Write out WEC quasi-static pressure.
          T  Hout(idWbeh)      Write out WEC Bernoulli head.
          T  Hout(idWamp)      Write out wave height.
          T  Hout(idWlen)      Write out wavelength.
          T  Hout(idWdir)      Write out wave direction.
          T  Hout(idWptp)      Write out wave surface period.
          T  Hout(idWpbt)      Write out wave bottom period.
          T  Hout(idWorb)      Write out wave bottom orbital velocity.
          T  Hout(idWdif)      Write out wave dissipation due to bottom friction.
          T  Hout(idWdib)      Write out wave dissipation due to breaking.
          T  Hout(idWdiw)      Write out wave dissipation due to white capping.
          T  Hout(idUwav)      Wave-avg surface u-velocity.
          T  Hout(idVwav)      Wave-avg surface v-velocity.
          T  Hout(idVvis)      Write out vertical viscosity: AKv.
          T  Hout(idMtke)      Write out turbulent kinetic energy.
          T  Hout(idMtls)      Write out turbulent generic length-scale.
          T  Qout(idBath)      Write out time-dependent bathymetry.
          T  Qout(idFsur)      Write out free-surface.
          T  Qout(idUbar)      Write out 2D U-momentum component.
          T  Qout(idVbar)      Write out 2D V-momentum component.
          T  Qout(idu2dE)      Write out 2D U-eastward  at RHO-points.
          T  Qout(idv2dN)      Write out 2D V-northward at RHO-points.
          T  Qout(idUsur)      Write out surface U-momentum component.
          T  Qout(idVsur)      Write out surface V-momentum component.
          T  Qout(idsurT)      Write out surface tracer 01: temp_sur
          T  Qout(idsurT)      Write out surface tracer 02: salt_sur
          T  Aout(idU2Sd)      Write out averaged 2D u-momentum stokes velocity.
          T  Aout(idV2Sd)      Write out averaged 2D v-momentum stokes velocity.
          T  Aout(idSdif)      Write out averaged vertical diffusion: AKt(isalt).
          T  Dout(M2rate)      Write out 2D momentum acceleration.
          T  Dout(M2pgrd)      Write out 2D momentum pressure gradient.
          T  Dout(M2hadv)      Write out 2D momentum horizontal advection.
          T  Dout(M2xadv)      Write out 2D momentum horizontal X-advection.
          T  Dout(M2yadv)      Write out 2D momentum horizontal Y-advection.
          T  Dout(M2hvis)      Write out 2D momentum horizontal viscosity.
          T  Dout(M2xvis)      Write out 2D momentum horizontal X-viscosity.
          T  Dout(M2yvis)      Write out 2D momentum horizontal Y-viscosity.
          T  Dout(M2sstr)      Write out 2D momentum surface stress.
          T  Dout(M2bstr)      Write out 2D momentum bottom stress.
