f951: sorry, unimplemented: Graphite loop.. cannot be used
barack99
#1 Unread post by barack99 »
Dear All,
I am a new ROMS user, I got the error message below while trying to run test case: Sed_floc_toy_check. Could anyone offer some help?
Many thanks
Barack
f951: sorry, unimplemented: Graphite loop optimizations cannot be used (-fgraphite, -fgraphite-identity, -floop-block, -floop-interchange, -floop-strip-mine, -floop-parallelize-all, and -ftree-loop-linear)
make: *** [/data/COAWST/Projects/Sed_floc_toy_check/Build/mod_kinds.o] Error 1
Barack
Re: f951: sorry, unimplemented: Graphite loop.. cannot be us
Which compiler are you using? Those look like gnu fortran options.
barack99
#3 Unread post by barack99 »
Hi Kate,
That error occured with gfortran. When I tried another test (Sedbed_toy) with Ifort/openMPI, I got another error message below.
Could you help?
Many Thanks & Regards
Barack
cd /data/projects/COAWST/Projects/Sedbed_toy_check/Build; /usr/local/software/OpenMPI/2.0.2-intel-2016.u3/bin/mpif90 -c -heap-arrays -fp-model precise -ip -O2 u2dbc_im.f90
u2dbc_im.f90(171): error #6404: This name does not have a type, and must have an explicit type. [FIRST_2D_STEP]
IF (FIRST_2D_STEP) THEN
u2dbc_im.f90(171): error #6341: A logical data type is required in this context. [FIRST_2D_STEP]
compilation aborted for u2dbc_im.f90 (code 1)
make: *** [/data/projects/COAWST/Projects/Sedbed_toy_check/Build/u2dbc_im.o] Error 1
Barack
I don't know where you are getting those extra compile flags from. My roms wants to compile with gfortran like this:
cd Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math strings.f90
Did you do a "make clean" before trying with a different compiler? FIRST_2D_STEP is coming from globaldefs.h and should not be seen by the compiler. Is there some other error above that from the cpp phase?
barack99
#5 Unread post by barack99 »
I did "make clean", but I dont know where the error came from?
Do you have any further suggestion?
Barack
#6 Unread post by kate »
I would go back to gfortran and try to figure out where those extra options came from. Do you have an FFLAGS environment variable set?
barack99
#7 Unread post by barack99 »
Dear Kate,
I have: FFLAGS := -frepack-arrays
I am able to compile MCT/SCRIPT_COAWST, and SWAN alone, but when compiling: Projects\Inlet_test\Coupled... I got another error below.
Where could I find m_coupling.mod? or m_coupling.f90/ftn?
swan_iounits.f90:14:10:
USE M_COUPLING
1
Fatal Error: Can't open module file ‘m_coupling.mod’ for reading at (1): No such file or directory
compilation terminated.
Barack
#8 Unread post by kate »
To find things, I like to use grep. In this case you can use the -ir option for recursive, case insensitive:
grep -ir m_coupling .
In addition to finding the "USE" lines, you get:
./SWAN/Src/swmod2.ftn:      MODULE M_COUPLING
./SWAN/Src/swmod2.ftn:      END MODULE M_COUPLING
It also matches instances of ocn2atm_coupling, oh well.
How to get things to compile in the correct order is another issue entirely, something I don't know how SWAN is attempting.
barack99
#9 Unread post by barack99 »
All right! :D
After changing gfortran/MPI versions, and re-building netCDF libraries, I have successfully compiled my COAWST! I am able to run all testcases in 'Projects' without any error!
My current versions are: GCC 5.4.0, OpenMPI 2.0.2, Zlib1.2.11/HDF51.10.1, netcdf-C 4.4.1.1 and netCDF-Fortran 4.4.0.
Thanks & Regards
Barrack
Barack
okami_zxh
#10 Unread post by okami_zxh »
barack99 wrote:All right! :D
Thanks & Regards
Barrack
Hi Barrack,
Which version of gfortran you are using for COAWST?
Xiaohui
barack99
#11 Unread post by barack99 »
As I mentioned GCC version is 5.4, so that is gfortran.
Barack
SivaHeramb
#12 Unread post by SivaHeramb »
Barrack[/quote]
I got the same error (with the same file and also because of FIRST_2D_STEP lines) but when using gfortran for compiling the basic upwelling case.
Is it because of any compilers incompatibility?
My current versions are almost same as you mentioned.
Can you help me out with this error?
Thanks and Regards,
Siva Heramb