             Output Restart File:  ocean_rst.nc
             Output History File:  ocean_his_coupled.nc
            Output Averages File:  ocean_avg_coupled.nc
         Output Diagnostics File:  ocean_dia.nc
            Output Stations File:  ocean_sta.nc
        Physical parameters File:
                 Input Grid File:  /home/zhou/COAWST/Projects/Idealized_Mount_Hope/idealized_mount_hope_grid_low_resolution.nc
          Station positions File:  /home/zhou/COAWST/Projects/Idealized_Mount_Hope/stations_idealized_mount_hope.in
 Tile partition information for Grid 01:  0098x0398x0008  tiling: 004x008
 Number of tracers:            3
        0        1       24        1       49     9408
        1       25       49        1       49     9800
        2       50       74        1       49     9800
        3       75       98        1       49     9408
        4        1       24       50       99     9600
        5       25       49       50       99    10000
        6       50       74       50       99    10000
        7       75       98       50       99     9600
        8        1       24      100      149     9600
        9       25       49      100      149    10000
       10       50       74      100      149    10000
       11       75       98      100      149     9600
       12        1       24      150      199     9600
       13       25       49      150      199    10000
       14       50       74      150      199    10000
       15       75       98      150      199     9600
       16        1       24      200      249     9600
       17       25       49      200      249    10000
       18       50       74      200      249    10000
       19       75       98      200      249     9600
       20        1       24      250      299     9600
       21       25       49      250      299    10000
       22       50       74      250      299    10000
       23       75       98      250      299     9600
       24        1       24      300      349     9600
       25       25       49      300      349    10000
       26       50       74      300      349    10000
       27       75       98      300      349     9600
       28        1       24      350      398     9408
       29       25       49      350      398     9800
       30       50       74      350      398     9800
       31       75       98      350      398     9408
   (interior points only)
        0     0.50    24.50     0.50    49.50  RHO-points
        1    24.50    49.50     0.50    49.50  RHO-points
        2    49.50    74.50     0.50    49.50  RHO-points
        3    74.50    98.50     0.50    49.50  RHO-points
        4     0.50    24.50    49.50    99.50  RHO-points
        5    24.50    49.50    49.50    99.50  RHO-points
        6    49.50    74.50    49.50    99.50  RHO-points
        7    74.50    98.50    49.50    99.50  RHO-points
        8     0.50    24.50    99.50   149.50  RHO-points
        9    24.50    49.50    99.50   149.50  RHO-points
       10    49.50    74.50    99.50   149.50  RHO-points
       11    74.50    98.50    99.50   149.50  RHO-points
       12     0.50    24.50   149.50   199.50  RHO-points
       13    24.50    49.50   149.50   199.50  RHO-points
       14    49.50    74.50   149.50   199.50  RHO-points
       15    74.50    98.50   149.50   199.50  RHO-points
       16     0.50    24.50   199.50   249.50  RHO-points
       17    24.50    49.50   199.50   249.50  RHO-points
       18    49.50    74.50   199.50   249.50  RHO-points
       19    74.50    98.50   199.50   249.50  RHO-points
       20     0.50    24.50   249.50   299.50  RHO-points
       21    24.50    49.50   249.50   299.50  RHO-points
       22    49.50    74.50   249.50   299.50  RHO-points
       23    74.50    98.50   249.50   299.50  RHO-points
       24     0.50    24.50   299.50   349.50  RHO-points
       25    24.50    49.50   299.50   349.50  RHO-points
       26    49.50    74.50   299.50   349.50  RHO-points
       27    74.50    98.50   299.50   349.50  RHO-points
       28     0.50    24.50   349.50   398.50  RHO-points
       29    24.50    49.50   349.50   398.50  RHO-points
       30    49.50    74.50   349.50   398.50  RHO-points
       31    74.50    98.50   349.50   398.50  RHO-points
        0     1.00    24.50     0.50    49.50    U-points
        1    24.50    49.50     0.50    49.50    U-points
        2    49.50    74.50     0.50    49.50    U-points
        3    74.50    98.00     0.50    49.50    U-points
        4     1.00    24.50    49.50    99.50    U-points
        5    24.50    49.50    49.50    99.50    U-points
        6    49.50    74.50    49.50    99.50    U-points
        7    74.50    98.00    49.50    99.50    U-points
        8     1.00    24.50    99.50   149.50    U-points
        9    24.50    49.50    99.50   149.50    U-points
       10    49.50    74.50    99.50   149.50    U-points
       11    74.50    98.00    99.50   149.50    U-points
       12     1.00    24.50   149.50   199.50    U-points
       13    24.50    49.50   149.50   199.50    U-points
       14    49.50    74.50   149.50   199.50    U-points
       15    74.50    98.00   149.50   199.50    U-points
       16     1.00    24.50   199.50   249.50    U-points
       17    24.50    49.50   199.50   249.50    U-points
       18    49.50    74.50   199.50   249.50    U-points
       19    74.50    98.00   199.50   249.50    U-points
       20     1.00    24.50   249.50   299.50    U-points
       21    24.50    49.50   249.50   299.50    U-points
       22    49.50    74.50   249.50   299.50    U-points
       23    74.50    98.00   249.50   299.50    U-points
       24     1.00    24.50   299.50   349.50    U-points
       25    24.50    49.50   299.50   349.50    U-points
       26    49.50    74.50   299.50   349.50    U-points
       27    74.50    98.00   299.50   349.50    U-points
       28     1.00    24.50   349.50   398.50    U-points
       29    24.50    49.50   349.50   398.50    U-points
       30    49.50    74.50   349.50   398.50    U-points
       31    74.50    98.00   349.50   398.50    U-points
        0     0.50    24.50     1.00    49.50    V-points
        1    24.50    49.50     1.00    49.50    V-points
        2    49.50    74.50     1.00    49.50    V-points
        3    74.50    98.50     1.00    49.50    V-points
        4     0.50    24.50    49.50    99.50    V-points
        5    24.50    49.50    49.50    99.50    V-points
        6    49.50    74.50    49.50    99.50    V-points
        7    74.50    98.50    49.50    99.50    V-points
        8     0.50    24.50    99.50   149.50    V-points
        9    24.50    49.50    99.50   149.50    V-points
       10    49.50    74.50    99.50   149.50    V-points
       11    74.50    98.50    99.50   149.50    V-points
       12     0.50    24.50   149.50   199.50    V-points
       13    24.50    49.50   149.50   199.50    V-points
       14    49.50    74.50   149.50   199.50    V-points
       15    74.50    98.50   149.50   199.50    V-points
       16     0.50    24.50   199.50   249.50    V-points
       17    24.50    49.50   199.50   249.50    V-points
       18    49.50    74.50   199.50   249.50    V-points
       19    74.50    98.50   199.50   249.50    V-points
       20     0.50    24.50   249.50   299.50    V-points
       21    24.50    49.50   249.50   299.50    V-points
       22    49.50    74.50   249.50   299.50    V-points
       23    74.50    98.50   249.50   299.50    V-points
       24     0.50    24.50   299.50   349.50    V-points
       25    24.50    49.50   299.50   349.50    V-points
       26    49.50    74.50   299.50   349.50    V-points
       27    74.50    98.50   299.50   349.50    V-points
       28     0.50    24.50   349.50   398.00    V-points
       29    24.50    49.50   349.50   398.00    V-points
       30    49.50    74.50   349.50   398.00    V-points
       31    74.50    98.50   349.50   398.00    V-points
               HaloSizeI(1) =     117
               HaloSizeJ(1) =     192
                TileSide(1) =      58
                TileSize(1) =    1914
SWAN grid   1 is preparing computation
 Sediment Parameters, Grid: 01
 Size     Sd50        Csed        Srho        Wsed        Erate       poros
 Class    (mm)       (kg/m3)     (kg/m3)     (mm/s)     (kg/m2/s)    (nondim)
   1    4.0000E-03  0.0000E+00  2.6500E+03  1.0000E-01  6.0000E-03  0.0000E+00
         tau_ce      tau_cd      nl_tnu2     nl_tnu4     Akt_bak      Tnudg
         (N/m2)      (N/m2)      (m2/s)      (m4/s)       (m2/s)      (day)
   1    5.0000E-02  1.0000E-01  0.0000E+00  0.0000E+00  5.0000E-06  0.0000E+00
         morph_fac
         (nondim)
   1    1.0000E+00
 New bed layer formed when deposition exceeds  0.10000E-01 (m).
 Two first layers are combined when 2nd layer smaller than  0.00000E+00 (m).
 Rate coefficient for bed load transport =  0.15000E+00
          F  LtracerSponge(03Turning OFF sponge on tracer 03: mud_01
          F  LtracerSrc(03)  Turning OFF point sources/Sink on tracer 03: mud_01
          F  LtracerCLM(03)  Turning OFF processing of climatology tracer 03: mud_01
          F  LnudgeTCLM(03)  Turning OFF nudging of climatology tracer 03: mud_01
          T  Hout(idTvar)   Write out sediment01: mud_01
          T  Hout(idfrac)   Write out bed fraction, sediment 01: mudfrac_01
          T  Hout(idfrac)   Write out mass, sediment 01: mudmass_01
          T  Hout(idSbed)   Write out BED property 01: bed_thickness
          T  Hout(idSbed)   Write out BED property 02: bed_age
          T  Hout(idSbed)   Write out BED property 03: bed_porosity
          T  Hout(idSbed)   Write out BED property 04: bed_biodiff
          T  Hout(idBott)   Write out BOTTOM property 01: grain_diameter
          T  Hout(idBott)   Write out BOTTOM property 02: grain_density
          T  Hout(idBott)   Write out BOTTOM property 03: settling_vel
          T  Hout(idBott)   Write out BOTTOM property 04: erosion_stress
          T  Hout(idBott)   Write out BOTTOM property 05: ripple_length
          T  Hout(idBott)   Write out BOTTOM property 06: ripple_height
          T  Hout(idBott)   Write out BOTTOM property 07: bed_wave_amp
          T  Hout(idBott)   Write out BOTTOM property 08: Zo_def
          T  Hout(idBott)   Write out BOTTOM property 09: Zo_app
          T  Hout(idBott)   Write out BOTTOM property 15: active_layer_thickness
          T  Hout(idBott)   Write out BOTTOM property 17: bed_inund_depth
          T  Hout(idBott)   Write out BOTTOM property 18: dep_net
 Stations Parameters, Grid: 01
          3  Nstation        Number of stations to write out into stations file.
          T  Sout(idbath)    Write out free-surface.
          T  Sout(idFsur)    Write out free-surface.
          T  Sout(idUbar)    Write out 2D U-momentum component.
          T  Sout(idVbar)    Write out 2D V-momentum component.
          T  Sout(idUvel)    Write out 3D U-momentum component.
          T  Sout(idVvel)    Write out 3D V-momentum component.
          T  Sout(idWvel)    Write out W-momentum component.
          T  Sout(idOvel)    Write out omega vertical velocity.
          T  Sout(idTvar)    Write out tracer 01: temp
          T  Sout(idTvar)    Write out tracer 02: salt
          T  Sout(idTvar)    Write out tracer 03: mud_01
          T  Sout(idUsms)    Write out surface U-momentum stress.
          T  Sout(idVsms)    Write out surface V-momentum stress.
          T  Sout(idUbms)    Write out bottom U-momentum stress.
          T  Sout(idVbms)    Write out bottom V-momentum stress.
          T  Sout(idUbrs)    Write out bottom U-current stress.
          T  Sout(idVbrs)    Write out bottom V-current stress.
          T  Sout(idUbws)    Write out wind-induced, bottom U-wave stress.
          T  Sout(idVbws)    Write out wind-induced, bottom V-wave stress.
          T  Sout(idUbcs)    Write out max wind + current, bottom U-wave stress.
          T  Sout(idVbcs)    Write out max wind + current, bottom V-wave stress.
          T  Sout(idUbot)    Write out bed wave orbital U-velocity.
          T  Sout(idVbot)    Write out bed wave orbital V-velocity.
          T  Sout(idUbur)    Write out bottom U-velocity above bed.
          T  Sout(idVbvr)    Write out bottom V-velocity above bed.
          T  Sout(idWamp)    Write out wave height.
          T  Sout(idWlen)    Write out wave length.
          T  Sout(idWdir)    Write out wave direction.
          T  Sout(idWptp)    Write out wave surface period.
          T  Sout(idWpbt)    Write out wave bottom period.
          T  Sout(idWorb)    Write out wave bottom orbital velocity.
          T  Sout(idWdis)    Write out wave dissipation.
          T  Sout(idBott)    Write out bottom property 01: grain_diameter
          T  Sout(idBott)    Write out bottom property 02: grain_density
          T  Sout(idBott)    Write out bottom property 03: settling_vel
          T  Sout(idBott)    Write out bottom property 04: erosion_stress
          T  Sout(idBott)    Write out bottom property 05: ripple_length
          T  Sout(idBott)    Write out bottom property 06: ripple_height
          T  Sout(idBott)    Write out bottom property 07: bed_wave_amp
          T  Sout(idBott)    Write out bottom property 08: Zo_def
          T  Sout(idBott)    Write out bottom property 09: Zo_app
          T  Sout(idBott)    Write out bottom property 10: Zo_Nik
          T  Sout(idBott)    Write out bottom property 11: Zo_bio
          T  Sout(idBott)    Write out bottom property 12: Zo_bedform
          T  Sout(idBott)    Write out bottom property 13: Zo_bedload
          T  Sout(idBott)    Write out bottom property 14: Zo_wbl
          T  Sout(idBott)    Write out bottom property 15: active_layer_thickness
          T  Sout(idBott)    Write out bottom property 16: saltation
          T  Sout(idBott)    Write out bottom property 17: bed_inund_depth
          T  Sout(idBott)    Write out bottom property 18: dep_net
          T  Sout(idVvis)    Write out vertical viscosity coefficient.
          T  Sout(idMtke)    Write out turbulent kinetic energy.
          T  Sout(idMtls)    Write out turbulent generic length-scale.
             Flag and positions for station 0001:  0    38.0000   25.0000
             Flag and positions for station 0002:  0    38.0000   35.0000
             Flag and positions for station 0003:  0    38.0000   45.0000
 zeta                     1   Gradient     Clamped      Gradient     Closed
 ubar                     1   Gradient     Reduced      Gradient     Closed
 vbar                     1   Gradient     Reduced      Gradient     Closed
 u                        1   Gradient     Reduced      Gradient     Closed
 v                        1   Gradient     Reduced      Gradient     Closed
 temp                     1   Gradient     Gradient     Gradient     Closed
 salt                     1   Gradient     Gradient     Gradient     Closed
 mud_01                   1   Gradient     Gradient     Gradient     Closed
 tke                      1   Gradient     Gradient     Gradient     Closed
 ubar_stokes              1   Gradient     Gradient     Gradient     Closed
 vbar_stokes              1   Gradient     Gradient     Gradient     Closed
 u_stokes                 1   Gradient     Gradient     Gradient     Closed
 v_stokes                 1   Gradient     Gradient     Gradient     Closed
 IDEALIZED_MOUNT_HOPEIdealized Mount Hope
 ANA_BPFLUX          Analytical bottom passive tracers fluxes.
 ANA_FSOBC           Analytical free-surface boundary conditions.
 ANA_INITIAL         Analytical initial conditions.
 ANA_M2OBC           Analytical 2D momentum boundary conditions.
 ANA_SEDIMENT        Analytical sediment initial conditions.
 ANA_SMFLUX          Analytical kinematic surface momentum flux.
 ANA_SPFLUX          Analytical surface passive tracer fluxes.
 ANA_SSFLUX          Analytical kinematic surface salinity flux.
 ANA_STFLUX          Analytical kinematic surface temperature flux.
 DIAGNOSTICS_UV      Computing and writing momentum diagnostic terms.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 MCT_LIB             Using Model Coupling Toolkit library.
 WEC_VF              Vortex Force wave current interaction.
 WDISS_WAVEMOD       Wave energy dissipation acquired from coupled wave model.
 !NONLIN_EOS         Linear Equation of State for seawater.
 K_GSCHEME           Third-order upstream advection of TKE fields.
 RI_SPLINES          Parabolic Spline Reconstruction for Richardson Number.
 SEDIMENT            Cohesive and noncohesive sediments.
 SED_MORPH           Allow bottom model elevation to evolve.
 SUSPLOAD            Activate suspended sediment transport.
 NONCOHESIVE_BED1    Activate non-cohesive (original) sediment bed.
 SPLINES_VDIFF       Parabolic Spline Reconstruction for Vertical Diffusion.
 SPLINES_VVISC       Parabolic Spline Reconstruction for Vertical Viscosity.
 SSW_BBL             Styles and Glenn Bottom Boundary Layer - modified.
 SSW_CALC_ZNOT       Internal computation of bottom roughness.
 STATIONS            Writing out station data.
 SWAN_COUPLING       SWAN model coupling.
 TS_MPDATA           Recursive flux corrected MPDATA 3D advection of tracers.
 UV_KIRBY            Compute uwave and vwave Kirby avg velocities.
 WAVES_OCEAN         Two-way wave-ocean models coupling.
 Process Information:
 Node # 21 (pid=    7059) is active.
 Node # 23 (pid=    7061) is active.
 Node #  7 (pid=    7045) is active.
 Node # 13 (pid=    7051) is active.
 Node # 15 (pid=    7053) is active.
 Node # 25 (pid=    7063) is active.
 Node # 27 (pid=    7065) is active.
 Node # 29 (pid=    7067) is active.
 Node # 31 (pid=    7069) is active.
 Node #  1 (pid=    7039) is active.
 Node #  3 (pid=    7041) is active.
 Node #  5 (pid=    7043) is active.
 Node #  9 (pid=    7047) is active.
 Node # 11 (pid=    7049) is active.
 Node # 17 (pid=    7055) is active.
 Node # 19 (pid=    7057) is active.
 Node #  0 (pid=    7038) is active.
 Node # 22 (pid=    7060) is active.
 Node # 28 (pid=    7066) is active.
 Node #  4 (pid=    7042) is active.
 Node #  6 (pid=    7044) is active.
 Node #  8 (pid=    7046) is active.
 Node # 12 (pid=    7050) is active.
 Node # 14 (pid=    7052) is active.
 Node # 18 (pid=    7056) is active.
 Node # 20 (pid=    7058) is active.
 Node # 26 (pid=    7064) is active.
 Node # 16 (pid=    7054) is active.
 Node # 30 (pid=    7068) is active.
 Node #  2 (pid=    7040) is active.
 Node # 10 (pid=    7048) is active.
 Node # 24 (pid=    7062) is active.
 level   S-coord     Cs-curve   Z   at hmin       at hc    half way     at hmax
     8   0.0000000   0.0000000        0.000       0.000       0.000       0.000
     7  -0.1250000  -0.1122656       13.125      13.125       6.108      -0.908
     6  -0.2500000  -0.2350037       26.250      26.250      11.562      -3.125
     5  -0.3750000  -0.3654529       39.375      39.375      16.534      -6.307
     4  -0.5000000  -0.5000000       52.500      52.500      21.250     -10.000
     3  -0.6250000  -0.6345471       65.625      65.625      25.966     -13.693
     2  -0.7500000  -0.7649963       78.750      78.750      30.938     -16.875
     1  -0.8750000  -0.8877344       91.875      91.875      36.392     -19.092
     0  -1.0000000  -1.0000000      105.000     105.000      42.500     -20.000
 Time Splitting Weights for Grid 01:    ndtfast =  20    nfast =  29
  3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
  4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
  5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
  6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
  7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
  8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
  9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
 10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
 11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
 12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
 13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
 14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
 15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
 16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
 17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
 18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
 19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
 20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
 21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
 22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
 23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
 24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
 25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
 26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
 27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
 28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
 29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
 ndtfast, nfast =   20  29   nfast/ndtfast =  1.45000
 Power filter parameters, Fgamma, gamma =  0.28400   0.14200
 Minimum X-grid spacing, DXmin =  5.00000000E-02 km
 Maximum X-grid spacing, DXmax =  5.00000000E-02 km
 Minimum Y-grid spacing, DYmin =  5.00000000E-02 km
 Maximum Y-grid spacing, DYmax =  5.00000000E-02 km
 Minimum Z-grid spacing, DZmin = -1.31250000E+01 m
 Maximum Z-grid spacing, DZmax =  3.69338142E+00 m
 Minimum barotropic Courant Number =  1.18854533E+00
 Maximum barotropic Courant Number =  2.72329947E+00
 Maximum Coriolis   Courant Number =  1.37347242E-05
 Maximum grid stiffness ratios:  rx0 =   2.126761E+00 (Beckmann and Haidvogel)
                                 rx1 =   3.090640E+01 (Haney)
 Initial basin volumes: TotVolume = -1.6199375000E+08 m3
                        MinVolume = -3.2812500000E+04 m3
                        MaxVolume =  9.2334535457E+03 m3
                          Max/Min = -2.8140048901E-01
 ** ROMS grid  1 recv data from SWAN grid  1
 == SWAN grid  1 sent wave data to ROMS grid  1
SWANtoROMS Min/Max DISBOT  (Wm-2):     0.000000E+00  0.000000E+00
SWANtoROMS Min/Max DISSURF (Wm-2):     0.000000E+00  0.000000E+00
SWANtoROMS Min/Max DISWCAP (Wm-2):     0.000000E+00  0.000000E+00
SWANtoROMS Min/Max HSIGN   (m):        0.000000E+00  2.006879E-02
SWANtoROMS Min/Max RTP     (s):        0.000000E+00  1.903654E+00
SWANtoROMS Min/Max TMBOT   (s):        0.000000E+00  3.071143E+00
SWANtoROMS Min/Max UBOT    (ms-1):     0.000000E+00  3.127606E-07
SWANtoROMS Min/Max DIR     (deg):      0.000000E+00  1.413716E+00
SWANtoROMS Min/Max WLEN    (m):        1.000000E+00  3.120065E+00
forrtl: error (65): floating invalid
Image              PC                Routine            Line        Source
coawstG            0000000000447396  ocean_coupler_mod         634  ocean_coupler.f90
coawstG            00000000004426E1  ocean_coupler_mod         442  ocean_coupler.f90
coawstG            000000000047EF62  initial_                  381  initial.f90
coawstG            000000000043CBA8  ocean_control_mod         142  ocean_control.f90
coawstG            000000000043BA6D  MAIN__                    204  master.f90
coawstG            00000000004396FC  Unknown               Unknown  Unknown
libc.so.6          000000321461D994  Unknown               Unknown  Unknown
coawstG            0000000000439609  Unknown               Unknown  Unknown
mpirun noticed that process rank 16 with PID 7054 on node compute-0-5.local exited on signal 6 (Aborted).
I also attached the PRINT file of SWAN output.
                    Execution started at 20171007.135134
                                     SWAN
                    SIMULATION OF WAVES IN NEAR SHORE AREAS
                             VERSION NUMBER 41.01AB
 PROJECT 'Idealized' '01'
  'Idealized Mount Hope'
  'Bathymetry: flat bottom'
  'COMMENTS'
 MODE NONSTATIONARY TWODIMENSIONAL
 SET DEPMIN 0.10 INRHOG 1 NAUTICAL
 COORDINATES CARTESIAN
 && KEYWORD for number of nested SWAN grids.
 NSGRIDS 1
 && KEYWORDS TO CREATE AND READ COMPUTATIONAL GRID &&
 CGRID CURVILINEAR 99 399 EXC 9.999000e+003 &
         CIRCLE 36 0.04 1.0 20
 Resolution in sigma-space: df/f =  0.1746
 READGRID COORDINATES 1 '/home/zhou/COAWST/Projects/Idealized_Mount_Hope/swan_coord.grd' 4 0 0 FREE
 && KEYWORDS TO CREATE AND READ BATHYMETRY GRID &&
 INPGRID BOTTOM CURVILINEAR 0 0 99 399 EXC 9.999000e+003
 READINP BOTTOM  1 '/home/zhou/COAWST/Projects/Idealized_Mount_Hope/swan_bathy.bot' 4 0 FREE
 && KEYWORD TO CREATE CURRENT GRID &&
 INPGRID CURRENT CURVILINEAR 0 0 99 399 EXC 9.999000e+003              &
         NONSTAT  20000101.000000 25 DAY 20000126.000000
 && KEYWORD TO CREATE WATER LEVEL GRID &&
 INPGRID WLEV CURVILINEAR 0 0 59 399 EXC 9.999000e+003                 &
 && KEYWORD TO CREATE BOTTOM FRICTION GRID &&
 INPGRID FRIC CURVILINEAR 0 0 99 399 EXC 9.999000e+003                 &
 && BOUNDARY FORCING &&
 BOUNDPAR1 SHAPESPEC JONSWAP 3.3 PEAK DSPR DEGREES
 BOUNDPAR2 SEGMENT IJ 0 399 99 399 CONSTANT PAR 1.0 10.0 0. 20.
 ** Warning          : No points on the boundaries found
 & Restart name **********************************
 &INIT HOTSTART 'swan_mount_hope_rst.dat'
 & PHYSICS  **************************************
 GEN3
 FRICTION MADSEN 0.05
 OFF QUAD
 BLOCK 'COMPGRID' NOHEADER 'depth.mat'   LAY 4 DEPTH 1.    OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'watlev.mat'  LAY 4 WATLEV 1.   OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'botlev.mat'  LAY 4 BOTLEV 1.   OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'vel.mat'     LAY 4 VEL 1.      OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'fric.mat'    LAY 4 FRCOEF  1.  OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'dissip.mat'  LAY 4 DISSIP 1.   OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'hsig.mat'    LAY 4 HSIGN 1.    OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'rtp.mat'     LAY 4 RTP 1.      OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'tmbot.mat'   LAY 4 TMBOT 1.    OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'ubot.mat'    LAY 4 UBOT 1.     OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'wdir.mat'    LAY 4 DIR 1.      OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'wdirbot.mat' LAY 4 DIRBOT 1.   OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'wlen.mat'    LAY 4 WLEN 1.     OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'qb.mat'      LAY 4 QB 1.       OUTPUT 20000101.000000 1 HR
 BLOCK 'COMPGRID' NOHEADER 'xp.mat'      LAY 4 XP 1.
 BLOCK 'COMPGRID' NOHEADER 'yp.mat'      LAY 4 YP 1.
 BLOCK 'COMPGRID' NOHEADER 'hsig.nc'   LAY 4 HSIGN 1.    OUTPUT 20000101.000000 1 HR
 POINTS  'point1' 5000.0 10000.0
 SPECOUT 'point1' SPEC2D 'point1.spc2d' OUTPUT 20000101.000000 1 HR
 TABLE   'point1' HEADER 'point1.table' HSIGN DIR DIRBOT WLEN OUTPUT 20000101.000000 1 HR
 PROP BSBT
 RESTART 'swan_mount_hope_rst.dat' FREE 1 HR
 COMPUTE NONSTATIONARY 20000101.000000 60 SEC 20000101.120000
 ** Warning          : (corner)point outside comp. grid
       Set of output locations: point1    coordinates:   5000.00  10000.00
 ** Warning          : Limiter is de-activated in case of no quadruplets
 Time of computation ->  20000101.000100      in sec:         60.
Re: floating invalid Couple ROMS and SWAN
difficult to tell. maybe start out by looking at line 634 ocean_coupler.f90
do you have wettt/dry on? is this a shallow water application?
can you post a ticket here:
https://coawstmodel-trac.sourcerepo.com ... el_COAWST/
thanks
john
okami_zxh
#3 Unread post by okami_zxh »
Hi John,
Thank you for your reply. I will post it on COAWST disscusion. Where is ocean_couple.f90?
Xiaohui
